Kết quả 1 tới 4 của 4
    Thành viên tích cực huuthien's Avatar
    Mặc định w580 mất nguồn cần giúp đỡ
    máy mở nguồn lên thì chỉ có rung một cái thôi không thấy lên đèn hay màn hình gì cả em đã chạy lại chương trình cho nó rồi mà vẫn không hết em post log lên đây các pro xem giúp em nó bị gì
    UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
    UFS_USB V2.8 (c) SarasSoft 2007., S/n: 63580
    HID: 0479E766416000B7
    HWK: A1.04-PRO1
    Licence: True, 00:18
    MCU_ID : 99000301FFFFFFFF
    S_BAUD : 921600
    P_LOAD : 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M
    FLSH_ID: 897E [Intel SIBLEY]
    M_CERT : 52 RED
    IMEI : 351649-03-692602-0
    CD_PAF : 1 0 1
    OTPCID : 51 RED
    CID_UP : 5152
    CXC_NR : cxc1123364 R8BE001
    CDA_NR : CDA102568/1 R2A
    CIDUP Canceled
    P_LOAD : 061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
    P_LOAD : 070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
    Country: APAC
    JAVA : Profile/MIDP-2.0 Configuration/CLDC-1.1
    Modem : Sony Ericsson IrDA Modem 089,Sony Ericsson Device
    ITP_SW : CXC 112 3323 R1G
    KRH_Inf: CB5A149C3V
    ERR_Log: 1E0W
    SHUT DOWN CS ...
    Log File: DBX_REPORT_LOG.log, created
    S_BAUD : 921600
    M_CERT : 52 RED
    CD_PAF : 1 0 1
    OTPCID : 51 RED
    CID_UP : 5152
    FINISH CS ...
    Upgrade to CID 53 Done, 00:15
    S_BAUD : 921600
    M_CERT : 52 RED
    CD_PAF : 1 0 1
    OTPCID : 51 RED
    CID_UP : 5152
    IMAGE : W580_R8BE001_MAIN_CHINA_LA_RED53.bin
    Certificate Warning, SSW_CID Mismatch: 53<>52
    Certificate Error F.2: -10
    FlashImage Certificate Rejected
    Flashing Failed, 00:01
    SHUT DOWN FL ...
    S_BAUD : 921600
    M_CERT : 52 RED
    CD_PAF : 1 0 1
    OTPCID : 51 RED
    CID_UP : 5152
    IMAGE : W850_R1KG001_MAIN_CHINA_CY_RED52.bin
    WRITTEN: 460 Block(s), 08:19
    IMAGE : W850_R1KG001_FS_APAC_RED52.bin
    WRITTEN: 257 Block(s), 04:44
    IMAGE : W580i_CDA102774-182_R2A_Singapore_Starhub_APAC.bib
    Write/Create: tpa/
    Write/Create: tpa/preset/
    Write/Create: tpa/preset/custom/
    Write/Create: tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm
    Write/Create: tpa/preset/custom/Customize.xml
    Write/Create: tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    Write/Create: tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    Write/Create: tpa/preset/custom/FM_THEMES_HOOK_3.itm
    Write/Create: tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    Write/Create: tpa/preset/custom/GAMES_HOOK_3.itm
    Write/Create: tpa/preset/custom/MEDIA_PLAYER_HOOK_3.itm
    Write/Create: tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm
    Write/Create: tpa/preset/custom/preloaded_config.xml
    Write/Create: tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm
    Write/Create: tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm
    Write/Create: tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm
    Write/Create: tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm
    WRITTEN: 17 File/Folder(s), 00:06
    Flashing Done, 13:44
    SHUT DOWN CS ...
    S_BAUD : 921600
    M_CERT : 52 RED
    CD_PAF : 1 0 1
    OTPCID : 51 RED
    CID_UP : 5152
    U_LOCK Set to: 0000
    SHUT DOWN CS ...
    V.I.P Lão_Đại's Avatar
    hải phòng
    có SETOOL quất lại cho em nó 1 phát , con này chạy = HWK thì chuối lắm
    còn cách nào trị bằng hwk không anh em không có seetool anh ơi
    korea
    tets thử đây nguồn đi bạn .
    hãy nhấn nút THANKS khi bài viết hữu ích cho bạn . thank all
  1. giúp em W580 này với
    By TLmobi in forum SONY-ERICSSON Models củ
    Bài viết cuối: 28-07-2011, 10:25
  2. w580 cần giúp
    By Apple179 in forum Các loại models mới Sony-Ericsson
    Bài viết cuối: 12-01-2011, 11:24
  3. Trả lời: 2
    Bài viết cuối: 12-12-2009, 10:03
  4. giúp em con w580 với. đang sài mất nguồn
    By duchoang in forum Các loại models mới Sony-Ericsson
    Bài viết cuối: 06-11-2009, 22:54
  5. W580 mở nguồn đèn đỏ nhấp nháy ,cứu cứu
    By tranloctran in forum Các loại models mới Sony-Ericsson
    Bài viết cuối: 23-06-2008, 10:07
