Trang 6 của 9 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 CuốiCuối
Kết quả 51 tới 60 của 87
    Moderator THIÊN UY™'s Avatar
    Bình Dương
    C1-01 Flash Usb ok.
    Technical Assistance GIALAI_GSM's Avatar
    Dec 2009
    GIALAI
    flash full C3 chỉ 8 giây
    Number of Image Files: 3
    Processing Image File :
    rm614__04.45.mcusw
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 650000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 525
    Entry Point: 0x01F2
    Page Format : -1
    MAX PAGE : 0x0000E000
    rm614__04.45.ppm_v
    CMT Type : BB5
    Number of Blocks : 130
    Entry Point: 0x0113
    Page Format : -1
    rm614__04.45.image_v_0597641
    CMT Type : BB5
    Number of Blocks : 222
    Entry Point: 0x0147
    Page Format : -1
    []: Found 1 active devices.
    [Nokia C3-00 USB Phonet]: Opening Connection
    [Nokia C3-00 USB Phonet]: Port opened OK!
    SW: V 03.35 15-05-10 RM-614 (c) Nokia
    IMEI: 353760045353937
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK STATE : Not Locked
    START FULL PM BACKUP
    Please Wait...
    Reading : PM 0~400... OK!
    FULL PM Backup Saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\353760045353937\USB_FULL_BACK UP_V 03.35 15-05-10 RM-614 (c) Nokia_353760045353937_Not Locked_63937.pm
    Reading battery value : 3680 mV
    Rebooting Phone...
    AUTO SELECTED DEAD USB FLASHING...
    If Flashing DOES NOT Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    BootRom Verified!
    BootFlashModeDCT5Ex Succeeded First Time
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
    Number of Sub Blocks 6 (0x06)
    1 SYSTEM_ASIC_ID 01
    Block Length : 17 (11)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000000
    ID DWORD 1 : 00000000
    ID DWORD 2 : 22000509
    ID DWORD 3 : 200C0000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00005361
    3 PUBLIC_ID 12
    Block Length : 21 (15)
    ID DWORD 1 : 0095B629
    ID DWORD 2 : BFBD2CDB
    ID DWORD 3 : 29C5BF9F
    ID DWORD 4 : 44371FCB
    4 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    5 ROOT_KEY_HASH 14
    Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
    6 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : DE56D582
    CRC 1 : BDDE7A3A
    START FLASHING
    RawLoaderExtract: rm614__04.45.mcusw
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_u sb2nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> not detected
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Device ID : 0000 -> BAD FLASH TYPE
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0010 ->
    Device ID : 0011 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0030 -> K5W1G13ACB
    Revision ID : 0321
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data :
    Flash Descriptor
    Device ID : 0030
    Revision ID : 0000
    Size : 08000000 (128 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_X SR16_usbalg.fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\353760045353937\3537600453539 37_63947.rpl
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
    ImagePath: D:\Flash file\File nokia\C3-00 RM-614\04.45\
    ImageFilename: rm614__04.45.mcusw
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    Certificate 5
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    Partition Version : 00010000
    Spare : FFFFFFFF
    Num Partitions : 00000004
    Partition 1
    Attribute : 00000002 RO
    Start Address : 00020000
    Partition 2
    ID : 00000008 FILESYSTEM
    Attribute : 00000001 RW
    Start Address : 02A00000
    Partition 3
    Start Address : 07540000
    Partition 4
    Start Address : 07B40000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000025E0000000000080000000102A0000004B400 000000000A0000000107540000006000000000000B00000001 07B40000001800000D
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0x90 (144)
    ERASE Blocks : 0x03 (3)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x2B (43)
    Device Index : 0x00
    0 : 00000000-0001FFFF
    1 : 00020000-000203FF
    2 : 00060000-012FFFFF
    3 : 01300000-01DFFFFF
    4 : 02600000-029FFFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x02000000
    Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
    2 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B0003000002000000 0203FF120B00030000060000012FFFFF120B00030001300000 01DFFFFF120B00030002600000029FFFFF11
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
    Successfully erased..
    Total blocks to write : 525
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : MCUSW
    >> CMT Rootkey Hash CERT : MCUSW1
    >> CMT Rootkey Hash CERT : GENIO_INIT
    >> CMT Rootkey Hash CERT : ISA+DYNSW
    ImageFilename: rm614__04.45.ppm_v
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    ERASE Blocks : 0x01 (1)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01E00000-025FFFFF
    ERASE_REQUEST_BB5 : 5001120B00030001E00000025FFFFF9E
    Total blocks to write : 130
    ImageFilename: rm614__04.45.image_v_0597641
    StartErase_DCT5...
    BlockLength : 0x3F (63)
    ERASE Blocks : 0x02 (2)
    Device Index : 0x00
    0 : 02A00000-0753FFFF
    Device Index : 0x00
    Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5001120B00030002A000000753FFFFE4
    FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
    Total blocks to write : 222
    ContinueFlash_DCT5 Complete
    Continue Flash Complete : : No Error - 0 (0x00)
    Status_BB5 STATUS_REQUEST_BB5..
    1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 00
    Device Type : 03
    Device Type : 00
    Num Bad Blocks : 00000000
    Additional Bad : 00000000
    Correctable ECC : 00000000
    FlashInfo.RestartMode : 2
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:08
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    SW: V 04.45 04-08-10 RM-614 (c) Nokia
    SIMLOCK TABLE :
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SUPER_DONGLE_TEST : PASSED
    SECURITY_CODE : 81777
    SL3 Phone detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    FACTORY SET TO : Full Factory Set
    OK
    FACTORY SET TO : User Data
    OK
    FACTORY SET TO : Leave Factory
    OK
    FACTORY SET TO : Service Center
    OK
    FACTORY SET TO : Software Upgrade
    OK
    FACTORY SET TO : Production Tune
    Error: USB BULK WRITE FAILED
    OK
    RESET LIFE TIMER TO : 0000:00
    OK
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Dec 2009
    GIALAI
    flash nokia 302 OK
    Code:
     rm813__14.26.mcusw
    CMT Type : BB5
    Number of Blocks :  300
    Entry Point:  0x02BB
    Page Format : -1
    MAX PAGE : 0x00020000
     rm813__14.26.ppm_v
    CMT Type : BB5
    Number of Blocks :  53
    Entry Point:  0x0151
    Page Format : -1
     rm813__14.26.image_v_059L2X6_009
    CMT Type : BB5
    Number of Blocks :  220
    Entry Point:  0x0182
    Page Format : -1
    2. Insert USB.
    BootFlashMode_DCT5
     BootRom Verified!
    BootFlashModeDCT5Ex Succeded After 0 Tries
    Number of Sub Blocks 7 (0x07)
      1  SYSTEM_ASIC_ID 01
         ID DWORD    0 : 00000003
         ID DWORD    1 : 00000226
         ID DWORD    2 : 00010007
         ID DWORD    3 : 400C1921
         ID DWORD    4 : 03032108
      2  EM_ASIC_ID 02
         ID DWORD    0 : 00001051
      3  EM_ASIC_ID 02
         ID DWORD    0 : 00001060
      4  PUBLIC_ID 12
         ID DWORD    0 : F00D0000
         ID DWORD    1 : FFFB3C40
         ID DWORD    2 : B369844C
         ID DWORD    3 : 06386226
         ID DWORD    4 : 0B9BD465
      5  ASIC_MODE_ID 13
         Mode Id       : 00
      6  ROOT_KEY_HASH 14
         Hash          :  3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06
      7  ROM_ID 15
         CRC         0 : 2CAC45E2
         CRC         1 : 3BC33C8B
     START FLASHING
    RawLoaderExtract: rm813__14.26.mcusw
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv21_2nd.fg
     MessageID  : C1
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 01
       Manufacturer Code : 0000 -> SPANSION
       Device ID         : 0001 -> not used
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Device ID         : 0040 -> KAT00F00RA
       Revision ID       : 0241
       Block Length      : 09
       Data              :
    Flash Descriptor
       Device ID         : 0040
       Revision ID       : 0000
       Size              : 10000000 (256 MB)
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv21_XSR17_alg.fg
    FUR control Ok
    IMEI: 358629040755005
     Plain RPL saved to:
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\358629040755005\358629040755005_11851.rpl
    Pabub KEY Request
        BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
     05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E
    ImagePath: D:\Flash file\File nokia\302\14.26\
    ImageFilename: rm813__14.26.mcusw
    Certificate 1
      ASIC Index  : CMT  0
    Certificate 2
      ASIC Index  : CMT  0
    Certificate 3
      ASIC Index  : CMT  0
    Certificate 4
      ASIC Index  : CMT  0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    Partition Info
                Device Index      : 0x00
                Spare             : FFFFFFFF
                Partition    1
                  Start Address   : 00140000
                Partition    2
                  Start Address   : 03880000
                Partition    3
                  Start Address   : 0F080000
                Partition    4
                  Start Address   : 0F680000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200140000030C00000000000800000001038800000B8000000000000A000000010F080000006000000000000B000000010F6800000030000000
    StartErase_DCT5...
    BlockLength  :  0xE9  (233)
    ERASE Blocks :  0x04  (4)
                Block Length     : 0x53 (83)
                Device Index     : 0x00
                   0             : 00040000-000403FF
                   1             : 000C0000-0013FFFF
                   2             : 00140000-004BFFFF
                   3             : 004C0000-0073FFFF
                   4             : 00740000-0147FFFF
                   5             : 00160000-0017FFFF
                   6             : 03200000-0387FFFF
                   7             : 0F080000-0F67FFFF
                   8             : 01480000-0243FFFF
                   9             : 02440000-025BFFFF
                Device Index     : 0x00
                Format Info      : 00000000000000080000000000000002000000640000000200000002000000010000000000000000
                Device Index     : 0x00
                Format Info      : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000
         3   FORMAT_PARTITION_BB5 0x19
                Device Index     : 0x00
                Format Info      : 000000000000000B0000000000000002000000640000000200000002000000010000000000000000
    ERASE_REQUEST_BB5 : 500A120B00030000040000000403FF120B000300000C00000013FFFF120B00030000140000004BFFFF120B000300004C00000073FFFF120B000300007400000147FFFF120B000300001600000017FFFF120B000300032000000387FFFF120B0003000F0800000F67FFFF120B000300014800000243FFFF120B00030002440000025BFFFF2C
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000800000000000000020000006400000002000000020000000100000000000000003E
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A00000001000000020000006400000002000000020000000100000000000000003B
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B00000000000000020000006400000002000000020000000100000000000000003B
    Total blocks to write : 300
    >>  CMT Rootkey Hash CERT : DSP0
    >>  CMT Rootkey Hash CERT : ISA+EXTDRV
    ImageFilename: rm813__14.26.ppm_v
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 025C0000-031FFFFF
    ERASE_REQUEST_BB5 : 5001120B000300025C0000031FFFFF60
    Total blocks to write : 53
    ImageFilename: rm813__14.26.image_v_059L2X6_009
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 03880000-0F07FFFF
                Device Index     : 0x00
    ERASE_REQUEST_BB5 : 5001120B000300038800000F07FFFF3F
    Total blocks to write : 220
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
              Num Bad Blocks    :  00000003
              Additional Bad    :  00000003
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:09
    Multi USB is Enabled...
    Skipping Phone Polling...
     Phone Flashing Done!!!
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Dec 2009
    GIALAI
    5250 flash ok
    Code:
     RM-684_11.0.008_prd.core.C00
    CMT Type : BB5
    Algorithm Sending Speed    : 13000000Hz
    Program Sending Speed      : 13000000Hz
    Number of Blocks :  364
    Entry Point:  0x273AAB
    Page Format : -1
    MAX PAGE : 0x00040000
     RM-684_11.0.008_prd.rofs2.V20
    CMT Type : BB5
    Number of Blocks :  99
    Entry Point:  0x00D7
    Page Format : -1
     RM684_10.0.011_002_000_U001.uda.fpsx
    CMT Type : BB5
    Number of Blocks :  23
    Entry Point:  0x00D1
    Page Format : -1
    2. Insert USB.
    BootFlashMode_DCT5
     BootRom Verified!
      1  SYSTEM_ASIC_ID 01
         ID DWORD    0 : 00000001
         ID DWORD    2 : 00010006
         ID DWORD    4 : 01051105
      2  EM_ASIC_ID 02
         ID DWORD    0 : 00000296
      3  EM_ASIC_ID 02
         ID DWORD    0 : 00000B22
      4  PUBLIC_ID 12
         ID DWORD    0 : 20200109
         ID DWORD    1 : 8AA70052
         ID DWORD    2 : 21E0A25D
         ID DWORD    3 : 99A7C668
         ID DWORD    4 : 0E0C8B34
      5  ASIC_MODE_ID 13
         Mode Id       : 00
      6  ROOT_KEY_HASH 14
         Hash          :  B8 C3 AD EC FC 99 7F CD 80 81 D3 DE AF 87 0B 8C
      7  ROM_ID 15
         CRC         0 : 4B9B7510
         CRC         1 : 3E691FF8
     START FLASHING
    RawLoaderExtract: RM-684_11.0.008_prd.core.C00
    RawLoaderExtract: Match Found ROOT_KEY_HASH
     RAW LOADER SENT...
    FAST PHONE....
     UPDATE AGENT SENT...
    BB5 ADL Loader Start Up... (Please Wait...)
    Found Nokia BB5 ADL Loader USB Generic..
    000485000413140010B8C3ADECFC997FCD8081D3DEAF870B8C13180214CA158EAEE7D8D7A5B2E4907CB6BD0A9C2794D992130B0407303539423657301313060F33353533373530343431323234393400
    Processing : RM-684_11.0.008_prd.core.C00
    Partition Block Found
      >> Spare                : FFFFFFFF
      >> Number of Partitions : 00000004
      >> Partition 1          : COPIEDOS
      >> Partition 2          : DEMANDONOS
      >> Partition 3          : FILESYSTEM
      >> Partition 4          : PMM
    Partition Complete : No Error - 0 (0x00)
    Erase Block Found
      >> Erasing area 0x00040000 - 0x00082FFF, Type: NAND, Subsystem: CMT
      >> Erasing area 0x00083400 - 0x003FFFFF, Type: NAND, Subsystem: CMT
      >> Erasing area 0x00400000 - 0x007FFFFF, Type: NAND, Subsystem: CMT
      >> Erasing area 0x00800000 - 0x00D5FFFF, Type: NAND, Subsystem: CMT
      >> Erasing area 0x00D60000 - 0x0A55FFFF, Type: NAND, Subsystem: CMT
      >> Formatting Active Partitions
    Erase Complete : No Error - 0 (0x00)
    Data Block Found : 364 Blocks
    >>  CMT Rootkey Hash CERT : SOS*UPDAPP
    >>  CMT Rootkey Hash CERT : SOS*ENO
    >>  CMT Rootkey Hash CERT : SOS*DSP0
    >>  CMT Rootkey Hash CERT : SOS*ISASW
    >>  CMT Rootkey Hash CERT : SOS+CORE
    >>  CMT Rootkey Hash CERT : SOS+ROFS1
    Continue Flash Complete : No Error - 0 (0x00)
    Processing : RM-684_11.0.008_prd.rofs2.V20
    Erase Block Found
      >> Erasing area 0x069A0000 - 0x0945FFFF, Type: NAND, Subsystem: CMT
    Data Block Found : 99 Blocks
    >>  CMT Rootkey Hash CERT : SOS+ROFS2
    Processing : RM684_10.0.011_002_000_U001.uda.fpsx
    Erase Block Found
      >> Erasing area 0x0A560000 - 0x0F47FFFF, Type: NAND, Subsystem: CMT
    Data Block Found : 23 Blocks
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:46
    Elapsed Time: 5 Seconds...
    SW: V ICPR72_10w29.2.2 18-10-10 RM-684 (c) Nokia
    IMEI: 355375044122494
    SIMLOCK TABLE :
                   SL3 Phone detected
     OK
     OK
     OK
     OK
     OK
     OK
    ERROR: Life timer Reset Failed
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Super Moderator TuệNguyễn's Avatar
    TP Hồ Chí Minh
    C5-00 flash USB chỉ với 15 giây
    Code:
    09:46:52 : 09:46:52 : AUTO SELECTED DEAD USB FLASHING...
    09:46:52 :
    09:46:52 : If Phone Booting does not Start in 5 Seconds,
    09:46:52 : Then Perform Steps 1, 2, 3 and 4...
    09:46:52 :
    09:46:52 : 1. Remove USB and Battery...
    09:46:52 : 2. Insert USB.
    09:46:52 : 3. Insert Battery. (Some phones boot automatically)
    09:46:52 : 4. Please Power on phone shortly...
    09:46:52 :
    09:46:59 : AdvanceFBox SendBootCodeEx
    09:46:59 : InitialiseBootstrap_DCT5 DIR
    09:46:59 : BootFlashMode_DCT5
    09:46:59 : READING BOOTROM
    09:46:59 :
    09:46:59 : BootFlashModeDCT5Ex Succeeded First Time
    09:46:59 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
    09:46:59 : Number of Sub Blocks 7 (0x07)
    09:46:59 :   1  SYSTEM_ASIC_ID 01
    09:46:59 :      Block Length  : 21  (15)
    09:46:59 :      BB ASIC Index : 0  (00)  CMT
    09:46:59 :      ID DWORD    0 : 00000003
    09:46:59 :      ID DWORD    1 : 00000226
    09:46:59 :      ID DWORD    2 : 00010007
    09:46:59 :      ID DWORD    3 : 600C1921
    09:46:59 :      ID DWORD    4 : 02031104
    09:46:59 :   2  EM_ASIC_ID 02
    09:46:59 :      Block Length  : 5  (05)
    09:46:59 :      ID DWORD    0 : 00000C35
    09:46:59 :   3  EM_ASIC_ID 02
    09:46:59 :      ID DWORD    0 : 00000C30
    09:46:59 :   4  PUBLIC_ID 12
    09:46:59 :      ID DWORD    0 : 08100213
    09:46:59 :      ID DWORD    1 : 1A990344
    09:46:59 :      ID DWORD    2 : C37526A9
    09:46:59 :      ID DWORD    3 : CC8C4AF0
    09:46:59 :      ID DWORD    4 : C90EFDBB
    09:46:59 :   5  ASIC_MODE_ID 13
    09:46:59 :      Block Length  : 2  (02)
    09:46:59 :      Mode Id       : 00
    09:46:59 :   6  ROOT_KEY_HASH 14
    09:46:59 :      Block Length  : 17  (11)
    09:46:59 :      Hash          :  91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
    09:46:59 :   7  ROM_ID 15
    09:46:59 :      Block Length  : 9  (09)
    09:46:59 :      CRC         0 : E693EF0D
    09:46:59 :      CRC         1 : AC22615B
    09:46:59 :
    09:46:59 : CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2nd.fg
    09:46:59 : Secondary Loader Sent....
    09:47:00 :
    09:47:00 : MCU_CONFIGURATION_RESPONSE_BB5:
    09:47:00 :  MessageID  : C1
    09:47:00 :  SubBlocks  : 06
    09:47:00 :  1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
    09:47:00 :    Block Length      : 0B
    09:47:00 :    BB ASIC Index     : CMT  00
    09:47:00 :    Device Type       : RAM  05
    09:47:00 :    Device Index      : 00
    09:47:00 :    Manufacturer Code : 0000 -> Flash
    09:47:00 :    Device ID         : 0000 -> Type not in database
    09:47:00 :    Extended/Fixed ID : 0000
    09:47:00 :    Revision ID       : 0000
    09:47:00 :  2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
    09:47:00 :    Device Type       : MMC  04
    09:47:00 :    Manufacturer Code : FFFF -> Flash
    09:47:00 :  3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
    09:47:00 :    Device Type       : NOR  00
    09:47:00 :    Manufacturer Code : 0020 ->
    09:47:00 :    Device ID         : 0040 -> Type not in database
    09:47:00 :    Revision ID       : 0031
    09:47:00 :  4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
    09:47:00 :    Device Index      : 01
    09:47:00 :    Manufacturer Code : 0000 -> SPANSION
    09:47:00 :    Device ID         : 0001 -> Type not in database
    09:47:00 :  5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
    09:47:00 :    Device Type       : MuxOneNAND  03
    09:47:00 :  6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
    09:47:00 :    Block Length      : 09
    09:47:00 :    Data              :
    09:47:00 :
    09:47:00 : SearchForBootstrap_DCT5  : No Error - 0 (0x00)
    09:47:00 : Flash Descriptor
    09:47:00 :    Size              : 10000000 (256 MB)
    09:47:00 :    VPP Info          : 0000
    09:47:00 :    Erase10s          : 1E
    09:47:00 :    Block1s           : 32
    09:47:00 :    BErase1s          : 02
    09:47:00 :    Reserved0         : 00
    09:47:00 :    Reserved1         : 00
    09:47:00 :    Reserved2         : 00
    09:47:00 :
    09:47:00 : CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XSR17_alg.fg
    09:47:00 : Algorithm Loader Sent...
    09:47:02 :
    09:47:02 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    09:47:02 : FUR control Ok
    09:47:02 :
    09:47:02 : START READING RPL DATA
    09:47:02 : IMEI: 353792040827573
    09:47:02 : Reading : NPC... OK!
    09:47:02 : Reading : CCC... OK!
    09:47:02 : Reading : HWC... OK!
    09:47:02 : Reading : R&D... OK!
    09:47:02 : RPL Backup was Successful...
    09:47:02 : Plain RPL saved to:
    09:47:02 : C:\AdvanceBox Turbo Flasher\Nokia\Backup\353792040827573\353792040827573_94702.rpl
    09:47:02 :
    09:47:02 : Pabub KEY Request
    09:47:02 : PhoneInfoRequest_BB5 (Asic Index 00 )
    09:47:02 : PHONE_INFO_RESPONSE_BB5
    09:47:02 :   PAPUB_KEYS_HASH_RESP_BB5 2A
    09:47:02 :     BB Asic Index   : 00
    09:47:02 : CMT PAPUBKEYS HASH:
    09:47:02 : D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
    09:47:02 : ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-645\
    09:47:02 : ImageFilename: rm645_071.005_prd.core.fpsx
    09:47:02 : Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    09:47:02 : Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
    09:47:02 : Certificate 1
    09:47:02 :   Name        : NPC
    09:47:03 :   ASIC Index  : CMT  0
    09:47:03 : Certificate 2
    09:47:03 :   Name        : CCC
    09:47:03 : Certificate 3
    09:47:03 :   Name        : HWC
    09:47:03 : Certificate 4
    09:47:03 :   Name        : R&D
    09:47:03 : STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    09:47:03 : STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    09:47:03 : ProcessPartitionInfo_DCT5...
    09:47:03 : Partition Info
    09:47:03 :     Partition Blocks :   1
    09:47:03 :      1   PARTITION_INFO_BB5
    09:47:03 :             BB ASIC Index     : 0x00 CMT
    09:47:03 :             Device Type       : 0x03 MuxOneNAND
    09:47:03 :             Device Index      : 0x00
    09:47:03 :             Partition Version : 00020000
    09:47:03 :             Spare             : FFFFFFFF
    09:47:03 :             Num Partitions    : 00000004
    09:47:03 :             Partition    1
    09:47:03 :               ID              : 00000003  COPIEDOS
    09:47:03 :               Attribute       : 00000002  RO
    09:47:03 :               Start Address   : 000A0000
    09:47:03 :               Size            : 030A0000
    09:47:03 :             Partition    2
    09:47:03 :               ID              : 00000004  DEMANDONOS
    09:47:03 :               Start Address   : 03140000
    09:47:03 :               Size            : 07D00000
    09:47:03 :             Partition    3
    09:47:03 :               ID              : 00000008  FILESYSTEM
    09:47:03 :               Attribute       : 00000001  RW
    09:47:03 :               Start Address   : 0AE40000
    09:47:03 :               Size            : 04800000
    09:47:03 :             Partition    4
    09:47:03 :               ID              : 0000000A  PMM
    09:47:03 :               Start Address   : 0F640000
    09:47:03 :               Size            : 003C0000
    09:47:03 : PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A0000030A000000000004000000020314000007D0000000000008000000010AE40000048000000000000A000000010F640000003C000036
    09:47:03 : PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    09:47:03 : ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    09:47:03 : StartErase_DCT5...
    09:47:03 : BlockLength  :  0x4F  (79)
    09:47:03 : ERASE Blocks :  0x02  (2)
    09:47:03 :      0   ERASE_AREA_BB5 0x12
    09:47:03 :             Block Length     : 0x1B (27)
    09:47:03 :                0             : 00020000-0003FFFF
    09:47:03 :                1             : 00060000-004DFFFF
    09:47:03 :                2             : 008E0000-0AE3FFFF
    09:47:03 :      1   FORMAT_PARTITION_BB5 0x19
    09:47:03 :             Block Length     : 0x2F (47)
    09:47:03 :             Format Info ID   : 0x02000000
    09:47:03 :             Format Info      : 000000000000000A0000000000000002000000640000000B00000002000000010000000000000000
    09:47:03 :
    09:47:03 : ERASE_REQUEST_BB5  : 5003120B000300000200000003FFFF120B00030000060000004DFFFF120B000300008E00000AE3FFFFCF
    09:47:03 :
    09:47:03 : FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B0000000200000001000000000000000033
    09:47:03 :
    09:47:03 : Successfully Erased...
    09:47:03 : Total blocks to write : 453
    09:47:03 : >>  CMT Rootkey Hash CERT :  ADA
    09:47:03 : >>  CMT Rootkey Hash CERT :  KEYS
    09:47:03 : >>  CMT Rootkey Hash CERT :  PRIMAPP
    09:47:04 : >>  CMT Rootkey Hash CERT :  RAP3NAND
    09:47:04 : >>  CMT Rootkey Hash CERT :  SOS+PMML
    09:47:04 : >>  CMT Rootkey Hash CERT :  PASUBTOC
    09:47:04 : >>  CMT Rootkey Hash CERT :  PAPUBKEYS
    09:47:04 : >>  CMT Rootkey Hash CERT :  GENIO_INIT
    09:47:04 : >>  CMT Rootkey Hash CERT :  SOS*UPDAPP
    09:47:04 : >>  CMT Rootkey Hash CERT :  SOS*DSP0
    09:47:04 : >>  CMT Rootkey Hash CERT :  LDSP
    09:47:04 : >>  CMT Rootkey Hash CERT :  SOS*ISASW
    09:47:04 : >>  CMT Rootkey Hash CERT :  SOS+CORE
    09:47:08 : >>  CMT Rootkey Hash CERT :  SOS+ROFS1
    09:47:14 : ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-645\
    09:47:14 : ImageFilename: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
    09:47:14 : StartErase_DCT5...
    09:47:14 : BlockLength  :  0x0E  (14)
    09:47:14 : ERASE Blocks :  0x01  (1)
    09:47:14 :      0   ERASE_AREA_BB5 0x12
    09:47:14 :             Block Length     : 0x0B (11)
    09:47:14 :             BB ASIC Index    : 0x00 CMT
    09:47:14 :             Device Type      : 0x03 MuxOneNAND
    09:47:14 :             Device Index     : 0x00
    09:47:14 :                0             : 0A040000-0AE3FFFF
    09:47:14 :
    09:47:14 : ERASE_REQUEST_BB5  : 5001120B0003000A0400000AE3FFFFE5
    09:47:14 :
    09:47:14 : Successfully Erased...
    09:47:14 : Total blocks to write : 5
    09:47:14 : >>  CMT Rootkey Hash CERT :  SOS+ROFS3
    09:47:14 : ImageFilename: rm645_071.005_16.01_Vietnam_prd.rofs2.fpsx
    09:47:14 :                0             : 06D40000-0A03FFFF
    09:47:14 :
    09:47:14 : ERASE_REQUEST_BB5  : 5001120B00030006D400000A03FFFFF9
    09:47:15 :
    09:47:15 : Successfully Erased...
    09:47:15 : Total blocks to write : 127
    09:47:15 : >>  CMT Rootkey Hash CERT :  SOS+ROFS2
    09:47:18 : ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-645\
    09:47:18 : ImageFilename: rm645_071.005_U000.000_prd.uda.fpsx
    09:47:18 : StartErase_DCT5...
    09:47:18 : BlockLength  :  0x0E  (14)
    09:47:18 : ERASE Blocks :  0x01  (1)
    09:47:18 :      0   ERASE_AREA_BB5 0x12
    09:47:18 :             Block Length     : 0x0B (11)
    09:47:18 :             BB ASIC Index    : 0x00 CMT
    09:47:18 :             Device Type      : 0x03 MuxOneNAND
    09:47:18 :             Device Index     : 0x00
    09:47:18 :                0             : 0AE40000-0F63FFFF
    09:47:18 :
    09:47:18 : ERASE_REQUEST_BB5  : 5001120B0003000AE400000F63FFFF80
    09:47:18 :
    09:47:18 : Successfully Erased...
    09:47:18 : Total blocks to write : 6
    09:47:19 : ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-645\
    09:47:19 : ImageFilename: RM645_ENO_10wk48v0.001.fpsx
    09:47:19 : StartErase_DCT5...
    09:47:19 : BlockLength  :  0x0E  (14)
    09:47:19 : ERASE Blocks :  0x01  (1)
    09:47:19 :      0   ERASE_AREA_BB5 0x12
    09:47:19 :             Block Length     : 0x0B (11)
    09:47:19 :             BB ASIC Index    : 0x00 CMT
    09:47:19 :             Device Type      : 0x03 MuxOneNAND
    09:47:19 :             Device Index     : 0x00
    09:47:19 :                0             : 004E0000-008DFFFF
    09:47:19 :
    09:47:19 : ERASE_REQUEST_BB5  : 5001120B000300004E0000008DFFFF05
    09:47:19 :
    09:47:19 : Successfully Erased...
    09:47:19 : Total blocks to write : 13
    09:47:19 : >>  CMT Rootkey Hash CERT :  SOS*ENO
    09:47:19 : ContinueFlash_DCT5 Complete
    09:47:19 : Continue Flash Complete :  : No Error - 0 (0x00)
    09:47:19 : Status_BB5 STATUS_REQUEST_BB5..
    09:47:19 :     1  Sub Block ID      :  15 STATUS_NAND_OK_BB5
    09:47:19 :           Block Length      :  0F
    09:47:19 :           BB ASIC Index     :  00
    09:47:19 :           Device Type       :  03
    09:47:19 :           Device Type       :  00
    09:47:19 :           Num Bad Blocks    :  00000001
    09:47:19 :           Additional Bad    :  00000001
    09:47:19 :           Correctable ECC   :  00000000
    09:47:19 : FlashInfo.RestartMode : 1
    09:47:19 :
    09:47:19 : Flashing Done...
    09:47:19 : Total Flashing Time (Erase + Flashing) : 00:00:15
    09:47:19 : (Booting time is NOT Included)
    09:47:20 :
    09:47:20 : Waiting for Phone to Start-Up..(Max 150 seconds)
    09:47:20 :
    09:47:31 :
    09:47:31 : SW: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
    09:47:31 : IMEI: 353792040827573
    09:47:31 : CONFIG KEY    :  0000000000000000
    09:47:31 : PROVIDER KEY  :  2440700000000000
    09:47:31 : NETWORK NAME  :  Nokia Default;Finland
    09:47:31 : LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
    09:47:32 : SIMLOCK TABLE :
    Unlock-repair boot-repair imei-repair emmc-nạp Tiếng Việt all smart phone
    ĐC: 159/7/2 Đường TTH07 Phường Tân Thới Hiệp Q12 TPHCM
    ĐT: 0903135569 - Skype: tuenguyen.79
    TP Hồ Chí Minh
    N101 flash ok
    Code:
    Booting Phone...
    CPU ID Response: A200341100
    CPU Type: XG110 2.1B
    Phone Booted at after First attempt...
                      TIME STARTS HERE
    Sending PBL 19456 bytes...
    PBL Successfully Sent...
    Sending SBL 65024 bytes...
    SBL Successfully Sent...
    Flash Chip Manufacturer: Samsung Electronics Corp.
    Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
    Extended Information: Multiple Bank / Burst / 1.8v
    Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.650
     FIRMWARE Image Found...
    Number of Sections: 03
    FIRMWARE Certificate Block Sent Successfully...
     Processing Section 01 of 03
    FIRMWARE Erase Block: 0x00000000~0x0001FFFE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Preparing Data Blocks...
    Data Size: 24576 bytes
    Data Checksum: F5BE
    Uploading Data Blocks to phone...
    FIRMWARE Data Blocks uploaded to phone...
     Processing Section 02 of 03
    FIRMWARE Erase Block: 0x00800000~0x00BFFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 4128768 bytes
    Data Checksum: D598
     Processing Section 03 of 03
    FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 1697536 bytes
    Data Checksum: 047E
    Start Data Verification... (Please wait)
    Data Verification Successful...
    Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.65mr
     PPM Image Found...
    Number of Sections: 01
    PPM Certificate Block Sent Successfully...
     Processing Section 01 of 01
    PPM Erase Block: 0x00100000~0x006109FE
    Start Erasing...
    Block Erase Done...
    Data Size: 5310976 bytes
    Data Checksum: 4B0D
    PPM Data Blocks uploaded to phone...
    Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai06.65mr
     CONTENT Image Found...
    CONTENT Certificate Block Sent Successfully...
    CONTENT Erase Block: 0x00E60000~0x00F0E53E
    Start Erasing...
    Block Erase Done...
    Data Size: 714048 bytes
    Data Checksum: 3ED3
    CONTENT Data Blocks uploaded to phone...
    Exit Flash Mode Done...
    Time Elapse : 00:04:13
        You must Factory Reset the phone to enable the
       ringtones and other  customized settings to work
     Waiting For Phone to go Online...
     5,  4,  3,  2,  1...
    MCU: V 06.65 07-11-11 RM-769 (c) Nokia
    IMEI: 359299049566420
    Product Serial Number: 5A5C9C3AH
    Product Code         : 059H0D7
    Module Code          : 0204883
    Basic Production Code: 059F6L6
    PPM SW Version       : V 06.65 07-11-11 RM-769 (c) Nokia MR
    ADSP Version         : p V 06.65\n07-11-11\nRM-769\n(c) NMP\nmr
    MCU SW Version       : V 06.65 07-11-11 RM-769 (c) Nokia
    HW Version           : 1000
    UEM Version          : 1328
    UPP Version          : 8850
    LCD Version          : TPO:BARACOAv90 HX5081
      ********** SIMLOCK INFO  **********
    CONFIG_DATA  : 0010100000000000
    PROFILE_BITS : 0000000000040002
    ASIC         : 11
    PROVIDER     : Default Test Operator
    ST_LCD_TEST               : PASSED
     OK
     OK
     OK
     OK
     OK
     OK
    Dec 2009
    GIALAI
    N81 flash OK
    Code:
    ATF Software Version v8.00
    ATF Box FBUS Flash Started...
                 Basic Phone Information
    MCU Version: V 06wk41v56.1 18-04-08 RM-223 (c) Nokia
    IMEI Plain : 356994017140488
    IMEI Spare : A356994017140480
    IMEI SV    : 33569940171404821F
    Phone Model: Nokia N81
    Category   : Classic Phone
    Phone Type : RM-223
    PM 120 Found...
    PM 308 Found...
     Simlock Data Saved to :  C:\AdvanceBox Turbo Flasher\Nokia\Backup\356994017140488\SL2_certificate_V 06wk41v56.1 18-04-08 RM-223 (c) Nokia_356994017140488_Not Locked_120043.pm
    Changing MODE : FLASH
    AdvanceBox SendBootCodeEx
    BootFlashMode_DCT5
                      TIME STARTS HERE
      1  SYSTEM_ASIC_ID 01
         ID DWORD    4 : 01021103
      2  EM_ASIC_ID 02
         ID DWORD    0 : 00000295
      3  EM_ASIC_ID 02
      4  PUBLIC_ID 12
         ID DWORD    0 : 0EE00005
         ID DWORD    1 : 5AC80158
         ID DWORD    2 : D6A37021
         ID DWORD    3 : F6001FD8
         ID DWORD    4 : 79FCBE06
      5  ASIC_MODE_ID 13
         Mode Id       : 00
      6  ROOT_KEY_HASH 14
         Hash          :  9A 28 E1 19 03 3B 91 D1 4D 22 83 8C 86 D0 D5 3C
      7  ROM_ID 15
         CRC         0 : A8C1D671
         CRC         1 : 3E691FF8
    Checksum           77
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
    Boot File - Version  011.034.00
    Boot File - Revision 0x0002 (2)
    eBB5ProtocolType == New
    PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
    PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
    TransmissionTypeRequest_DCT5_NewProtocol
    TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
    FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
    Transmission Type Request Sent...
    ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
     MessageID  : 06
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Manufacturer Code : 0400 -> Flash
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 01
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0121
       Block Length      : 09
       Data              : XSR 1.5
     Checksum   : 35
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0030 ExtID :0000 RevID :0121
    Flash Descriptor
       Device ID         : 0030
       Revision ID       : 0000
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg
    Algorithm File - Version  011.034.00
    Algorithm File - Revision 0x0002 (2)
    Algo Loader Sent...
    SendCodeStart_NewProtocol :
    SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
    SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
    FUR control Ok...
    VPP Enabled by Software
    Using Internal VPP
    FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
    Pabub KEY Request
       BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
    E70C21157D5AB5AF61AAD376910751FB06D6E9FD
    Reading : NPC (CMT)
    OK
    Reading : VARIANT (CMT)
     VARIANT :  Empty
    Reading : CCC (CMT)
    OK
    Reading : HWC (CMT)
    OK
    Reading : R&D (CMT)
    OK
    Reading : PARTNERC (CMT)
     PARTNERC :  Empty
    Reading : MDM_KEYS (CMT)
     MDM_KEYS :  Empty
    FINISHED READING RPL DATA
     RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\356994017140488\356994017140488_120053.rpl
     C:\Users\MANH CUONG\Desktop\RM223_21.0.010 tv\RM223_21.0.010 tv\RM223_21.0.010_prd.C00
    CMT Type                   :  BB5
    CMT Algorithm              :  XSR 1.5
    Secondary Sending Speed    :  650000 Hz
    Algorithm Sending Speed    :  6500000 Hz
    Program Sending Speed      :  6500000 Hz
    Message Reading Speed      :  98000 Hz
    Number of Blocks           :  421
    Entry Point                :  0x1FF8FC
    Page Format                :  128K
    Maximum Page Size          :  0x00020000
    VBATT Powering Down <<<<
    VBATT Powering Up   >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    BootFlashMode_DCT5
                      TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded after 3 Attempts
      1  SYSTEM_ASIC_ID 01
      2  EM_ASIC_ID 02
      3  EM_ASIC_ID 02
      4  PUBLIC_ID 12
      5  ASIC_MODE_ID 13
         Mode Id       : 00
      6  ROOT_KEY_HASH 14
      7  ROM_ID 15
         CRC         0 : A8C1D671
         CRC         1 : 3E691FF8
    Checksum           77
     MessageID  : 06
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 01
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0121
       Block Length      : 09
       Data              : XSR 1.5
     Checksum   : 35
    SendAlgoCode_DCT5..
    Flash Descriptor
       Device ID         : 0030
       Revision ID       : 0000
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    Algo Loader Sent...
    FUR control Ok...
    Using Internal VPP
    Pabub KEY Request
       BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
    Certificate 1
      ASIC Index  : CMT  0
    Certificate 2
      ASIC Index  : CMT  0
    Certificate 3
      ASIC Index  : CMT  0
    Certificate 4
      ASIC Index  : CMT  0
    Partition Info
                Device Index      : 0x00
                Spare             : FFFFFFFF
                Num Partitions    : 00000005
                Partition    1
                  Start Address   : 00080000
                Partition    2
                  Start Address   : 01700000
                Partition    3
                  Start Address   : 05F80000
                Partition    4
                  ID              : 00000009  FILESYSTEM1
                  Start Address   : 079E0000
                Partition    5
    PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000010000FFFFFFFF000000050000000300000002000800000168000000000004000000020170000004880000000000080000000105F8000001A600000000000900000001079E0000001600000000000A0000000107B4000000160000A4
    StartErase_DCT5...
    BlockLength  :  0x80  (128)
                Device Index     : 0x00
                   0             : 00040000-00082FFF
                   1             : 00083400-0087FFFF
                   2             : 00B80000-05F7FFFF
                Device Index     : 0x00
                Format Info ID   : 0x00000000
                Format Info      : 000000000000000A0000000000000002000000640000000300000001000000010000000000000000
                Device Index     : 0x00
                Format Info      : 00000000000000090000000000000002000000640000000300000001000000010000000000000000
    Erase_SendEraseBlock_BB5_NAND
    Task in Progress... Please Wait...
    Erase_SendFormatPartition_BB5_NAND
    Time Taken to Erase : 00:00:01
    Flashing Speed: 5.00 Mhz (AUTO)
    Processing  : RM223_21.0.010_prd.C00
    Total blocks to write : 421
    >>  CMT Rootkey Hash CERT : SOS*CORE
    Time Taken to Flash  : 00:00:29
     C:\Users\MANH CUONG\Desktop\RM223_21.0.010 tv\RM223_21.0.010 tv\RM223_21.0.010_prd_1601.V16
    CMT Type                   :  BB5
    Number of Blocks           :  213
    Entry Point                :  0x011A
    Page Format                :  128K
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 03730000-05F7FFFF
    Time Taken to Erase : 00:00:00
    Processing  : RM223_21.0.010_prd_1601.V16
    Total blocks to write : 213
    >>  CMT Rootkey Hash CERT : SOS+ROFX
    Time Taken to Flash  : 00:00:17
     C:\Users\MANH CUONG\Desktop\RM223_21.0.010 tv\RM223_21.0.010 tv\RM223_21.0.010_003_000_U05_uda.fpsx
    CMT Type                   :  BB5
    Entry Point                :  0x00B9
    Page Format                :  128K
    Maximum Page Size          :  0x00013200
    StartErase_DCT5...
    BlockLength  :  0x1D  (29)
                Device Index     : 0x00
                   0             : 05F80000-079DFFFF
         1   ERASE_AREA_BB5 0x13
                Block Length     : 0x0D (13)
    Processing  : RM223_21.0.010_003_000_U05_uda.fpsx
    Time Taken to Flash  : 00:00:00
    Total Flash Write Time (Flashing Only) : 00:00:48
    Total Flashing Time (Booting + Erase + Flashing) : 00:00:53
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
    Waiting for Phone to Go Online...
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    MCU Version: V 06wk41v62.4 04-12-08 RM-223 (c) Nokia
    IMEI SV    : 33569940171404823F
    Phone Type : RM-223
                Extended Phone Information
    Product Serial Number: CMG111296
    Product Code         : 0550094
    Module Code          : 0203265
    Basic Production Code: 0541202
    Long Production SN   : 0
    MCU SW Version       : V 06wk41v62.4 04-12-08 RM-223 (c) Nokia
    HW Version           : 0542
    RFIC Version         : 17141715
    DSP Version          : bruce_mc.ICPR62_08w28
    AHNE Version         : 11
    APE SW Core Version  : 21.0.010
    Variant Version      : 21.0.01021.0.010_16.01
    APE Test Version     : rm223_ENO_x_2007wk24v0.070
    RETU Version         : 15
    TAHVO Version        : 22
    APE HW Version       : 256
    APE ADSP SW Version  : 256
    Wireless LAN ID      : 00:1C:D4:F5:BB:8B
    Bluetooth ID         : 00:1C:D4:E6:79:4B
    CS Type              : GSM850, GSM900, GSM1800, GSM1900, WCDMA I
                   Simlock Information
    SIMLOCK TABLE :
    SIMLOCK_TYPE             : PA_SL2
    SECURITY_CODE          : 12345
    PHONE_MODE              : LOCAL
    DCC ID                          : NOT USED
     OK
     OK
     OK
     OK
     OK
     OK
    Life timer data is not yet used...
    Life timer: ----:--
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Dec 2009
    GIALAI
    flash N8 OK
    Code:
    Number of Image Files: 5
     RM-596_022.014_79.92_prd.core.fpsx
    CMT Type : BB5
    Number of Blocks :  514
    Entry Point:  0x01FC
    Page Format : -1
     RM-596_022.014_C02.01_SEAP_79.92_prd.rofs3.fpsx
    CMT Type : BB5
    Entry Point:  0x00EE
    Page Format : -1
    MAX PAGE : 0x00003200
     RM-596_022.014_19.01_Vietnam_79.92_prd.rofs2.fpsx
    CMT Type : BB5
    Number of Blocks :  136
    Entry Point:  0x00F4
    Page Format : -1
     RM-596_022.014_U03.01_79.92.uda.fpsx
    CMT Type : BB5
    Number of Blocks :  383
    Entry Point:  0x00F4
    Page Format : -1
     RM596_APE_ONLY_ENO_11w15_v0.148.fpsx
    CMT Type : BB5
    Number of Blocks :  18
    Entry Point:  0x00F4
    Page Format : -1
    [Nokia N8-00 USB Phonet]: Opening Connection
    [Nokia N8-00 USB Phonet]: Port opened OK!
    SW: V 92_11w25.1 01-07-11 RM-596 (c) Nokia
    IMEI: 356237xxxxxxxxxxx
    SIMLOCK TABLE :
    Please Wait...
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\35623704xxxxxxxxxxxxx\USB_FULL_BACKUP_V 92_11w25.1 01-07-11 RM-596 (c) Nokia_35623xxxxxxxxxx5_Not Locked_95235.pm
    Reading battery value  : 3794 mV
    Rebooting Phone...
    2. Insert USB.
    BootFlashMode_DCT5
     BootRom Verified!
      1  SYSTEM_ASIC_ID 01
      2  EM_ASIC_ID 02
      3  EM_ASIC_ID 02
      4  PUBLIC_ID 12
         ID DWORD    0 : 0D800211
         ID DWORD    1 : 6DD40344
         ID DWORD    2 : 5DB14602
         ID DWORD    3 : 6BE1E642
         ID DWORD    4 : 08BFDAA5
      5  ASIC_MODE_ID 13
         Mode Id       : 00
      6  ROOT_KEY_HASH 14
      7  ROM_ID 15
         CRC         0 : E693EF0D
         CRC         1 : AC22615B
     START FLASHING
    RawLoaderExtract: RM-596_022.014_79.92_prd.core.fpsx
     MessageID  : C1
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 01
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Device ID         : 0050 -> Type not in database
       Revision ID       : 0031
       Block Length      : 09
       Data              :
    Flash Descriptor
       Device ID         : 0050
       Revision ID       : 0000
       Size              : 20000000 (512 MB)
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    FUR control Ok
    IMEI: 356237042283505
    Reading : PARTNERC... OK!
     Plain RPL saved to:
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\35623xxxxxxxxxxx\3562370xxxxxxxxxxxxxxx_95245.rpl
    Pabub KEY Request
        BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
     D172C32473AE199B213465ABB3853246F9631231
    ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-596\
    ImageFilename: RM-596_022.014_79.92_prd.core.fpsx
    Certificate 1
      ASIC Index  : CMT  0
    Certificate 2
      ASIC Index  : CMT  0
    Certificate 3
      ASIC Index  : CMT  0
    Certificate 4
      ASIC Index  : CMT  0
    Certificate 5
      ASIC Index  : CMT  0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B
    Partition Info
                Device Index      : 0x00
                Spare             : FFFFFFFF
                Partition    1
                Partition    2
                  Start Address   : 02E60000
                Partition    3
                  Start Address   : 0EA00000
                Partition    4
                  Start Address   : 1F000000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF0000000400000003000000020014000002D20000000000040000000202E600000BB2000000000008000000010EA00000106000000000000A000000011F0000000040000052
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 00040000-0007FFFF
                   1             : 000C0000-008BFFFF
                   2             : 00DC0000-0E97FFFF
                Device Index     : 0x00
                Format Info ID   : 0x03000000
                Format Info      : 000000000000000A0000000000000002000000640018000000000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5003120B000300000400000007FFFF120B000300000C0000008BFFFF120B00030000DC00000E97FFFF7F
    FORMAT_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000000200000064001800000000000200000001000000000000000025
    Total blocks to write : 514
    ImageFilename: RM-596_022.014_C02.01_SEAP_79.92_prd.rofs3.fpsx
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 0DA80000-0E97FFFF
    ERASE_REQUEST_BB5 : 5001120B0003000DA800000E97FFFF86
    ImageFilename: RM-596_022.014_19.01_Vietnam_79.92_prd.rofs2.fpsx
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 09F40000-0DA7FFFF
    ERASE_REQUEST_BB5 : 5001120B00030009F400000DA7FFFF2F
    Total blocks to write : 136
    ImageFilename: RM-596_022.014_U03.01_79.92.uda.fpsx
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 0EA00000-1EFFFFFF
    ERASE_REQUEST_BB5 : 5001120B0003000EA000001EFFFFFF15
    Total blocks to write : 383
    ImageFilename: RM596_APE_ONLY_ENO_11w15_v0.148.fpsx
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 008C0000-00DBFFFF
    ERASE_REQUEST_BB5 : 5001120B000300008C000000DBFFFF79
    Total blocks to write : 18
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
              Num Bad Blocks    :  00000006
              Additional Bad    :  00000006
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:34
    Elapsed Time: 10 Seconds... (Installing Drivers)
    Elapsed Time: 15 Seconds... (Installing Drivers)
    IMEI: 35623xxxxxxxxxxx
    SIMLOCK TABLE :
                   SL3 Phone detected
     OK
     OK
     OK
     OK
     OK
     OK
     OK
    Changing Phone Mode...
    (Wait for 10 seconds)
    Successfully set to : Normal
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Dec 2009
    GIALAI
    Code:
     rm614__07.20.mcusw
    CMT Type : BB5
    Number of Blocks :  528
    Entry Point:  0x01F2
    Page Format : -1
     rm614__07.20.ppm_v
    CMT Type : BB5
    Number of Blocks :  125
    Entry Point:  0x0113
    Page Format : -1
     rm614__07.20.image_v_0598884
    CMT Type : BB5
    Number of Blocks :  228
    Entry Point:  0x0147
    Page Format : -1
    IMEI: 353760048529905
    SIMLOCK TABLE :
    Please Wait...
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\353760048529905\USB_FULL_BACKUP_V 04.45 04-08-10 RM-614 (c) Nokia_353760048529905_Not Locked_23818.pm
    Reading battery value  : 4064 mV
    Rebooting Phone...
    2. Insert USB.
    BootFlashMode_DCT5
     BootRom Verified!
      1  SYSTEM_ASIC_ID 01
      2  EM_ASIC_ID 02
      3  PUBLIC_ID 12
         ID DWORD    1 : 00899375
         ID DWORD    2 : 1923C94D
         ID DWORD    3 : 3E740C03
         ID DWORD    4 : CFB39110
      4  ASIC_MODE_ID 13
         Mode Id       : 00
      5  ROOT_KEY_HASH 14
      6  ROM_ID 15
         CRC         0 : DE56D582
         CRC         1 : BDDE7A3A
     START FLASHING
    RawLoaderExtract: rm614__07.20.mcusw
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_usb2nd.fg
     MessageID  : C1
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 01
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0431
       Block Length      : 09
       Data              :
    Flash Descriptor
       Device ID         : 0030
       Revision ID       : 0000
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_XSR16_usbalg.fg
    FUR control Ok
     Plain RPL saved to:
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\353760048529905\353760048529905_23827.rpl
    Pabub KEY Request
        BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
    ImagePath: D:\Flash file\File nokia\C3-00 RM-614\07.20\
    ImageFilename: rm614__07.20.mcusw
    Certificate 1
      ASIC Index  : CMT  0
    Certificate 2
      ASIC Index  : CMT  0
    Certificate 3
      ASIC Index  : CMT  0
    Certificate 4
      ASIC Index  : CMT  0
    Certificate 5
      ASIC Index  : CMT  0
    Partition Info
                Device Index      : 0x00
                Spare             : FFFFFFFF
                Partition    1
                Partition    2
                Partition    3
                Partition    4
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200020000025E0000000000080000000102A0000004B400000000000A0000000107540000006000000000000B0000000107B40000001800000D
    StartErase_DCT5...
                Device Index     : 0x00
                Device Index     : 0x00
                Device Index     : 0x00
    ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B00030000020000000203FF120B00030000060000012FFFFF120B0003000130000001DFFFFF120B00030002600000029FFFFF11
    Total blocks to write : 528
    ImageFilename: rm614__07.20.ppm_v
    StartErase_DCT5...
                Device Index     : 0x00
    Total blocks to write : 125
    ImageFilename: rm614__07.20.image_v_0598884
    StartErase_DCT5...
                Device Index     : 0x00
                Device Index     : 0x00
    Total blocks to write : 228
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
    Flashing Done...
    Elapsed Time: 20 Seconds...
    Elapsed Time: 25 Seconds...
    Elapsed Time: 30 Seconds...
    Elapsed Time: 35 Seconds...
    Elapsed Time: 40 Seconds...
    Elapsed Time: 45 Seconds...
    Elapsed Time: 50 Seconds...
    Elapsed Time: 55 Seconds...
    Elapsed Time: 60 Seconds...
    Elapsed Time: 65 Seconds...
    SW: V 07.20 29-10-10 RM-614 (c) Nokia
    SIMLOCK TABLE :
                   SL3 Phone detected
     OK
     OK
     OK
     OK
     OK
     OK
     OK
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    TP Hồ Chí Minh
    nokia 311 flash ok
    Code:
    BootFlashMode_DCT5
    READING BOOTROM
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96  (0x60) bytes returned
      1  SYSTEM_ASIC_ID 01
         ID DWORD    4 : 03042108
      2  EM_ASIC_ID 02
      3  EM_ASIC_ID 02
      4  PUBLIC_ID 12
         ID DWORD    0 : 58560080
         ID DWORD    1 : FFFB7C40
         ID DWORD    2 : 2C32B90C
         ID DWORD    3 : 44EF691C
         ID DWORD    4 : A9C3DB30
      5  ASIC_MODE_ID 13
         Mode Id       : 00
      6  ROOT_KEY_HASH 14
         Hash          :  6D 95 6B 2D 26 FE C3 C7 84 E2 16 49 2B 7C C9 0A
      7  ROM_ID 15
         CRC         0 : 2CAC45E2
         CRC         1 : 1CB478AF
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg
     MessageID  : C1
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 01
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0241
       Block Length      : 09
       Data              : XSR 1.6
    Flash Descriptor
       Device ID         : 0040
       Revision ID       : 0000
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg
    FUR control Ok
    IMEI: 354133058488462
    NPC CERTIFICATE INFORMATION (CMT):
    IMEI           : 345310385844826
    PRODUCT CODE   : 059M475
    WLAN ID        : 0C:C6:6A:A7:E0:6E
    BLUETOOTH ID   : 0C:C6:6A:A7:44:2E
    PUBLIC_ID      : 58560080FFFB7C402C32B90C44EF691CA9C3DB30
    PAPUB_KEYS_HASH: A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28
    CCC CERTIFICATE INFORMATION (CMT):
    HWC CERTIFICATE INFORMATION (CMT):
     Plain RPL saved to:
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\354133058488462\354133058488462_82637.rpl
    Pabub KEY Request
        BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
    ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-714\
    ImageFilename: rm714__03.81.mcusw
    Certificate 1
      ASIC Index  : CMT  0
    Certificate 2
      ASIC Index  : CMT  0
    Certificate 3
      ASIC Index  : CMT  0
    Certificate 4
      ASIC Index  : CMT  0
    Partition Info
                Device Index      : 0x00
                Spare             : FFFFFFFF
                Partition    1
                Partition    2
                  Start Address   : 04480000
                Partition    3
                Partition    4
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF0000000400000003000000020014000003D000000000000800000001044800000AC000000000000A000000010F080000006000000000000B000000010F680000003000003C
    StartErase_DCT5...
                Device Index     : 0x00
                   4             : 00740000-0173FFFF
                   6             : 03E40000-0447FFFF
                   8             : 01740000-02ABFFFF
                   9             : 02AC0000-02F3FFFF
                Device Index     : 0x00
                Device Index     : 0x00
                Device Index     : 0x00
    ERASE_REQUEST_BB5  : 500A120B00030000040000000403FF120B000300000C00000013FFFF120B00030000140000004BFFFF120B000300004C00000073FFFF120B000300007400000173FFFF120B000300001600000017FFFF120B00030003E400000447FFFF120B0003000F0800000F67FFFF120B0003000174000002ABFFFF120B00030002AC000002F3FFFFE7
    Total blocks to write : 325
    >>  CMT Rootkey Hash CERT : PAPUBKEYS [A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28]
    ImageFilename: rm714__03.81.ppm_v
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 02F40000-03E3FFFF
    ERASE_REQUEST_BB5  : 5001120B00030002F4000003E3FFFF04
    Total blocks to write : 101
    ImageFilename: rm714__03.81.image_v_059F7M5
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 04480000-0F07FFFF
                Device Index     : 0x00
    ERASE_REQUEST_BB5  : 5001120B000300044800000F07FFFF7E
    Total blocks to write : 639
    STATUS_REQUEST_BB5...
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
              Num Bad Blocks    :  00000002
              Additional Bad    :  00000002
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:14
    SW: V 03.81 18-06-12 RM-714 (c) Nokia
    SIMLOCK TABLE :
    SECURITY_CODE          : 2221994
                   SL3 Phone detected
     OK
     OK
     OK
     OK
     OK
     OK
     OK
  1. Trả lời: 43
    Bài viết cuối: 07-08-2014, 09:15
  2. Trả lời: 91
    Bài viết cuối: 13-08-2013, 17:42
  3. Trả lời: 2
    Bài viết cuối: 27-09-2012, 17:43
  4. Trả lời: 31
    Bài viết cuối: 02-11-2011, 15:23
  5. Trả lời: 7
    Bài viết cuối: 29-01-2011, 20:26
