    Thành viên mới dk hoaiminh's Avatar
    Mặc định K800i chớp tắt cần giúp đở
    Em có cây k800i (cid 53) nạp Tiếng việt. Em nạp 2 file R8BF003_1250214_CHINA_WI.sswR8BF003_FS_APAC_WI_RED_CID53.ssw. Log flash Ok hết nhưng khi Identify thì Model lại là K700 và kết quả là máy chớp tắt mãi, ko lên nguồn được. Mong a/e trong 4r cho em ý kiến. Cám ơn a/e đã quan tâm.
    Đây là Log Flash:
    Code:
    RUNNING v 1.01/UNI
    CARD SERIAL 00143298
    CFG:000000000000
    ChipID:9900,EMP protocol:0301
    Speed:115200
    FLASH ID: 897E
    OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908801827060 CERT:N/A
    FLASH CID:53 COLOR:RED
    Model (from GDFS):K700
    MAPP CXC article: R8BF003     prgCXC1250214_CHINA_WI
    MAPP CXC version: R8BF003
    Language Package: APAC
    CDA article: CDA102568/101
    CDA version: R8A
    Default article: cxc1250490
    Default version: R8BF003
    PROVIDER: 000-00
    SIMLOCKS NOT DETECTED
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    Elapsed: 22 secs.
    SIGNED MODE (USING SERVER)
    CFG:100100000000
    Speed:115200
    PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0
    LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
    FLASH ID: 897E
    writing "E:\File Flash\Setool\SONY ERICSSION\K800\cid53\r8bf003\R8BF003_1250214_CHINA_WI.ssw"
    CURRENT FLASH FILE CID:53
    SSW uses full hash, hash len is: 9200
    Will flash 460 blocks...
    writing "E:\File Flash\Setool\SONY ERICSSION\K800\cid53\r8bf003\R8BF003_FS_APAC_WI_RED_CID53.ssw"
    SSW uses full hash, hash len is: 4980
    Will flash 249 blocks...
    LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
    loader GDFS startup executed
    loader FILESYSTEM startup executed
    using GENERIC phone customization
    tpa/preset/custom/C3_PCA_G3v2.cer
    tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
    tpa/preset/custom/customize.xml
    tpa/preset/custom/DESKTOP_HOOK_2.itm
    tpa/preset/custom/Entrust.net Root Certificate.cer
    tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
    tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    tpa/preset/custom/FM_THEMES_HOOK_3.itm
    tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    tpa/preset/custom/GAMES_HOOK_3.itm
    tpa/preset/custom/GTE_CyberTrust_Root.cer
    tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
    tpa/preset/custom/Root.cer
    tpa/preset/custom/SEMC_E2E_Root_CA.crt
    tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
    tpa/preset/custom/ThawtePremium.der
    tpa/preset/custom/ThawteServerCA.cer
    tpa/preset/custom/Utiroot.cer
    tpa/preset/custom/VeriSignClass3Root.cer
    tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
    Phone detached
    Elapsed: 4498 secs.
    CFG:100100000000
    Unknown ChipID (C692),RETRY
    FAILED TO SETUP PHONE
    Elapsed: 12 secs.
    CFG:100100000000
    Speed:115200
    FLASH ID: 897E
    CDA version: R8A
    PROVIDER: 000-00
    Elapsed: 18 secs.
    Up phát cho ae quan tâm đây
    Thành viên danh dự TuấnPhát_GSM's Avatar
    Jan 2009
    Hi anh!
    Anh xem lại Log đi anh
    Sau khi anh Flash nó thành K700 rồi anh
    Code:
    CFG:100100000000
    Elapsed: 12 secs.
    CFG:100100000000
    Speed:115200
    FLASH ID: 897E
    CDA version: R8A
    PROVIDER: 000-00
    Elapsed: 18 secs.
    Dec 2009
    GIALAI
    tìm file khác flash lại đi anh
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Jan 2009
    Trích Được post bởi HTFONE_KRONGPA Xem bài viết
    K800 thành K700 ko Repair, Flash ko hết đâu anh
    Jan 2009
    Hướng giải quyết:
    1. Qua Tab emptyboard.
    2. Bên Seting chọn "signed mod"
    3. Click "recovery"
    4. Sau khi "recovery" hoàn tất.
    5. Qua seting ko chọn gì hết.
    6. Write gdfs K800 vào.
    7. Nạp lại File Erom (EROM CID >= OTP CID).
    8. Rồi nhấn Flash.
    K800 nếu lên trắng màn hình & Identify ra K700 thì nhiều khả năng do mà hình anh.
    V.I.P DinhKha™'s Avatar
    Kiên Giang
    Code:
    RUNNING v 1.01/UNI
    CFG:000000000000
    Speed:115200
    FLASH ID: 897E
    CDA version: R8A
    PROVIDER: 000-00
    Elapsed: 22 secs.
    CFG:100100000000
    Speed:115200
    FLASH ID: 897E
    Phone detached
    Elapsed: 4498 secs.
    CFG:100100000000
    Elapsed: 12 secs.
    CFG:100100000000
    Speed:115200
    FLASH ID: 897E
    CDA version: R8A
    PROVIDER: 000-00
    Elapsed: 18 secs.
    Bạn chọn đúng file, log Flash Ok và khi Indentify seach ra model K700. Đồng nghĩa, màn hình của bạn đã bị hư. Vì vậy,bạn thay màn hình khác vào sẽ Ok đấy và cả khi Indentify cũng sẽ thay đổi Model luôn á.
    Tested By Me.
    Thành viên chính thức hungphutho's Avatar
    phú thọ
    con đó recovery cho về cid49 va unlock sau đó viết file eprom để nâng thánh cid52 rùi chay full flash lại là ok ngay thôi
    http://daivietpda.com
    Forum dành cho mobile by HUNGPHUTHO
  1. k800i cần anh em giúp
    By nhathuy_mobile2009 in forum Sửa chữa phần cứng
    Bài viết cuối: 27-10-2012, 22:14
  2. cứu em k800i giúp mình vs!!!
    By dragonfire95hp in forum Các loại models mới Sony-Ericsson
    Bài viết cuối: 21-05-2012, 12:51
  3. k800i xin giúp
    By LongBiênMobile in forum Phần mềm Sony-Ericsson
    Bài viết cuối: 07-11-2009, 13:31
  4. cần pro trợ giúp tớ vấn đề về k800i
    By minhtienk800i in forum Ứng dụng dành cho Sony-Ericsson
    Bài viết cuối: 02-04-2009, 19:33
  5. K800i cid 51, treo máy cần giúp đỡ!
    By khoibt in forum SETOOL
    Bài viết cuối: 29-09-2007, 16:17
