Kết quả 1 tới 3 của 3
    Thành viên mới quanvv's Avatar
    Mặc định Xin giúp w810i lên trắng chớp rồi treo
    Em đã chạy nhiều ver nhưng đều ko đc.Chạy xong ok nhưng bật lên trắng chớp- tắt rồi treo.
    PHONE STATE: "RETAIL"
    FLASH CID: 0049
    Speed:921600
    Flash ID check:2019
    Flash props sent ok
    OTP: LOCKED:1 CID:49 PAF:1 IMEI:35462301046588 CERT:RED
    FLASH CID:49 COLOR:RED
    Model:K700
    MAPP CXC article: R4DB005 prgCXC1250317_CHINA_HN
    MAPP CXC version: R4DB005
    Language Package:S_ASIA_LEVAN
    CDA article: CDA102555/110
    CDA version: R2A
    Default article: cxc1250324
    Default version: R4CE012
    PROVIDER: 000-00
    SIMLOCKS NOT DETECTED
    USERCODE:0000
    SEARCH:K:\hoangthong\SETOOL\SONY ERICSSION\W810\r4cf002\R4CF002_1250321_ORANGE_HN.s sw.cry
    SEARCH:K:\hoangthong\SETOOL\SONY ERICSSION\W810\r4cf002\R4CF002_apac_fs.ssw.cry
    RESTORATION FILE NOT PRESENT
    "R4DB005_CXC1250317_CHINA_HN"
    YOU MUST PERFORM FULL FLASHING
    WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
    Elapsed: 8 secs.
    Open COM port OK
    ChipID:8040,EMP protocol:0301
    FLASH CID: 0049
    Speed:921600
    PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
    LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738
    REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
    THEN PRESS "READY"
    Open COM port OK
    Trying to launch embedded bootloader...
    INT LDRB2010_RESPIN_ID_LOADER_SETOOL2
    LDRB2010_RESPIN_PRODLOADER_SETOOL2
    Flash ID check:2019
    Flash props sent ok
    FOUND VERSION "R4DB005_CXC1250317_CHINA_HN"
    can't open file "F:\Setool\Setup\v0.915028\rest\R4DB005_CXC1250317 _CHINA_HN"
    writing "K:\hoangthong\SETOOL\SONY ERICSSION\W810\r4cf002\R4CF002_1250321_ORANGE_HN.s sw.cry"
    CURRENT FLASH FILE CID:49
    SSW uses dynamic hash, dynamic hash len is:342
    Will flash 342 blocks...
    SSW loading returns:0
    writing "K:\hoangthong\SETOOL\SONY ERICSSION\W810\r4cf002\R4CF002_apac_fs.ssw.cry"
    SSW uses dynamic hash, dynamic hash len is:157
    Will flash 157 blocks...
    Setting up GDFS...
    WRITING CLEAR SIMLOCK UNITS...
    ALL UNLOCK/LOCK CODES SET TO "85231204"
    SIGNING...
    LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V26
    loader startup: executed
    loader GDFS startup: executed
    loader filesystem startup: executed
    loader unlock: executed
    writing "tpa/preset/custom/C3_PCA_G3v2.cer"
    writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm"
    writing "tpa/preset/custom/customize.xml"
    writing "tpa/preset/custom/DESKTOP_HOOK_2.itm"
    writing "tpa/preset/custom/Entrust.net Root Certificate.cer"
    writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt"
    writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm"
    writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm"
    writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm"
    writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm"
    writing "tpa/preset/custom/GAMES_HOOK_3.itm"
    writing "tpa/preset/custom/GTE_CyberTrust_Root.cer"
    writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt"
    writing "tpa/preset/custom/Root.cer"
    writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt"
    writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm"
    writing "tpa/preset/custom/ThawtePremium.der"
    writing "tpa/preset/custom/ThawteServerCA.cer"
    writing "tpa/preset/custom/Utiroot.cer"
    writing "tpa/preset/custom/VeriSignClass3Root.cer"
    writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt"
    Phone detached
    Elapsed: 618 secs.
    Open COM port OK
    FLASH CID: 0049
    Speed:921600
    Flash ID check:2019
    Flash props sent ok
    Model:K700
    MAPP CXC article: R4CF002 prgCXC1250321_ORANGE_HN
    MAPP CXC version: R4CF002
    CDA version: R2A
    PROVIDER: 000-00
    USERCODE:0000
    "R4CF002_CXC1250321_ORANGE_HN" CREATED
    Elapsed: 17 secs.
    Sau khi Repair GDFS chỉ lên logo rồi treo.Nó lại trở về ver ban đầu
    Elapsed: 17 secs.
    POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK
    DONE EXTRACTING.
    Will write GDFS now.
    Open COM port OK
    FLASH CID: 0049
    Speed:921600
    THEN PRESS "READY"
    Open COM port OK
    Flash ID check:2019
    Flash props sent ok
    FOUND VERSION "R4CF002_CXC1250321_ORANGE_HN"
    Setting up GDFS...
    format gdfs complete.
    will write 1341 units
    done
    Phone detached
    Elapsed: 70 secs.
    Open COM port OK
    FLASH CID: 0049
    Speed:921600
    Flash ID check:2019
    Flash props sent ok
    Model:W810i
    Brand:Generic
    MAPP CXC article: R4EA031 prgCXC1250316_GENERIC_HN
    MAPP CXC version: R4EA031
    Language Package:EUROPE_4
    CDA article: CDA102555/13
    CDA version: R2A
    Default version: R4ED001
    PROVIDER: 000-00
    USERCODE:0000
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    Elapsed: 3 secs.
    Mong các bác chỉ giáo.
    Thanks
    http://dananggsm.com
    V.I.P ThanhHai_GSM's Avatar
    mình gặp trường hơp này chạy mãi không đc bỏ cái thẻ nhớ ra khởi động lên bt
    => làm phần thẻ nhớ
    Trích Được post bởi ThanhHai_GSM Xem bài viết
    => làm phần thẻ nhớ
    làm thẻ nhớ hả bác?khi khởi động không có thẻ nhớ bác ah
  1. w810i bạt nguồn lên trắng rồi tắt
    By bacquan123 in forum Phần mềm Sony-Ericsson
    Bài viết cuối: 08-09-2013, 15:45
  2. w810i bạt nguồn lên trắng rồi tắt
    Bài viết cuối: 04-08-2013, 09:05
  3. Trả lời: 7
    Bài viết cuối: 20-01-2013, 14:49
  4. N72 lên trắng MH treo cần giúp
    By ATmobile_qn in forum BB5
    Bài viết cuối: 07-01-2012, 10:21
  5. Trả lời: 10
    Bài viết cuối: 13-06-2010, 17:28
