14:05:00 : Number of Image Files: 3
14:05:00 :
14:05:00 : Processing Image File :
14:05:00 : rm607__03.35.mcusw
14:05:00 : CMT Type :
14:05:00 : CMT Algorithm :
14:05:00 : Secondary Sending Speed : 0Hz
14:05:00 : Algorithm Sending Speed : 0Hz
14:05:00 : Program Sending Speed : 0Hz
14:05:00 : Message Reading Speed : 0Hz
14:05:00 : Number of Blocks : 0
14:05:00 : Entry Point: 0x0000
14:05:00 : Page Format : -1
14:05:00 : MAX PAGE : 0x00000000
14:05:00 :
14:05:09 : Number of Image Files: 3
14:05:09 :
14:05:09 : Processing Image File :
14:05:09 : rm607__03.35.mcusw
14:05:09 : CMT Type :
14:05:09 : CMT Algorithm :
14:05:09 : Secondary Sending Speed : 0Hz
14:05:09 : Algorithm Sending Speed : 0Hz
14:05:09 : Program Sending Speed : 0Hz
14:05:09 : Message Reading Speed : 0Hz
14:05:09 : Number of Blocks : 0
14:05:09 : Entry Point: 0x0000
14:05:09 : Page Format : -1
14:05:09 : MAX PAGE : 0x00000000
14:05:09 :
14:05:16 : Number of Image Files: 3
14:05:16 :
14:05:16 : Processing Image File :
14:05:16 : rm607__03.35.mcusw
14:05:16 : CMT Type :
14:05:16 : CMT Algorithm :
14:05:16 : Secondary Sending Speed : 0Hz
14:05:16 : Algorithm Sending Speed : 0Hz
14:05:16 : Program Sending Speed : 0Hz
14:05:16 : Message Reading Speed : 0Hz
14:05:16 : Number of Blocks : 0
14:05:16 : Entry Point: 0x0000
14:05:16 : Page Format : -1
14:05:16 : MAX PAGE : 0x00000000
14:05:16 :
14:05:21 : Number of Image Files: 3
14:05:21 :
14:05:21 : Processing Image File :
14:05:21 : rm607__03.35.mcusw
14:05:21 : CMT Type :
14:05:21 : CMT Algorithm :
14:05:21 : Secondary Sending Speed : 0Hz
14:05:21 : Algorithm Sending Speed : 0Hz
14:05:21 : Program Sending Speed : 0Hz
14:05:21 : Message Reading Speed : 0Hz
14:05:21 : Number of Blocks : 0
14:05:21 : Entry Point: 0x0000
14:05:21 : Page Format : -1
14:05:21 : MAX PAGE : 0x00000000
14:05:21 :
14:05:35 : Number of Image Files: 3
14:05:35 :
14:05:35 : Processing Image File :
14:05:35 : rm607__03.35.mcusw
14:05:35 : CMT Type :
14:05:35 : CMT Algorithm :
14:05:35 : Secondary Sending Speed : 0Hz
14:05:35 : Algorithm Sending Speed : 0Hz
14:05:35 : Program Sending Speed : 0Hz
14:05:35 : Message Reading Speed : 0Hz
14:05:35 : Number of Blocks : 0
14:05:35 : Entry Point: 0x0000
14:05:35 : Page Format : -1
14:05:35 : MAX PAGE : 0x00000000
14:05:35 :
14:06:19 : Number of Image Files: 3
14:06:19 :
14:06:19 : Processing Image File :
14:06:19 : rm607__03.35.mcusw
14:06:19 : CMT Type :
14:06:19 : CMT Algorithm :
14:06:19 : Secondary Sending Speed : 0Hz
14:06:19 : Algorithm Sending Speed : 0Hz
14:06:19 : Program Sending Speed : 0Hz
14:06:19 : Message Reading Speed : 0Hz
14:06:19 : Number of Blocks : 0
14:06:19 : Entry Point: 0x0000
14:06:19 : Page Format : -1
14:06:19 : MAX PAGE : 0x00000000
14:06:19 :
14:06:37 : Number of Image Files: 3
14:06:37 :
14:06:37 : Processing Image File :
14:06:37 : rm607__03.35.mcusw
14:06:37 : CMT Type :
14:06:37 : CMT Algorithm :
14:06:37 : Secondary Sending Speed : 0Hz
14:06:37 : Algorithm Sending Speed : 0Hz
14:06:37 : Program Sending Speed : 0Hz
14:06:37 : Message Reading Speed : 0Hz
14:06:37 : Number of Blocks : 0
14:06:37 : Entry Point: 0x0000
14:06:37 : Page Format : -1
14:06:37 : MAX PAGE : 0x00000000
14:06:37 :
14:06:51 : Number of Image Files: 3
14:06:51 :
14:06:51 : Processing Image File :
14:06:51 : rm607__03.35.mcusw
14:06:51 : CMT Type :
14:06:51 : CMT Algorithm :
14:06:51 : Secondary Sending Speed : 0Hz
14:06:51 : Algorithm Sending Speed : 0Hz
14:06:51 : Program Sending Speed : 0Hz
14:06:51 : Message Reading Speed : 0Hz
14:06:51 : Number of Blocks : 0
14:06:51 : Entry Point: 0x0000
14:06:51 : Page Format : -1
14:06:51 : MAX PAGE : 0x00000000
14:06:51 :
14:06:55 : Number of Image Files: 3
14:06:55 :
14:06:55 : Processing Image File :
14:06:55 : rm607__03.35.mcusw
14:06:55 : CMT Type :
14:06:55 : CMT Algorithm :
14:06:55 : Secondary Sending Speed : 0Hz
14:06:55 : Algorithm Sending Speed : 0Hz
14:06:55 : Program Sending Speed : 0Hz
14:06:55 : Message Reading Speed : 0Hz
14:06:55 : Number of Blocks : 0
14:06:55 : Entry Point: 0x0000
14:06:55 : Page Format : -1
14:06:55 : MAX PAGE : 0x00000000
14:06:55 :
14:09:51 : ERROR: USB Write Failed
14:09:52 : ERROR: USB Write Failed
14:09:58 : Number of Image Files: 3
14:09:58 :
14:09:58 : Processing Image File :
14:09:58 : rm607__03.35.mcusw
14:09:58 : rm607__03.35.ppm_v
14:09:58 : rm607__03.35.image_v_0596365
14:09:58 : []: Found 1 active devices.
14:09:58 : [Nokia C1-01 USB Phonet]: Opening Connection
14:09:58 : [Nokia C1-01 USB Phonet]: Port opened OK!
14:09:58 :
14:09:58 : SW: V 03.35 02-12-10 RM-607 (c) Nokia
14:09:58 : IMEI: 355962049045448
14:09:58 :
14:09:58 : START FULL PM BACKUP
14:09:58 : Please Wait...
14:10:20 : Reading : PM 0~400... OK!
14:10:20 : FULL PM Backup Saved to:
14:10:20 : C:\AdvanceBox Turbo Flasher\Nokia\Backup\355962049045448\USB_FULL_BACK UP_V 03.35 02-12-10 RM-607 (c) Nokia_355962049045448__21020.pm
14:10:20 :
14:10:20 :
14:10:20 : Reading battery value : 3947 mV
14:10:24 : Rebooting Phone...
14:10:24 :
14:10:24 :
14:10:24 :
14:10:24 : AUTO SELECTED DEAD USB FLASHING...
14:10:24 :
14:10:24 : If Flashing DOES NOT Start in 5 Seconds,
14:10:24 : Then Perform Steps 1, 2, 3 and 4...
14:10:24 :
14:10:25 : 1. Remove USB and Battery...
14:10:25 : 2. Insert USB.
14:10:25 : 3. Insert Battery. (Some phones boot automatically)
14:10:25 : 4. Please Power on phone shortly..
14:10:25 :
14:10:26 :
14:10:26 : Infineon USB Boot: F00A1FB300020303010100FF
14:10:26 : Sending PBL...
14:10:29 : PBL Successfully Sent...
14:10:29 : Sending SBL...
14:10:29 : SBL Successfully Sent...
14:10:29 : Setting Transmission Speed Done...
14:10:29 : Flash Chip Manufacturer: Intel Electronics Corp.
14:10:29 : Flash Boot Successful...
14:10:29 :
14:10:29 :
14:10:29 :
14:10:29 : Current File : rm607__03.35.mcusw
14:10:29 : Image Type : Main Firmware
14:10:29 : Sections : 05
14:10:29 : Compile Name: rm607__03.35.mcusw_ebl_psi.fls
14:10:29 : Data Size : 26217904 Bytes
14:10:29 :
14:10:29 : Sending Certificate Block
14:10:30 : FIRMWARE Certificate Block Sent Successfully...
14:10:30 : Processing Section 01 of 05
14:10:30 : FIRMWARE Erase Block: 0x40000000~0x4001FFFE
14:10:30 : Start Erasing...
14:10:30 : Erasing Please Wait...
14:10:30 : Block Erase Done...
14:10:30 : Preparing Data Blocks...
14:10:30 : Data Size: 131072 bytes
14:10:30 : Data Checksum: A830
14:10:30 : Uploading Data Blocks to phone...
14:10:31 : Block Write Successful...
14:10:31 : FIRMWARE Data Blocks uploaded to phone...
14:10:31 : Processing Section 02 of 05
14:10:31 : FIRMWARE Erase Block: 0x40040000~0x4007FFFE
14:10:31 : Start Erasing...
14:10:31 : Erasing Please Wait...
14:10:32 : Block Erase Done...
14:10:32 : Preparing Data Blocks...
14:10:32 : Data Size: 262144 bytes
14:10:32 : Data Checksum: 0000
14:10:32 : Uploading Data Blocks to phone...
14:10:33 : Block Write Successful...
14:10:33 : FIRMWARE Data Blocks uploaded to phone...
14:10:33 : Processing Section 03 of 05
14:10:33 : FIRMWARE Erase Block: 0x40080000~0x4009FFFE
14:10:33 : Start Erasing...
14:10:33 : Erasing Please Wait...
14:10:34 : Block Erase Done...
14:10:34 : Preparing Data Blocks...
14:10:34 : Data Size: 131072 bytes
14:10:34 : Data Checksum: 865C
14:10:34 : Uploading Data Blocks to phone...
14:10:34 : Block Write Successful...
14:10:34 : FIRMWARE Data Blocks uploaded to phone...
14:10:34 : Processing Section 04 of 05
14:10:34 : FIRMWARE Erase Block: 0x400A0000~0x4019FFFE
14:10:34 : Start Erasing...
14:10:34 : Erasing Please Wait...
14:10:40 : Block Erase Done...
14:10:40 : Preparing Data Blocks...
14:10:40 : Data Size: 1048576 bytes
14:10:40 : Data Checksum: 097B
14:10:40 : Uploading Data Blocks to phone...
14:10:41 : Block Write Successful...
14:10:41 : FIRMWARE Data Blocks uploaded to phone...
14:10:41 : Processing Section 05 of 05
14:10:41 : FIRMWARE Erase Block: 0x40400000~0x41BFFFFE
14:10:41 : Start Erasing...
14:10:41 : Erasing Please Wait...
14:12:51 : Block Erase Done...
14:12:51 : Preparing Data Blocks...
14:12:51 : Data Size: 24641536 bytes
14:12:51 : Data Checksum: C5EE
14:12:51 : Uploading Data Blocks to phone...
14:13:24 : Block Write Successful...
14:13:24 : FIRMWARE Data Blocks uploaded to phone...
14:13:24 : Data Verification Successful...
14:13:24 :
14:13:24 :
14:13:24 : Current File : rm607__03.35.ppm_v
14:13:24 : Image Type : PPM Image
14:13:24 : Sections : 01
14:13:24 : Compile Name: package_v.ppm_ebl_psi.fls
14:13:24 : Data Size : 4258712 Bytes
14:13:24 :
14:13:24 : Sending Certificate Block
14:13:24 : PPM Certificate Block Sent Successfully...
14:13:24 : Processing Section 01 of 01
14:13:24 : PPM Erase Block: 0x41C00000~0x421FFFFE
14:13:24 : Start Erasing...
14:13:24 : Erasing Please Wait...
14:13:55 : Block Erase Done...
14:13:56 : Preparing Data Blocks...
14:13:56 : Data Size: 4255368 bytes
14:13:56 : Data Checksum: 6EBB
14:13:56 : Uploading Data Blocks to phone...
14:14:01 : Block Write Successful...
14:14:01 : PPM Data Blocks uploaded to phone...
14:14:01 : Data Verification Successful...
14:14:01 :
14:14:01 :
14:14:01 : Current File : rm607__03.35.image_v_0596365
14:14:01 : Image Type : CONTENT Package
14:14:01 : Sections : 01
14:14:01 : Compile Name: package_v_0596365.image.fls
14:14:01 : Data Size : 13765904 Bytes
14:14:01 :
14:14:01 : Sending Certificate Block
14:14:01 : CONTENT Certificate Block Sent Successfully...
14:14:01 : Processing Section 01 of 01
14:14:01 : CONTENT Erase Block: 0x42200000~0x43E5FFFE
14:14:01 : Start Erasing...
14:14:01 : Erasing Please Wait...
14:17:09 : Block Erase Done...
14:17:09 : Preparing Data Blocks...
14:17:09 : Data Size: 13762560 bytes
14:17:09 : Data Checksum: EB10
14:17:09 : Uploading Data Blocks to phone...
14:17:28 : Block Write Successful...
14:17:28 : CONTENT Data Blocks uploaded to phone...
14:17:28 : Data Verification Successful...
14:17:28 : Total Flashing Time (Erase + Flashing) : 00:06:59
