Kết quả 1 tới 10 của 20
    May 2010
    Mặc định 2700c lên nokia rồi tắt
    em đã chạy lại phần mêm băng hwk báo ok nhưng vẫn vậy, em dung mx key check thì báo như sau; Using device: UFS_USB V2.8 (c) SarasSoft 2007.
    Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 1670020F6F538E567813D2B675399CCF9610C6BB
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    ID 32: 000200800000
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    No RAP Flash Chip Detected
    Original Imei: 35270304548685
    Original Product code: 0579808
    Bluetooth ID: A04E042F5B84
    Phone not responding !
    xin xem giúp em với
    DIA_NGUC_MA
    0984745666
    May 2010
    đây là log em flat băng hwk . xin xem giúp. 1ST BOOT : C0,07 [Rm-561] [2.1.0.0]
    RAPx ID : 000000010000022600010006030C192101033000
    EM 1 ID : 00000296
    EM 2 ID : 00000B22
    RAPx PBID : 1670020F6F538E567813D2B675399CCF9610C6BB
    RAPx MODE : 00
    RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
    RAPx ROID : 273F6D55DFAAF68F
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
    CMT UNKID : 32 02008000004400
    CMT 2ND Boot OK
    CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
    CMT KSIG0 : 3EA22A1DDA660002E56108DB5072A10F8709443F
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    IMAGE : rm561__09.97.mcusw
    CMT NOR Erase Area: 0x00000000-000006BF
    CMT NOR Erase Area: 0x000006C0-0001FFFF
    CMT NOR Erase Area: 0x00040000-000BFFFF
    CMT NOR Erase Area: 0x000C0000-0013FFFF
    CMT NOR Erase Area: 0x00140000-0137FFFF
    CMT NOR Erase Area: 0x01380000-0151FFFF
    CMT FLASH ERASE OK, Time: 01:19
    Written: 8 Certificate(s)
    CMT FLASH WRITE OK, Time: 01:58
    Chip SECTOR_SIZE: 128k
    Warning, Must be Used 128Kb Sector_Size CNT File
    CONVERSION: Already 128K Paged Source
    IMAGE : rm561__09.97.image_v_red
    CMT NOR Erase Area: 0x01DC0000-0215FFFF
    CMT NOR Erase Area: 0x02160000-03FBFFFF
    CNT FLASH ERASE OK, Time: 01:21
    CNT FLASH WRITE OK, Time: 01:25
    IMAGE : rm561__09.97.ppm_v
    CMT NOR Erase Area: 0x01520000-01DBFFFF
    PPM FLASH ERASE OK, Time: 00:28
    PPM FLASH WRITE OK, Time: 00:41
    Flashing Completed, Rebooting Mobile
    DIA_NGUC_MA
    0984745666
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    nếu chạy ok
    info và đồng bộ lại cũng ok
    mà vẫn như củ thì xem lại phần nguồn anh nhé.
    May 2010
    ĐIỆN BIÊN
    lỗi này là chưa đồng bộ đc.thử cáp khác>>>>>>>>>chạy ver cao nhất>>>>>>>>đồng bộ lại luôn
    TRUNG HIẾU MOBILE
    May 2010
    em flat băng mx key đây; Using device: UFS_USB V2.8 (c) SarasSoft 2007.
    Processing MCU file: rm561__09.97.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    ID 32: 000200800000
    Erase size: 21.00 MB
    CMT NOR area [00000000-000006BF] erased in 0.656 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.156 s
    CMT NOR area [00040000-000BFFFF] erased in 2.203 s
    CMT NOR area [000C0000-0013FFFF] erased in 0.219 s
    CMT NOR area [00140000-0137FFFF] erased in 1 min 9.265 s
    CMT NOR area [01380000-0151FFFF] erased in 7.063 s
    Flash programming ...
    CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100384336 (RAP Certificate 202 v.1) written.
    Programming completed in 12 min 33.328 s
    Processing PPM file: rm561__07.80.ppm_v
    [BB5,BB5 ALGORITHM] size: 7.25 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    ID 32: 000200800000
    Erase size: 8.62 MB
    CMT NOR area [01520000-01DBFFFF] erased in 29.110 s
    Programming completed in 5 min 1.250 s
    Processing CNT file: rm561__09.97.image_v_red
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    ID 32: 000200800000
    Erase size: 34.00 MB
    CMT NOR area [01DC0000-0215FFFF] erased in 16.110 s
    CMT NOR area [02160000-03FBFFFF] erased in 1 min 22.844 s
    Programming completed in 9 min 5.281 s
    Total time for flashing process(boot+erase+write) was 30 min 55.812 s
    Flashing completed in 31 min 17.172 s
    DIA_NGUC_MA
    0984745666
    V.I.P ThanhHai_GSM's Avatar
    log đó mới chạy thôi nếu chạy lại ver cao hơn ver trước đó bạn Ul settings lại cái đi
    May 2010
    Trích Được post bởi ThanhHai_GSM Xem bài viết
    Ul settings không được anh ạ. hiccc, khó quá
    DIA_NGUC_MA
    0984745666
    May 2010
    có dòng chữ này màu đỏ là gì mà em không hiêu; No RAP Flash Chip Detected.
    DIA_NGUC_MA
    0984745666
    máy bị va đập gì không bạn báo như vậy là không nó không truy xuất đc dữ liệu của Flash rồi
    có lẽ phải làm nhà 2 tầng thôi không chạy đc
    Jan 2007
    THAI BINH CITY
    Dùng mxkey chạy usb đi bạn
  1. 2700c lên nokia 3s tắt Nguồn
    By ChuotSmiles2 in forum BB5
    Bài viết cuối: 04-03-2014, 14:33
  2. 2700c lên nokia rồi tắt
    By thuong3 in forum BB5
    Trả lời: 22
    Bài viết cuối: 25-03-2012, 16:49
  3. 2700c lên NOKIA tắt máy
    By kennyphan in forum BB5
    Trả lời: 14
    Bài viết cuối: 29-05-2011, 19:10
  4. 2700c lên nokia rồi tắt cần giúp !
    By linhprox09 in forum BB5
    Bài viết cuối: 01-05-2011, 09:41
  5. 2700c lên nokia rồi tắt
    By 1976thienduong in forum BB5
    Trả lời: 18
    Bài viết cuối: 28-02-2011, 07:22
