e nó bị mất nguồn cho vào box thì check dc nhung ko info dc. day là log của nó. aexem giúp e với.
đây là log e check bằng jap
Getting MCU ID
MCU ID: 0x2293
FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AC 7A 10 00 02 00 01 00 44 04 44 01 00 02 60 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
còn đây là mx-key
Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
ExtBUSC: 0D2E A210 2110 0040 C600 2001 2002 4414
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 004F1FE3A3BDA66
ASIC type: 11
UEM Imei: 35932903179901
Phone not responding !
			 1202 cần ae giúp
 1202 cần ae giúp
			 Được post bởi chuonggc
