Kết quả 1 tới 10 của 11
    Thành viên chính thức tuanmobileclub's Avatar
    Mặc định anh em chỉ rúp cách sửa lỗi CONFIG KEY
    em đang có 1 con 3110c bị CONFIG KEY và PROVIDER KEY tất cả 2 cái đều báo : 00000000
    anh em nào có cách sửa lỗi này chỉ rúp em với ! thank các anh chước !
    đây là log của nó !
    JAF version 1.98.63
    Detected PKEY:
    Card life counter: 97.62%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.1.31.0
    Changing mode...Done!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 18500006ED087E56C35FE12E53A53DB97A90BC4A
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 89810089 <=> INTEL -> Type not in database
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 01.21.01 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 07.21
    05-11-08
    RM-237
    (c) Nokia.
    HW version: 2000
    PCI version:
    RFIC version:  17211721
    DSP version:
    ICPR61_08w10
    PPM version: V 07.21
    05-11-08
    RM-237
    (c) Nokia.
    S
    BT MCM version: 06cc-P9.1
    Retu version: 32
    Tahvo version: 53
    Production serial number: 7F0213742
    Product code: 0514949
    Module code: 0203291
    Basic production code: 0542523
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 359343028793512
    IMEI spare to net: 3A 95 43 03 82 97 53 01
    IMEI SV to net: 33 95 43 03 82 97 53 21 F5
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 0000000000000000
    Provider: Unknown provider
    Key Code count: 0, FBUS Code count: 0
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
    Setting local mode...
    Reading product code...
    Product Code: 0514949
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
    Checking path: \Products\RM-237\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_v
    Languages in ppm: English,Chinese T,Vietnamese
    Done!
    ™•๑๑۩۞۩๑๑♥™¤ Tuân_Mobile ¤™•๑๑۩۞۩๑๑♥™
    .________BỆNH__VIỆN__ĐIỆN__THOẠI________.
    V.I.P ThanhHai_GSM's Avatar
    bạn có mxkey buz check xong quang log lên đây sẽ có hướng cho bạn
    còn không dùng tool jaf unlock cái xem hết không
  3. ( ThanhHai_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tuanmobileclub (01-11-2010)
    em dùng jaf unlock nó mới ra : 0000000000 . chứ ban đầu nó là : FFFFFFFFFFFF . ai có cách rúp em với !
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    bạn có MX key đưa vào apdate simlock phát, cần nữa thì ripaid + sx4 nói chung ít nhất bạn cần có thiết bị như MX key hoặc Box thì chỉ có MT hoac UB thì mới làm được. tóm lại là cần có thiết bị sx4 được thì mới sữa lỗi config key 000000000 hoặc FFFFFFFFFFF
  6. ( nhanvnn ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Vi phạm nội quy tuyetnhi_2007's Avatar
    cái này dùng tool JAF unlock cho nó 1 phát là ok .
  8. #6
    bác dùng tool JAF unlock như nào vậy mà ok ? chỉ em với ! thank
  9. #7
    nói tóm lại máy của bạn bây giờ đang như thế nào (han chế điện thoại hay nghe nhac mất nguồn hoặc contacr) cho rõ bệnh cuả máy và trong tay bạn có những thiết bị phần mềm gì
    có thể bạn liên hệ chữ ký
  10. #8
    Thành viên tích cực trantukiet1008's Avatar
    Dec 2009
    Anh repair SD, Sx4 rồi Write full pm đã bỏ 308 vào là sẽ hết bệnh thôi
  11. #9
    Vi phạm nội quy tvb212's Avatar
    Dec 2009
    chủ tớt mất tích
  12. #10
    chắc là phải mang qua thợ khác có mxkey thôi ! rất cảm ơn anh em đã nhiệt tình rúp đỡ !
Hiện có 4 người đang xem bài này . Bao gồm : 0 thành viên và 4 khách
  1. xin rúp em gấp con ss s2
    By langtutimhoa_tlphaibiet in forum Samsung Android
    Bài viết cuối: 11-06-2012, 21:50
  2. chứng chỉ của mấy xin rúp
    By langtutimhoa_tlphaibiet in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 14-09-2011, 21:19
  3. xin rúp hwk không update được
    By langtutimhoa_tlphaibiet in forum HWK
    Bài viết cuối: 14-06-2011, 20:57
  4. vẫn là 3120 ! anh em xem rúp cái log
    By tuanmobileclub in forum DCT4 - WD2
    Bài viết cuối: 18-09-2010, 16:12
  5. 3600s bệnh lạ cần rúp
    By tungxuyenmobile in forum BB5
    Bài viết cuối: 02-01-2010, 22:56
