em nhận con 2610 mất nguồn.chậy pm ok mà hok lên.em đóng con cpu lại thì contac sevic,ae xem hộ cái log check bằng mx-key.thanks
Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010)
ASIC ID: 0x3040 [UPP_4M ver: 4.1]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
UEM ID: 00D80E61A3BDA66
ASIC type: 11
UEM Imei: 35275101865362
Phone Type: RH-86 (Nokia 2610)
SW Version: V 07.11 05-11-08 RH-86 (c) Nokia.
Imei plain: 35275101865362-8
Product Code: 0537020
Cellular System: GSM
ASIC ID: 0x3040, type: 11
Ppm Id: V
Language Pack:
- not available.
Imei net: 35275101865362
Version: SIMLOCK SERVER VERSION 63
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000001000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
			 2610 contac sevic
 2610 contac sevic
			 DTDD :0922972486
 DTDD :0922972486
 yahoo nguyenquang_201086
