Trang 1 của 27 1 2 3 4 5 6 7 8 9 10 11 ... CuốiCuối
Kết quả 1 tới 10 của 264
    Hỗ Trợ Kĩ Thuật HoangThong_hotrokythuat4's Avatar
    Jan 2009
    Mặc định Z3X samsung New update
    Samsung 3G Tool 8.5 Update. Just one more revolutional update
    Only Real HOT solution from z3x-team
    Added:
    SGH-A797 support (unlock via read codes by usb cable ) - first in the world
    GT-B2710 support (flash, unlock via read codes) - first in the world
    GT-I5700R support (direct unlock/imei repair)
    GT-S7230E support (flash, unlock via patched flash ) - first in the world
    SGH-A927 support (unlock via read codes) - first in the world
    I know all waiting for A797 unlock solution.
    Welcome, solution ready.
    You can make money with your favorite z3x box
    Count supported models - 214
    Press 1 + message key and connect phone by cable
    Waiting for SE USB Device... OK
    Detected:\\?\usb#vid_0bdb&pid_100e#5&2eab04ab&0&2# {a6782bce-4376-4de2-8096-70aa9e8fed19}
    Opening Port... OK
    Flash ID900
    Protocol:0401
    Sending Loader 1... OK
    Sending Loader 2... OK
    Sending Loader 3... OK
    Sending Loader 4... OK
    Reading Data... OK
    Calculating stage 1... OK
    Calculating stage 2... OK
    Calculating codes... OK
    Freeze code: 39684252
    NET lock: #7465625*638*42852694#
    Sub lock: #7465625*782*00000000#
    SP lock: #7465625*77*00000000#
    CP lock: #7465625*27*00000000#
    For check lock status: *#7465625#
    Done with Samsung 3G tool ver 8.5
    Setup will be on support after 1hour RapidShare AG, Cham, Switzerland
  2. ( HoangThong_hotrokythuat4 ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    hoangdaika (05-12-2012), thanhkien90 (18-12-2012)
    Jan 2009
    How To Unlock samsung A797
    Install USB Driver
    Download : A797 Driver
    Power OFF phone
    Press and hold both keys ( 1 and message key )
    Press Unlock
    Connect USB cable
    When software detect phone - release keys
  4. ( HoangThong_hotrokythuat4 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  5. #3
    Thành viên danh dự TuấnPhát_GSM's Avatar
    Jan 2009
    Mặc định Samsung 2G Tool Update ver. 3.4.0069. Info inside
    Added:
    - C3300K code reading via USB cable
    - C3303 code reading via USB cable
    - E2550 code reading via USB cable
    - S5320 support (code reading, flashing )
    - B7722 support (master part unlock via code reading/ imei repair via z3x micro uart cable)
    - f275 support (direct unlock/ imei repair, flash read/write, eprom read/write)
    - f275L support (direct unlock/ imei repair, flash read/write, eprom
    - A697 support (unlock via code reading)
    - T249 support (unlock via code reaing)
    Fixed:
    -f270 tfs flashing.
    -A517 unlock fixed
    -T539 flahsing fixes
  6. ( TuấnPhát_GSM ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    hoangdaika (05-12-2012), quanghanh@ (24-10-2011)
  7. #4
    Jan 2009
    Mặc định Z3X BOX Samsung Update. S5620 boot repair without jtag ))))))))). all info inside
    Samsung 2G Tool 3.4.0071. First in the world.
    Added:
    - S5620 new chip boot repair without jtag - first in the world.
    - C3300K new security vodafone branded read codes via usb cable - first in the world.
    As we know many customers have lot of S5620 which can;t be repaired with other tool.
    So it;s time for all z3x owners to make money...
    We hope tommorow all s5620 will alive
    Wait for more and more hot and revolutionak and real update from Z3x-team
    Manual S5620 boot repair!
    READ CAREFULL AND AFTER NOT ASK 1000TIMES IN FORUM HOW REPAIR.:
    1. Check or battery fully charged in S5620.
    2. Run z3x sw, choise S5620, press Boot repair
    3. Connect z3x MICROUART cable to phone and wait.
    4. If you will see back lights on LCD - so phone in download mode and you lucky -> after
    5. Disconect z3x cable, connect usb cable(pc should detect device).
    6. Setup drivers.
    7. Run multidownloader and flash full firware with boot with ticked (full download)
  8. ( TuấnPhát_GSM ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    hoangdaika (05-12-2012), HoangThong_hotrokythuat4 (31-10-2010)
  9. #5
    86 phan đình phùng quảng ngãi
  10. ( NGUYÊNQNGAI ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
  11. #6
    Samsung 3g Tool 8.8. Only first in the world again
    Added:
    -i5510 support (direct unlock/ imei repair)
    p.s. All i5510 a,b, c,d,e,f,... etc - can be unlocked if you select i5510. all first in the world
    Wait for next update. few hours )
  12. ( NGUYÊNQNGAI ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    HoangThong_hotrokythuat4 (24-11-2010)
  13. #7
    TP.Tuy Hòa
    Arrow Z3X BOX Samsung Update. Samsung 2g tool 4.3.0074 update. All inside
    Samsung 2g tool 4.3.00074 update.
    Added:
    - S5250 full support standalone (flash, unlock, imei, Repair SWAP) without boot patch!!! - first in the world
    - S5253 full support standalone (flash, unlock, imei, Repair SWAP) without boot patch!!! - first in the world
    - E1252 full support (flash, unlock, imei, read code)
    - E1225T full support (flash, unlock, imei, read code)
    - S5230M full support (flash, unlock, imei, Repair SWAP)
    - C3200 reading user code.
    - S3550 reading user code.
    Manual how work with S5250/S5253 READ CAREFULL:
    1. Download any original firmware.
    2. Flash firmware or only apps file to phone.
    3. If you got blink phone or freze on logo - flash boot via multiloader.
    4. Choise same apps file in firmware window. And choise this fw like for flashing.
    5. Press Read codes button or imei repair button.
    6. Make all programm steps.
  14. ( TUYHOAGSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  15. #8
    Jan 2009
    Mặc định Z 3 X-MAS Samsung Unreal update. Only wanted solution. and this is begin only
    Samsung 3G tool 8.9 update. Real solution from real team
    Added:
    For begin: you waiting for i9000,i897,t959 - result is:
    - P1000 addition support (flashing, new sec unlock, imei repair via patch flash)
    - i897 addition support (flashing, new sec unlock, imei repair via patch flash)
    - t959 addition support (flashing, new sec unlock, imei repair via patch flash)
    Second, also most wanted:
    - T669 addition support (direct unlock!!! , code reading, frezz remove!!) - first in the world
    And:
    Now we listed phones which from now can be unlocked:
    - all known version
    - WITHOUT ANY CREDITS, LOGS
    - WITHOUT ANY FIRWMARE PATCHING (like we did before )
    - WITHOUT ANY BOOT PATCHING (this method like boot killers)
    - WITHOUT ANY CHANGE IN STRUCTUR OF PHONE (FULL SAFE)
    - S8500 additional support (direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - S8530 additional support (direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - S8000 additional support (direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    Note: S8000, S8003, S8000M, S8000L, S8000T - can be direct unlocked like S8000
    - S3370 additional support (direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - S5350 additional support (direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - S5530 additional support (direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - S5510 additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - C5510 additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - S5600 additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - S5603 additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - S8300 additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    Note: S8300H, S8300J, S8300N, S8300V - can be direct unlocked like S8300
    - S7330 additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - M7500 additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - M7603 additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - M7600 additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - S6700T additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    - S6703T additional support (new direct unlock!!! , code reading, frezz remove) - free without any credits - first in the world
    Manual for all this models added inside sw under manual button.
    P.S. Sorry, but for security reason we have add this method only via server. So be sure that internet - connected while unlocking.
    LAST NOTE: S7230E, S7230 was removed from 3G tool and will be added in next version of 2G tool.
    BUT IF YOU WANT UNLOCK THIS PHONES NOW WITHOUT ANY BOOT CANHING - YOU CAN DO IT - JUST CHOISE S8500 FROM LIST AND READ CODES....
    all our customers, are you want more good SAFE solution? ) just wait for new update of 2G tool. we hope this will be also very big surpise.
  16. ( TuấnPhát_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    HoangThong_hotrokythuat4 (20-12-2010)
  17. #9
    Jan 2009
    Mặc định Samsung 3g Tool 9.1. first in the world again
    Samsung 3G tool 9.1 First in the world
    Added:
    T959 additional function new sec (reset network codes via patch (for phones which can be unlocked in normal way)
    I9000 additional function new sec (reset network codes via patch (for phones which can be unlocked in normal way)
    P1000 additional function new sec (reset network codes via patch (for phones which can be unlocked in normal way)
    I897 additional function new sec (reset network codes via patch (for phones which can be unlocked in normal way)
    T556 support ( direc usb coder reading ) - first in the world
    T359 additional support ( new sec T359UVIJ2 usb code reading ) - first in the world
    T479 additional support ( new sec T479UVJH1 usb code reading ) - first in the world
    - Improved server part
  18. #10
    Product Supporter HoangThong_hotrokythuat10's Avatar
    UPDATE Z3X-SHELL _3.9.1.exe: 09.01.11
    SERVER is now BACK ON LINE!
    CTy TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    Địa chỉ : 697 - 699 Đường 3 tháng 2 Phường 6 Quận 10 Tp. Hồ Chí Minh
    Điện Thoại : 08.9572152 - 08.8.57.57.07 - 0903303717
    www.saigonmobile.vn
  1. DC unlocker Update anh em vui long post ở đây
    By hungphongmobile™ in forum DC-unlocker
    Trả lời: 87
    Bài viết cuối: 12-07-2022, 22:16
  2. Update mx-key anh em vui long post ở đây nhé
    By Hoang Thong Mobile in forum MX-KEY (by Alim Hape)
    Trả lời: 185
    Bài viết cuối: 10-12-2014, 22:12
  3. Update cyclonebox anh em vui long post ở đây nhé
    By HoangThong_hotrokythuat4 in forum Cyclonebox
    Trả lời: 75
    Bài viết cuối: 11-07-2013, 11:03
  4. Samsung Rocker New Update AE Post tại đây
    By TuấnPhát_GSM in forum Samsung Rocker
    Bài viết cuối: 15-02-2012, 17:16
  5. Z3x samsung update anh em vui lòng post tại đây
    By HoangThong_hotrokythuat4 in forum Z3X-BOX FOR SAMSUNG
    Bài viết cuối: 05-10-2010, 16:34
