    Thành viên chính thức sutuden's Avatar
    Mặc định 3110c lên nguồn hiện NOKIA rồi tắt.
    em chạy lại không hết. nâng lên ver cao nhất cũng vẫn vậy, em nạp file xóa vô rồi chạy lại thì ok. và đây là log cua nó:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_v_128
    APE Variant file: NONE
    Languages in ppm: English,Chinese T,Vietnamese
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 0600020E64937C56F5D7004D9A84863714640A43
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 09.0B.01 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 89810089 <=> INTEL -> Type not in database
    CMT Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 09.2F.00 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Sending CRT data...
    Erasing...
    Operation took 0 minutes 2 seconds...
    Writing...
    Stage 1
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    Sending CMT PUB KEYS...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Sending CMT HASH for PMM_CONF
    Sending CMT HASH for SBIF_CONF
    Operation took 2 minutes 2 seconds...
    Reseting phone...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_v
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader Ready
    Erasing...
    Operation took 0 minutes 24 seconds...
    Writing...
    Stage 1
    Operation took 0 minutes 33 seconds...
    Reseting phone...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_v_128
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Operation took 0 minutes 48 seconds...
    Writing...
    Stage 1
    Operation took 0 minutes 38 seconds...
    Reseting phone...
    Done!
    Total time: 4 Minutes, 44 Seconds
    DCT4/BB5 counter: 1120
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RM-237, Software version: 07.21
    IMEI: 12345610654321?
    APE Ver: (null)
    Variant Ver: (null)
    Product Code: 0552816
    Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 07.21
    05-11-08
    RM-237
    (c) Nokia.
    HW version: 5005
    PCI version:
    RFIC version:  17211721
    DSP version:
    ICPR61_08w10
    PPM version: V 07.21
    05-11-08
    RM-237
    (c) Nokia.
    V
    BT MCM version: 06cc-P9.1
    Retu version: 32
    Tahvo version: 53
    Content Pack version: Content: v
    V 07.21
    13-01-09
    RM-237
    (c) Nokia.
    Production serial number: MSB695027
    Product code: 0552816
    Module code: 0203291
    Basic production code: 0542523
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 12345610654321?
    IMEI spare to net: 1A 32 54 16 60 45 23 01
    IMEI SV to net: 13 32 54 16 60 45 23 21 F5
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Done!
    nhưng mà cứ write rpl vào là máy lại bị như ban đầu. bác nào làm wa mong giúp em
    korea
    bạn xóa full một lần nữa ( nên dùng eno file để xóa) và chạy lại ver ban đầu của nó . rùi nạp lại rpl coi dc không . thân
    hãy nhấn nút THANKS khi bài viết hữu ích cho bạn . thank all
    Thành viên mới quanvv's Avatar
    banh imei rồi bác
    Default SN type:
    nếu có backup thì write lại
    http://dananggsm.com
    Thành viên chính thức vanhieu9566's Avatar
    Trích Được post bởi quanvv Xem bài viết
    banh imei rồi bác
    Default SN type:
    đúng đó bị banh imei rồi bạn ơi
    V.I.P UNLOCKDTDD's Avatar
    Default SN type:
    nếu có backup rpl thì nạp lại thôi, con không chắc phải thay cặp khác cho lẹ
    Super Moderator tuanhoang's Avatar
    Sep 2007
    giờ khổ chủ làm theo cách này nhé !
    nếu máy được xoá full >> nạp lại done >> lên nguồn >> Wri RPL vô vẫn kg đồng bộ được thì nếu file BK của bạn ở ver cao hơn thì chỉ cần nạp lại ver đó là có imei thôi ,nếu xoá banh rồi lại nạp ver cao nhất mà Wri BK khi ver thấp hơn phone sẽ kg đồng bộ được ,nếu như vậy ,làm theo cách sau :
    nếu bạn chắc chắn file BK đó ver nào ,ví dụ 06.02 ,thì giờ tiến hành xoá full rồi nạp 06.02 ( vì xoá full rồi thì nạp vẻ thấp vẫn lên OK ) bây giờ nạp 06.02 >> lên OK rồi Wri BK vô ,1 trường hợp nữa ,nếu kg nhớ file BK ver nào ,ta nên xoá full lại >> nạp ver thấp chút rồi Wri file BK vô ,not ok >> thẳng tiến từng nắc thang >> max chưa OK >> hết phím
    PS/ các bạn trả lời vụ banh imei nên xem lại ,vì trường hợp này khổ chú có BK ,vả lại cũng hiểu cần Wri lại BK !
    TRUNG TÂM SỬA CHỮA DTDD TUẤN HOÀNG - GIA TÂN 1-THỐNG-NHẤT-ĐỒNG NAI-QL-20
    Chuyên SW & HW all Mobile -LH_ ĐT:0613778888-3867722-0902442220-0966907790
    Bank-plus Cua VT:9990110214707_Vũ Tiến Hoàng : NH Agribank số TK:5915205023902
  1. 3110c lên nokia rồi tự tắt nguồn
    By 0985598885 in forum BB5
    Trả lời: 14
    Bài viết cuối: 14-06-2011, 07:09
  2. 3110c lên nokia chớp tắt !
    By hà_vũng tàu in forum BB5
    Bài viết cuối: 22-05-2011, 18:28
  3. Trả lời: 7
    Bài viết cuối: 24-05-2010, 07:08
  4. Trả lời: 25
    Bài viết cuối: 27-01-2010, 16:24
  5. 3110c vô nước lên nokia vài giây tắt
    By hoang khang in forum BB5
    Bài viết cuối: 10-01-2009, 23:39
