Number of Image Files: 3
Processing Image File :
rm123_145_30005.600.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 51000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 944
Entry Point: 0x44FC
Page Format : -1
MAX PAGE : 0x00004000
rm123_145_3005.60.ppm_v
CMT Type : BB5
Number of Blocks : 178
Entry Point: 0x00A6
Page Format : -1
rm123_145_30005.60.image_v
CMT Type : BB5
Secondary Sending Speed : 3250000Hz
Number of Blocks : 208
Entry Point: 0x00B2
Page Format : 0
AUTO SELECTED DEAD USB FLASHING...
If Flashing DOES NOT Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
BootRom Verified!
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 010C1921
ID DWORD 4 : 01003000
cmt hardware : 01003000
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00000232
3 ROM_ID 15
ID DWORD 0 : 00000353
4 PUBLIC_ID 12
ID DWORD 0 : 1FF00006
ID DWORD 1 : 99CB0154
ID DWORD 2 : 2BB57273
ID DWORD 3 : FD17940F
ID DWORD 4 : 2596F548
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
START FLASHING
RawLoaderExtract: Processing rm123_145_30005.600.mcusw
RawLoaderExtract: Image matches with RootKey Hash, Extraction is done
Parsed OK
RAW LOADER SENT..
UpdateAgentDataExtract: Processing rm123_145_30005.600.mcusw
UpdateAgentDataExtract: Found matching Rootkey Hash CERT Block
UpdateAgentDataExtract: Found DATA Block
UpdateAgentDataExtract: Consolidating DATA Blocks
PASUBTOCCertExtract: Processing rm123_145_30005.600.mcusw
PASUBTOCCertExtract: Found matching Rootkey Hash CERT Block
00000400
Update Agent Sent..
Waiting for phone to ADL ... (Make take a while)
Found Nokia BB5 ADL Loader USB Generic..
EraseFile: Processing rm123_145_30005.600.mcusw
Erasing area 0x00000000 - 0x000006BF, Type: NOR, Subsystem: CMT
Erasing area 0x000006C0 - 0x0000FFFF, Type: NOR, Subsystem: CMT
Erasing area 0x00010000 - 0x0007FFFF, Type: NOR, Subsystem: CMT
Erasing area 0x000A0000 - 0x0021FFFF, Type: NOR, Subsystem: CMT
Erasing area 0x00220000 - 0x011DDFFF, Type: NOR, Subsystem: CMT
Erasing area 0x011DE000 - 0x011DEFFF, Type: NOR, Subsystem: CMT
Erasing area 0x011DF000 - 0x011DFFFF, Type: NOR, Subsystem: CMT
Processing : rm123_145_30005.600.mcusw
Total blocks to write : 1062
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : PMM_CONF
>> CMT Rootkey Hash CERT : SBIF_CONF
Continue Flash Complete : : No Error - 0 (0x00)
EraseFile: Processing rm123_145_3005.60.ppm_v
Erasing area 0x011E0000 - 0x016DFFFF, Type: NOR, Subsystem: CMT
Processing : rm123_145_3005.60.ppm_v
Total blocks to write : 310
EraseFile: Processing rm123_145_30005.60.image_v
Erasing area 0x016E0000 - 0x01E7FFFF, Type: NOR, Subsystem: CMT
Erasing area 0x01E80000 - 0x01FDFFFF, Type: NOR, Subsystem: CMT
Converting to 128K format....
Converting image to 128k bit.....
Converted file created : rm123_145_30005.60.image_v_128k
Processing : rm123_145_30005.60.image_v_128k
Total blocks to write : 208
Flashing Done..
Total Flashing Time (Erase + Flashing) : 00:04:55
(Booting time is NOT Included)
Waiting for Phone to Start-Up...(Max 100 seconds)
If Windows is Installing Drivers...
Phone Polling MIGHT Exit Automatically.
Elapsed Time: 5 Seconds...
V 05.60 14-09-07 RM-145 (c) Nokia
SW: V 05.60 14-09-07 RM-145 (c) Nokia
IMEI: 356283014087292
CONFIG KEY: 8000000000000002
PROVIDER KEY: 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : 0/3 , 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status : Not Locked
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SUPER_DONGLE_TEST : PASSED
SECURITY_CODE : 12345
SL1/SL2 Phone detected
FACTORY SET TO : Factory Set Full
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Production Tune
OK
FACTORY SET TO : Production Tuning
OK
FACTORY SET TO : Reset User Code
OK
FACTORY SET TO : Service Centre
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : User Data
OK
			 flash 6233 RM145 = usb ok by ATF
