    Thành viên mới kechien's Avatar
    Aug 2010
    Mặc định 6030 không lên nguồn?xjn giúp
    em có cây 6030 ko nên nguồn mong ae4r giúp đỡ em dã thử chạy phần mềm nhưng ko dươc khi dang chạy thì nó như vầy//.
    MCU ID: 0x2031
    FLASH ID0: 2C7E0001 <=> SPANSION -> 72NS128N Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    First 16 bytes: 24 22 B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Setting local mode...
    Failed! Aborting!
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-74\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.300
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.30l
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.30.image_ctv_za
    Languages in ppm: English,French,Afrikaans,Swahili,Zulu,Sesotho,Xhos a
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.30v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.30.image_v
    Languages in ppm: English,Vietnamese,Chinese S,Chinese T
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.300
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x7E2C0100
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 10
    Loader is ready...
    MSID: 84A6A4C0DF7D99B71106DBDBBC
    MSID decoded: 5E42BAE900CA3975AA000000
    FAID: 648B1AF850D3B4B696935334
    Erasing...
    Found 3 interval(s) to erase
    Erasing area: 01020000 - 017BFFFF...
    Erasing area: 01F20000 - 01FDFFFF...
    Operation took 1 minutes 8 seconds...
    Writing...
    Error cmd: 14!
    Addr: 01040000
    em mói vô nghè nên ko pít tại sao mong cao thủ chỉ giáo em thank các pác nhìu
    V.I.P ThanhHai_GSM's Avatar
    qua hwk + đổi ver khác xem bạn không đc thì làm lại cpu xong chạy lại
    Thành viên chính thức cuahang_minhchien's Avatar
    Nov 2010
    làm chan cpu rồi nạp là luọm lúa thôi!!
    Moderator Apple179's Avatar
    Sep 2010
    bạn lấy sọi cáp khác chạy...và bỏ đánh dấu 208 đi là ok ah...
    Đất Hà Thành!
    flash ver khác>>not mang qua box khác>>làm lại flash>>làm lại cpu rùi chạy lại là ok!
    Thành viên chính thức bacson_langson's Avatar
    Oct 2010
    Error cmd: 14! coi lại flash bạn nhé
    TpHCM
    đem qua box khác thử đi bạn k đc thì cho flash tí lửa đi
    Aug 2010
    em da lam lai upp nhưng vẫn ko dươc mong các pác chỉ giáo
    chú ý! tiếng việt có dấu đầy đủ nhé!
  1. Trả lời: 12
    Bài viết cuối: 10-03-2012, 15:06
  2. 6030 kẹp nguồn lên bỏ pin vào ko lên
    By nhoemvocung2 in forum DCT4 - WD2
    Bài viết cuối: 19-08-2010, 14:00
  3. 6030 tự động lên nguồn cần giúp đỡ
    By duong bin bin in forum DCT4 - WD2
    Bài viết cuối: 02-02-2010, 20:56
  4. 6030 kẹp nguồn lên cho pin k lên
    By giaphu_dn in forum DCT4 - WD2
    Bài viết cuối: 01-07-2008, 21:41
  5. 6030 kẹp nguồn lên cho pin k lên
    Bài viết cuối: 01-07-2008, 21:26
