Kết quả 1 tới 10 của 12
    May 2010
    ĐIỆN BIÊN
    Mặc định 6500 s chạy pm chết nguồn
    luc đầu là máy cứ đơ liên tàng.em tính flash lại nhưng chạy bằng jaf thì log của nó đây
    JAF version 1.98.62
    Detected PKEY: 90009699
    Card life counter: 99.99%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    Booting phone...
    FAST PHONE detected!
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101003000
    Asic Mode ID: 00
    Asic EM ID: 00000B22
    Asic Public ID: 0D000201BAE17C56AEA2EF9967016ADCC5411D07
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 273F6D55DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 003F0001 <=> SPANSION -> Type not in database
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 01.21.01 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 08.30
    03-07-08
    RM-240
    (c) Nokia
    HW version: 1003
    PCI version:
    RFIC version:  17141715
    DSP version:
    ICPR71_08w22
    LCD version: SHARP
    PPM version: V 08.30
    03-07-08
    RM-240
    (c) Nokia
    V
    BT MCM version: 2222-143
    Retu version: 15
    Tahvo version: 22
    Content Pack version: Content: v
    V 08.30
    03-07-08
    RM-240
    (c) Nokia
    Production serial number: CJM098669
    Product code: 0549754
    Module code: 0203327
    Basic production code: 0543753
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 356400029833078
    IMEI spare to net: 3A 65 04 00 92 38 03 07
    IMEI SV to net: 33 65 04 00 92 38 03 57 F1
    LOCK STATUS:
    CONFIG KEY: 8000000000000002
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-240.ini
    Setting local mode...
    Reading product code...
    Product Code: 0549754
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-240\
    Checking path: \Products\RM-240\
    No ini files found...
    Done!
    Setting test mode...
    Setting FULL FACTORY...
    Done!
    Resetting LEAVE FACTORY...
    Done!
    Resetting USER DATA...
    Done!
    Resetting UPGRADE SOFTWARE...
    Done!
    Resetting PRODUCTION TUNE...
    Done!
    Phone Type:
    MCU Flash file: C:\Documents and Settings\quangtrung\My Documents\Nokia-6500S-phien-ban-08-30\Nokia6500S_cps.net.vn\rm240__08.30.mcusw
    Phone Type:
    PPM Flash file: C:\Documents and Settings\quangtrung\My Documents\Nokia-6500S-phien-ban-08-30\Nokia6500S_cps.net.vn\rm240__08.30.ppm_v
    Phone Type:
    CNT Flash file: C:\Documents and Settings\quangtrung\My Documents\Nokia-6500S-phien-ban-08-30\Nokia6500S_cps.net.vn\rm240__08.30_ism_015.imag e_v
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Flash ID: 0000FFFF <=> BAD FLASH VENDOR -> BAD FLASH TYPE
    CMT Flash Data: NOT AVAILABLE
    CMT Loader Ready
    Reading CMT NPC certificate...
    Failed to backup CRT...
    Backing up SIMLOCK data...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\356400029833078_CRT_backu p_1239911.pm
    Done!
    Backup LCK OK!
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Operation took 1 minutes 19 seconds...
    Writing...
    Stage 1
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    Sending CMT PUB KEYS...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    CMT Loader Ready
    Stage 1
    FAST MODE finish!
    Operation took 2 minutes 30 seconds...
    Reseting phone...
    PPM: C:\Documents and Settings\quangtrung\My Documents\Nokia-6500S-phien-ban-08-30\Nokia6500S_cps.net.vn\rm240__08.30.ppm_v
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Operation took 0 minutes 25 seconds...
    Writing...
    Stage 1
    Operation took 0 minutes 46 seconds...
    Reseting phone...
    CNT: C:\Documents and Settings\quangtrung\My Documents\Nokia-6500S-phien-ban-08-30\Nokia6500S_cps.net.vn\rm240__08.30_ism_015.imag e_v
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Operation took 2 minutes 40 seconds...
    Writing...
    Stage 1
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Stage 1
    FAST MODE finished!
    Operation took 1 minutes 44 seconds...
    Reseting phone...
    Done!
    Total time: 9 Minutes, 38 Seconds
    DCT4/BB5 counter: 1
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    xong em cho qua hwk chạy lại thì báo là rx pin2 not connected gì đó em ween kô giữ lại log của nó.bjo cho vào check lại thì ko check đc.các sư huynh giúp em vụ này với
    V.I.P ThanhHai_GSM's Avatar
    nếu bằng HWK chọn model trước xong ấn check
    tiếp tục lấy ver cao hơn chạy lại bằng hwk hoăc diae USB đi bạn
    May 2010
    ĐIỆN BIÊN
    thì minh vãn chọn vậy mà nhưng mà ko đc.toàn báo là eror thôi à.cả jaf đều kko đc.bjo là máy bật hiện lên nokia rồi tắt.và ko có cách nào check nổi cả dea usb nữa cũng ko đc
    dùng navifirm load bộ file và ver cao hơn chạy bằng phoenix là ok
    ĐÔ LƯƠNG _ NGHỆ AN
    con này bạn kiếm ver cao hơn đi do ver thôi
    May 2010
    ĐIỆN BIÊN
    bjo chech bằng jaf nó ra thế này đây các a
    JAF version 1.98.62
    Detected PKEY: 9000BC25
    USB Cable Driver version: 7.1.29.0
    Booting phone...
    Error sync the phone...
    May 2010
    ĐIỆN BIÊN
    vấn đề là ko chcek đc thì làm sao mà flash đc các bác.mà em ko biết navifirm là gì bác noi cụ thể hơn đc kô ah.các bác có cho em luôn nha
    Trích Được post bởi trung07mobile Xem bài viết
    navifirm là chương trình hỗ trợ dowload 3 file nokia rất tiện ích khi bạn chạy bằng phoenix không cần phải cài bản setup
    trước khi mở navifirm bạn cài netframework: 822156-netframework20(1).exe - 4shared.com - chia sẻ và lưu trữ - tải xuống tập tin trực tuyến
    còn đây là em nó: navifirm_V0.4.exe - 4shared.com - chia sẻ và lưu trữ - tải xuống tập tin trực tuyến
    Dec 2009
    GIALAI
    anh flash bằng chế dộ dead usb xem sao
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Thành viên tích cực VƯƠNGANH-HẢI PHÒNG's Avatar
    Sep 2010
    phoenix free
    bác có phoenix thi vào Skype: vuongncchp em send cho file full chạy là ok
    Ở ẨN
  1. 6500 đang chạy phần mèm thì báo lỗi
    By lethanhtam92 in forum BB5
    Bài viết cuối: 05-06-2012, 08:10
  2. Trả lời: 3
    Bài viết cuối: 06-12-2010, 09:34
  3. Trả lời: 9
    Bài viết cuối: 29-06-2010, 17:59
  4. 6500 S rớt nước , chạm
    By ANHTEO in forum BB5
    Bài viết cuối: 27-05-2009, 08:40
