Kết quả 1 tới 10 của 16
    Thành viên tích cực ngocminhhungyen's Avatar
    jhhj
    Mặc định 1202 rơi vỡ màn
    ace xem hộ cái log,máy bik rơi vỡ màn,mik thay màn nhưng k dc,bỏ vào chk>inf>nạp pm>ok mà vẫn k mở dc nguồn
    Getting MCU ID
    MCU ID: 0x2293
    First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 04.03
    29-06-09
    RH-112
    (c) Nokia
    HW version: 1003
    PCI version:
    UEM version: 1328
    UPP version: 8851
    RFIC version: 0700
    DSP version: ICPR81_09w22_U
    LCD version: UNKWN: IDs:
    00:ff:00
    PPM version: V 04.03
    29-06-09
    RH-112
    (c) Nokia
    MR
    ADSP SW version: V 04.03\n29-06-09\nRH-112\n(c) NMP\nmr
    Production serial number: DRS816037
    Product code: 0562324
    Module code: 0204036
    Basic production code: 0558505
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 359329033590654
    IMEI spare to net: 3A 95 23 09 33 95 60 05
    IMEI SV to net: 33 95 23 09 33 95 60 15 F9
    Master Code: 2526117552
    Phone type: RH-112, Software version: 04.03, Language Pack: MR
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
    Setting local mode...
    Reading product code...
    Product Code: 0562324
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
    Checking path: \Products\RH-112\
    No ini files found...
    Done!
    Reading...
    29-06-09
    RH-112
    (c) Nokia
    HW version: 1003
    PCI version:
    UEM version: 1328
    UPP version: 8851
    RFIC version: 0700
    00:ff:00
    29-06-09
    RH-112
    (c) Nokia
    MR
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_004.030
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_004.03mr
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai04.03mr
    Done!
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_004.030
    Booting phone...
    MCU ID: 0x2293
    Loader version: 04.4F.00 -> Revision: 0007
    Boot size is 0x09D8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4C68; Loader chk: ff
    Loader is ready...
    MSID: 84AB62FCCBF049FDAF05652FE2
    MSID decoded: 3E4EBAE900244DA5A9000000
    FAID: 4C2B48D5C9308C2BF879D93C
    Operation took 0 minutes 13 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 15 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 15 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_004.03mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    MSID: 849E349B2864EC236BA44A8A24
    MSID decoded: 3E4EBAE900244DA5A8000000
    FAID: 4E868CCA0204737E45C9ACE7
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 24 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai04.03mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 41 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    IMEI: 359329033590654
    Resetting PPC...
    Done!
    Repair - Unlock - Nạp tiếng việt - Chuyển hệ cho tất cả các loại ĐTDĐ
    Thành viên chính thức manhhai_au's Avatar
    Bạn thay màn hình chưa được,nó báo chưa nhận biết được LCD.kiểm tra lại xem.không được thì cho Upp nưa viên thuốc lắc.
    Học hành là việc lớn.Yêu đương là việc nhỏ.Việc nhỏ không làm được sao làm được việc lớn
    Thành viên mới kechien's Avatar
    Aug 2010
    log báo hỏng flash pạn thử làm chan lại xem sao?? rồi tính tiếp
    Thành viên tích cực hoangmobilephone's Avatar
    Vinh Yen
    test các chân main hàn vào màn hình . đứt chân nào câu chân đó
    Vi phạm nội quy lamvtmobile's Avatar
    Máy có dao động không bạn
    Thành viên tích cực Tài mobile Độc®'s Avatar
    Oct 2010
    Trích Được post bởi ngocminhhungyen Xem bài viết
    Getting MCU ID
    MCU ID: 0x2293
    Algo is ready...
    Done!
    Phone Restarted...
    Reading...
    29-06-09
    RH-112
    (c) Nokia
    HW version: 1003
    PCI version:
    UEM version: 1328
    UPP version: 8851
    RFIC version: 0700
    00:ff:00
    29-06-09
    RH-112
    (c) Nokia
    MR
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done!
    Reading...
    29-06-09
    RH-112
    (c) Nokia
    HW version: 1003
    PCI version:
    UEM version: 1328
    UPP version: 8851
    RFIC version: 0700
    00:ff:00
    29-06-09
    RH-112
    (c) Nokia
    MR
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done!
    Reading IMEI...
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Writing...
    Restarting MCU...
    Flashing Done!
    Reading...
    Resetting PPC...
    Done!
    LCD version: UNKWN: IDs:xem lại màn hình đi
    Thành viên tích cực nguyenvumobile's Avatar
    chạy ok rồi kiễm tra lại mh và đường dẫn mh đi
    :D
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    không lên do cái màn hình đó bạn check lại coi đo đạc coi đứt đường nào không đứt thì câu lại vì máy đập nên có nhiều hơn nữa khả năng
    Trích Được post bởi kechien Xem bài viết
    Hỏng mà Write Flash done!
    Thành viên chính thức ledangkhanh38's Avatar
    Oct 2010
    bạn kiểm tra lại đường phím bấm nguồn đi không có mh thì khi mở nguồn vẫn phải có nhịp chứ.
    0916722722 tân phú_tân kỳ_nghệ an
    By LEGIAM_GSM in forum DCT4 - WD2
    Bài viết cuối: 23-09-2012, 09:55
  2. 1202 mất mic
    By cuocsongmoi_hotbyos9x in forum DCT4 - WD2
    Bài viết cuối: 16-10-2010, 15:30
  3. 1202 không đồng bộ được
    By q79 in forum DCT4 - WD2
    Bài viết cuối: 12-10-2010, 18:19
  4. Trả lời: 0
    Bài viết cuối: 19-07-2010, 08:52
  5. Trả lời: 6
    Bài viết cuối: 15-02-2010, 09:38
