Octoplus / Octopus Box Samsung Software v.2.1.5 Release Notes:🐙 Added support for the following models:- SM-Z300H - added world's first Direct Unlock, Read Codes, Repair IMEI (A / B), Write Firmware, Read / Write Cert, Read / Write Security, Read PIT
- SM-Z300F - added world's first Direct Unlock, Read Codes, Repair IMEI (A / B), Write Firmware, Read / Write Cert, Read / Write Security, Read PIT
- SM-Z300FD - added world's first Direct Unlock, Read Codes, Repair IMEI (A / B), Write Firmware, Read / Write Cert, Read / Write Security, Read PIT
- SM-T817P - added Direct Unlock, Read / Write Cert, Read / Write Security, Read / Write / Repair EFS, Reset FRP / Reactivation / EE lock, Reboot in Download / Recovery mode, Read PIT
- SM-R750 - added Direct Unlock (no need root), Write Firmware, Read / Write / Repair NVM, Read / Write QCN, Read PIT
- SM-R750A - added Direct Unlock (no need root), Write Firmware, Read / Write / Repair NVM, Read / Write QCN, Read PIT
- SM-R750B - added Direct Unlock (no need root), Write Firmware, Read / Write / Repair NVM, Read / Write QCN, Read PIT
- SM-R750D - added Direct Unlock (no need root), Write Firmware, Read / Write / Repair NVM, Read / Write QCN, Read PIT
- SM-R750J - added Direct Unlock (no need root), Write Firmware, Read / Write / Repair NVM, Read / Write QCN, Read PIT
- SM-R750T - added Direct Unlock (no need root), Write Firmware, Read / Write / Repair NVM, Read / Write QCN, Read PIT
- SM-R750W - added Direct Unlock (no need root), Write Firmware, Read / Write / Repair NVM, Read / Write QCN, Read PIT
- SM-G9200 - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G9208 - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G9209 - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920D - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920F - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920FD - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920FZ - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920I - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920K - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920L - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920P - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920S - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920T - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920T1 - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
- SM-G920W8 - added Reset Screen Lock (Pattern, PIN, Password, Fingerprints)
🐙 Added "Fast Unlock" (no need root) and "Fast Reset MSL" (no need root) operations for the following models with new Security type:
- SM-A3000, SM-A300YZ, SM-A3009, SM-A300FU, SM-A300F, SM-A300G, SM-A300M, SM-A300Y, SM-A300H
- SM-A500YZ, SM-A500F, SM-A500FU, SM-A500G, SM-A500H, SM-A500K, SM-A500L, SM-A500S, SM-A500M, SM-A500XZ, SM-A5000, SM-A500FD, SM-A500Y
- SM-A700FZ, SM-A7000, SM-A7009, SM-A700H, SM-A700FD
- SM-E500M, SM-E500HQ, SM-E500H, SM-E500F, SM-E500YZ
- SM-E700F, SM-E700M, SM-E700H, SM-E7000
- SM-G360G, SM-G360F, SM-G360M, SM-G360GY, SM-G360FY, SM-G3609, SM-G3606, SM-G3608, SM-G360AZ, SM-G360BT
- SM-G7200, SM-G7202, SM-G720AX, SM-G720NO
- SM-P355, SM-P355C, SM-P355M, SM-P355Y
- SM-P555, SM-P555C, SM-P555Y, SM-P555M, SM-P555K, SM-P555L, SM-P555S
- SM-T355, SM-T355Y, SM-T355C
- SM-T555, SM-T555C
🐙 If you have a phone for which "Fast Unlock" or "Fast Reset MSL" operations are not supported - select any of the listed above models and try to do a "Fast Unlock" or "Fast Reset MSL" procedure
🐙 All supported operations described in details in the manual ("Cable & Manual" button in Software)More info and discussion are HERE
___________________________________
WBR,
Octoplus Box Team
