Kết quả 1 tới 10 của 11
    May 2010
    Mặc định xin ae xem giup cái log 3110c
    log của em nó đây ; Using device: UFS_USB V2.8 (c) SarasSoft 2007.
    Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
    Processing MCU file: rm237__07.21.mcusw
    [BB5,BB5 ALGORITHM] size: 14.48 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 1130011833F48B56455BE09512F7225D0D8AEF16
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT NOR area [00000000-000006BF] erased in 0.984 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.234 s
    CMT NOR area [00020000-0007FFFF] erased in 2.953 s
    CMT NOR area [00080000-000DFFFF] erased in 0.218 s
    CMT NOR area [00100000-001FFFFF] erased in 0.344 s
    CMT NOR area [00200000-0031FFFF] erased in 8.078 s
    CMT NOR area [00320000-0105FFFF] erased in 1 min 36.187 s
    CMT NOR area [01060000-01067FFF] erased in 1.031 s
    CMT NOR area [01068000-0107FFFF] erased in 0.172 s
    Flash programming ...
    CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written.
    Programming completed in 2 min 0.813 s
    Processing PPM file: rm237__07.21.ppm_v
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 4.62 MB
    CMT NOR area [01080000-0151FFFF] erased in 2.016 s
    Error chk C7012D0103CD000010000000F1
    RX2 not responding, please check BSI/cable/pinout !
    Error while programming [00] at 0x010A0000, Result: 0010
    Flashing terminated with error(s) in 4 min 30.422 s
    RX Buffer: C7012D0103CD000010000000F172
    DIA_NGUC_MA
    0984745666
    Thành viên tích cực vantungnguyen's Avatar
    Nov 2010
    cái này có phải lỗi flash ko bà con, nghi quá
    May 2010
    con này em đã thay cáp đa năng rôi vẫn vậy, chạy bằng hwk cũng not ok
    DIA_NGUC_MA
    0984745666
    Thành viên tích cực sydungdtdd's Avatar
    Apr 2010
    anh đem qua mxkey chon file 7,30 có tiếng việt chạy ok đó
    ĐÔ-LƯƠNG-NGHỆ AN
    YAHOO.SYDUNGDTDD_88
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    tốt nhất trước khi làm gì bạn nên backup lại pm full và rpl cho nó keo lại ôm hận. còn lỗi này bạn có thể dùng HWK chạy ver 7.30 là ok. nếu ko được thì xóa full chạy lại.
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    nhìn máy dòng đó là đủ hiểu rồi
    nếu máy đang có nguồn mà flash báo lỗi vậy thì nên kiểm tra lại cáp ,tiếp xúc cáp
    có thể dùng usb flash lại cho nó
    Dec 2009
    GIALAI
    thay sợi cáp khác đi hoặc flash bằng dead usb xem sao
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    May 2010
    cám ơn tất cả ae đã nhiệt tình giúp đỡ, em đã làm ok ; MCU SW : V 07.30 07-05-09 RM-237 (c) Nokia.
    PPM SW : V 07.30 07-05-09 RM-237 (c) Nokia. C
    Product : Nokia 3110c
    Prd.Code: 0514949
    Bpr.Code: 0542523
    Prod.Sn : MAK556472
    HW Vers : 5008
    EM RETU : 32
    EM TAHVO: 53
    RFIC Ver: 17211721
    DSP Vers: ICPR61_08w10
    IMEI : 356061-03-279158-6
    SL Serv : SIMLOCK SERVER VERSION 63
    SL Conf : 244-07-00000000000
    SL Prof : 0000000000000000
    SL Count: 00 00
    BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    Provider: Nokia Test;Finland
    DIA_NGUC_MA
    0984745666
    May 2010
    em flash bằng dead usb khong được sau đấy em flat lại băng hwk thì như sau nhưng bật nguồn lên vẫn chớp tắt ; 1ST BOOT : C0,07 [Rm-237] [2.1.0.0]
    RAPx ID : 000000010000022600010006010C192101001101
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx PBID : 1130011833F48B56455BE09512F7225D0D8AEF16
    RAPx MODE : 00
    RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
    RAPx ROID : 191EC665DFAAF68F
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
    CMT FLID0 : 00898981-00006A21, Int NU48F256
    CMT FLCNT : 00000000000000000000000000000000000000
    CMT MCID0 : FFFF0000-00000000
    CMT 2ND Boot OK
    CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
    CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    IMAGE : rm237__07.21.mcusw
    CMT NOR Erase Area: 0x00000000-000006BF
    CMT NOR Erase Area: 0x000006C0-0001FFFF
    CMT NOR Erase Area: 0x00020000-0007FFFF
    CMT NOR Erase Area: 0x00080000-000DFFFF
    CMT NOR Erase Area: 0x00100000-001FFFFF
    CMT NOR Erase Area: 0x00200000-0031FFFF
    CMT NOR Erase Area: 0x00320000-0105FFFF
    CMT NOR Erase Area: 0x01060000-01067FFF
    CMT NOR Erase Area: 0x01068000-0107FFFF
    CMT FLASH ERASE OK, Time: 01:48
    Written: 10 Certificate(s)
    CMT FLASH WRITE OK, Time: 01:38
    Chip SECTOR_SIZE: 128k
    Warning, Must be Used 128Kb Sector_Size CNT File
    CONVERSION: Already 128K Paged Source
    IMAGE : rm237__07.21.image_v_128
    CMT NOR Erase Area: 0x01520000-01FDFFFF
    CNT FLASH ERASE OK, Time: 00:54
    CNT FLASH WRITE OK, Time: 00:32
    IMAGE : rm237__07.21.ppm_v
    CMT NOR Erase Area: 0x01080000-0151FFFF
    PPM FLASH ERASE OK, Time: 00:29
    PPM FLASH WRITE OK, Time: 00:27
    Flashing Completed, Rebooting Mobile
    DIA_NGUC_MA
    0984745666
    Như Xuân_Thanh Hóa
    đã nói rùi mà. 7.30 là ok mà
  1. cần giup 3110c
    By phuongxa in forum BB5
    Trả lời: 24
    Bài viết cuối: 04-04-2013, 10:02
  2. 3110c can giup
    By trungloc in forum BB5
    Bài viết cuối: 08-10-2009, 22:59
  3. giup e con 3110c voi
    By dungnv86 in forum BB5
    Trả lời: 13
    Bài viết cuối: 04-11-2008, 08:04
  4. giup em con 3110c với
    By baoanmobile in forum BB5
    Bài viết cuối: 13-12-2007, 20:01
