nguyên văn từ Advance-Box
ví dụ nhũng box mở giao diện lên báo như thế nàyHi,
On May 20, 2014 our ACTIVATION SERVER had a small database corruption and we have since then FULLY Restored it. However, if you are still experiencing Box Activation Problems after updating your firmware to LogiCore 11.0.00 or ATF Software 11.xx and above, please:
1. POST FULL BOX SN Here
2. Post Date of when you Updated your Box Firmware
There is NO NEED TO PANIC. I will solve your ACTIVATION Problem and you DO NOT NEED TO CONTACT YOUR RESELLER. Just give me Info 1 and 2 as I require above.
B.R.
anh em có box chưa được active vào link sau để lại thông tin box để đuọc hỗ trợ================================================
Advance Turbo Flasher Found
Driver Version : 00020824
Library Version : 00030207
Box Type : ATF Nitro
Box Firmware : LogiCore 10.3.80
Software Version : v10.20
AdvanceBox SN : F65644E9A4B745BAE758CDAA
Box Status : NOT ACTIVATED
i think that was 2014/5/22
Box Successfully Initialized
<<<<<<< all box not activated - look inside asap >>>>>>> - GSM-Forum
