    Thành viên tích cực gsmqk2's Avatar
    Mặc định 3500c chạy phần mềm lỗi không len nguồn!!!
    Máy tình trạng ban đầu bị chập TAHVO, mình thay TAHVO khác vào thì hết chập nhưng ko lên nguồn. Chạy lại bằng HWK nhưng ko UIsetting được. đem qua JAF chạy cũng không được mong anh em chỉ giúp.
    Log Check:
    1ST BOOT : C0,07 [Rm-272] [2.1.0.1]
    RAPx ID : 000000010000022600010006010C192101001101
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx PBID : 225002140DE96E567958952F193A3A6D3518E4F7
    RAPx MODE : 00
    RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
    RAPx ROID : 191EC665DFAAF68F
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
    CMT FLID0 : 00EC2208-00006921, Sam K8F5615ETM
    CMT FLCNT : 00000000000000000000000000000000000000
    CMT MCID0 : FFFF0000-00000000
    CMT 2ND Boot OK
    CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
    CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    INFO_2ND : APE Chip Absent
    INFO_ALG : APE Chip Absent
    PASUBTOC : PA_SL
    Đây là Log chạy:
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx MODE : 00
    CMT 1ST Boot OK
    CMT 2ND Boot OK
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    PASUBTOC : PA_SL
    Rebooting Mobile
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx MODE : 00
    CMT 1ST Boot OK
    CMT 2ND Boot OK
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    IMAGE : rm272__07.21.mcusw
    CMT NOR Erase Area: 0x00000000-000006BF
    CMT NOR Erase Area: 0x000006C0-0001FFFF
    CMT NOR Erase Area: 0x00020000-0007FFFF
    CMT NOR Erase Area: 0x00080000-000DFFFF
    CMT NOR Erase Area: 0x00100000-001FFFFF
    CMT NOR Erase Area: 0x00200000-0031FFFF
    CMT NOR Erase Area: 0x00320000-0105FFFF
    CMT NOR Erase Area: 0x01060000-01067FFF
    CMT NOR Erase Area: 0x01068000-0107FFFF
    CMT FLASH ERASE OK, Time: 00:42
    Written: 10 Certificate(s)
    CMT FLASH WRITE OK, Time: 01:30
    Chip SECTOR_SIZE: 128k
    Warning, Must be Used 128Kb Sector_Size CNT File
    CONVERSION: Already 128K Paged Source
    IMAGE : rm272__07.21.image_v_128
    CMT NOR Erase Area: 0x01520000-01FDFFFF
    CNT FLASH ERASE OK, Time: 00:26
    CNT FLASH WRITE OK, Time: 00:44
    IMAGE : rm272__07.21.ppm_v
    CMT NOR Erase Area: 0x01080000-0151FFFF
    PPM FLASH ERASE OK, Time: 00:13
    PPM FLASH WRITE OK, Time: 00:27
    Flashing Completed, Rebooting Mobile
    UI Defaults Failed
    Anh em chỉ giúp mình nhé!!!
    Log Check:
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx MODE : 00
    CMT 1ST Boot OK
    CMT 2ND Boot OK
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    PASUBTOC : PA_SL
    Đây là Log chạy:
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx MODE : 00
    CMT 1ST Boot OK
    CMT 2ND Boot OK
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    PASUBTOC : PA_SL
    Rebooting Mobile
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx MODE : 00
    CMT 1ST Boot OK
    CMT 2ND Boot OK
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    UI Defaults Failed
    V.I.P ThanhHai_GSM's Avatar
    nếu chập TAHVO chỉ cần thay ic chuẩn là lên cần gì chạy lại
    bây giờ tiếp tục thay TAHVO chuẩn xong chạy
    Lúc đầu mình thay thì lên rồi tự tắt. sau đó thay cả mấy con vẫn thế, thay luôn RETU cũng ko hết mới chạy. giờ chạy lỗi như vậy chưa tìm ra nguyên nhân. Xin anh em chỉ giúp!!
    Thành viên kỳ cựu setot_thoi's Avatar
    Sóc Trăng
    Trích Được post bởi gsmqk2 Xem bài viết
    bạn đem qua Mxkey múc xem tình hình thế nào . chứ ngồi đó múc JAF và HWK củng vậy
    MẩnMobile .Y/H : Jimmyphong10
    bình phước
    up log hwk luôn xem . mình chỉ nhìn wen HWK thui jaf thì củng có lúc up log HWK xem mình có jup dc j ko nhé
    Thành viên tích cực baohantg's Avatar
    Oct 2009
    Trích Được post bởi ThanhHai_GSM Xem bài viết
    mấy máy 3110,6300,6233.3500....hai con nguồn chỉ cần thay con chuẩn vào là lên nguồn thôi không cần chạy luôn...
    CÁC BẠN LÀ ĐỒNG NGHIỆP VÀ CỦNG LÀ THẦY CỦA TÔI. XIN CẢM ƠN TẤT CẢ .
  1. thay ic nguồn Qmobile có phải chạy lại phần mềm ko?
    By gamoi.gsm in forum Sửa chữa phần cứng
    Bài viết cuối: 23-10-2011, 07:35
  2. 3500c chaỵ phần mềm báo err
    By GSMDANANG in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 04-06-2009, 14:12
  3. 3500C mất phản quang....
    By quanghau_mobile in forum BB5
    Bài viết cuối: 23-04-2009, 19:13
  4. 3500C mất phản quang....
    By qlmobile in forum BB5
    Bài viết cuối: 05-04-2009, 22:05
  5. Trả lời: 12
    Bài viết cuối: 28-12-2008, 17:55
