E52 FULL Flash via FBUS = 49 Seconds
AdvanceBox Turbo Flasher Found
Initialize Device....
Init TRY : 1
Changing Clock to 15mhz..
Box Name : AdvanceBox Turbo
Box Firmware : LogiCore 1.16.10
Software Version : v2010.0.1.21
AdvanceBox SN : E43C85E1F5CD8A8BD157919B
BOX ACTIVATED
DDR DELAY : 01
INIT : OK
Changing MODE : FLASH
Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-469\rm469_031.012_prd.core.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.6
CMT Supported Hardwares :
> 4003192102001104
> 400C192102001104
> 6003192102001104
> 600C192102001104
> 6003192102011104
> 600C192102011104
> 6003192102021104
> 600C192102021104
> 600C192102031104
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 13000000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 440
Entry Point: 0x01E2
Page Format : -1
MAX PAGE : 0x00040000
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2118223920 (0x30) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 600C1921
ID DWORD 4 : 02011104
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00000C34
3 ROM_ID 15
ID DWORD 0 : 00000C30
4 PUBLIC_ID 12
ID DWORD 0 : 16500114
ID DWORD 1 : 4C340344
ID DWORD 2 : DE509AF2
ID DWORD 3 : 9450934C
ID DWORD 4 : F08DCBA5
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 3E273BF6
CRC 1 : 37BE26FA
Checksum 49
SearchForBootstrap_DCT5..
Boot File MATCH : RAPUv11_2nd.fg
Boot File - Version : 009.048.000
Boot File - Revision : 0x0300
BB5ProtocolType == : New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)
MessageID : C1
SubBlocks : 05
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0040 -> KAT00F00RA
Revision ID : 0121
Checksum : 19
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Algo File MATCH : RAPUv11_XSR17_alg.fg
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
VPP Enabled by Software
Using Internal VPP
VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER
CMT Does Not Support 12V VPP
CMT Does Not Support Group Erase
00 unsupported VPP Voltage setting
Using Internal VPP
SendFlashVoltageInit_DCT5
VPP1 0000
VPP2 0000
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 01
PAPUB Keys Hash : 0085F252E351E225CAFC4DFBC8041EABD2823E3500
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D7
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00020000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 000A0000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 03480000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 0B140000
Partition 4
Start Address : 0F640000
PARTITION_INFO_REQUEST_BB5
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x004F (79)
ERASE Blocks : 0x0002 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x1B (27)
Device Index : 0x00
0 : 00020000-0003FFFF
1 : 00060000-004DFFFF
2 : 008E0000-0B13FFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID :0x02000000
Format Info :000000000000000A0000000000000002000000640000000B0 000000200000001000000000000
ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B0003000006000000 4DFFFF120B000300008E00000B13FFFF9E
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000002
Additional Bad : 00000002
Correctable ECC : 00000000
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000000000 0002000000640000000B000000020000000100000000000033
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Successfully erased..
Is Flashing CLOCK AUTO : 0
Processing : rm469_031.012_prd.core.fpsx
Total blocks to write : 440
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : SOS+PMML
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : LDSP
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
ContinueFlash_DCT5 Complete
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
FlashInfo.RestartMode : 1
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:44
Making delay between files for 10ms
Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-469\rm469_031.012_C00.01_DEFAULT_prd.rofs3.fpsx
CMT Type : BB5
> 4003192102001104
> 400C192102001104
> 6003192102001104
> 600C192102001104
> 6003192102011104
> 600C192102011104
> 6003192102021104
> 600C192102021104
> 600C192102031104
Number of Blocks : 34
Entry Point: 0x00E7
Page Format : -1
BootFlashMode_DCT5
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 3E273BF6
CRC 1 : 37BE26FA
Checksum 49
MessageID : C1
SubBlocks : 05
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0121
Checksum : 19
SendAlgoCode_DCT5..
Algo Loader Sent...
Using Internal VPP
Using Internal VPP
VPP1 0000
VPP2 0000
Pabub KEY Request
BB Asic Index : 01
No RESTORE CERTIFICATE FOUND IN IMAGE FILE
No partition info....
StartErase_DCT5...
BlockLength : 0x000E (14)
ERASE Blocks : 0x0001 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 09D00000-0B13FFFF
ERASE_REQUEST_BB5 : 5001120B00030009D000000B13FFFFE9
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Processing : rm469_031.012_C00.01_DEFAULT_prd.rofs3.fpsx
Total blocks to write : 34
>> CMT Rootkey Hash CERT : SOS+ROFS3
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Time Taken to Flash : 00:00:04
Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-469\rm469_031.012_U000.000_prd.uda.fpsx
CMT Type : BB5
> 4003192102001104
> 400C192102001104
> 6003192102001104
> 600C192102001104
> 6003192102011104
> 600C192102011104
> 6003192102021104
> 600C192102021104
> 600C192102031104
Entry Point: 0x00E7
Page Format : -1
BootFlashMode_DCT5
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 3E273BF6
CRC 1 : 37BE26FA
Checksum 49
MessageID : C1
SubBlocks : 05
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0121
Checksum : 19
SendAlgoCode_DCT5..
Algo Loader Sent...
Using Internal VPP
Using Internal VPP
VPP1 0000
VPP2 0000
Pabub KEY Request
BB Asic Index : 01
StartErase_DCT5...
Device Index : 0x00
0 : 0B140000-0F27FFFF
ERASE_REQUEST_BB5 : 5001120B0003000B1400000F27FFFF8B
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Processing : rm469_031.012_U000.000_prd.uda.fpsx
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Time Taken to Flash : 00:00:01
Rebooting Box ...
Init TRY : 1
BOX ACTIVATED
DDR DELAY : 01
INIT : OK
VBATT OFF ...
VBATT ON
Setting VBATT Done!...
Waiting for phone to Power On, 8000 ms delay
Changing MODE : UART
Reading Phone Information...
MCU SW version : V ICPR82_09w46.3 28-12-09 RM-469 (c) Nokia
HW version : 6000
PCI version :
RFIC version : |Vapaus_5.1 | Aura_?.?
DSP version : ICPR82_09w46.2_RIO
Retu version : 34
Tahvo version : 00
Production serial number : MKO703255
Product code : 0581292
Module code : 0203994
Basic production code : 0565921
Flash code :
Order number :
Product specific data :
Long production SN : 0
ATO :
IMEI plain : 355216030887254
IMEI spare to net : 3A 55 12 06 03 88 27 05
IMEI SV to net : 33 55 12 06 03 88 27 35 F9
Simlock Version : SIMLOCK SERVER
CONFIG KEY: 0000000000000000
Provider : AT&T;U.S.A. (3650)
Counters : 0/3 , 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status : Not Locked
No. of records found : 4
