Trang 8 của 9 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 CuốiCuối
Kết quả 71 tới 80 của 87
    Thành viên mới taki7610's Avatar
    Aug 2007
    NOKIA N9 Treo Flash Ok !
    Code:
    Number of Image Files: 2
    (Mass Memory File Detected)
    Processing Image File :
     DFL61_HARMATTAN_40.2012.21-3.280.04.1_PR_LEGACY_280_ARM_RM-696_PRD_signed.bin
    CMT Type : MAEMO/MEEGO
     DFL61_HARMATTAN_40.2012.21-3.280.1_EMMC_280.bin
    C:\AdvanceBox Turbo Flasher\Logs\flasher.exe
     -F DFL61_HARMATTAN_40.2012.21-3.280.04.1_PR_LEGACY_280_ARM_RM-696_PRD_signed.bin
    C:\Program Files (x86)\Nokia\Phoenix\Products\RM-696\
     -F DFL61_HARMATTAN_40.2012.21-3.280.04.1_PR_LEGACY_280_ARM_RM-696_PRD_signed.bin -F DFL61_HARMATTAN_40.2012.21-3.280.1_EMMC_280.bin
                 BB5 MEEGO / HARMATTAN FLASHER
    1. Turn OFF Phone and wait 10 Seconds...
    2. Connect the USB Cable to the PHONE Micro USB Port
    3. Connect the USB Cable to the PC USB Port
    TIPS & INFORMATION:
     1. To Turn OFF the Phone, PRESS and HOLD the POWER
        button for at least 10 Seconds...
     2. Battery Charging will still work on "DEAD" Phones.
     3. Factory Reset will make Flashing 15 minutes longer
        and it will Totally Erase the User Data and Remove
        the Phone Lock + Security Code as well...
     4. Skip ADL Chk will Cold Flash the Device.
    Waiting For Phone on USB PORT/s...
    REQUIRED MODE: BOOTROM MODE
    Sending PRIMARY-BOOT: SUCCESSFUL!
    Sending SECONDARY-BOOT: SUCCESSFUL!
             SECURE USER DATA ERASING IN PROGRESS
        Secure Data Erasing takes about 15 MINUTES...
         DO NOT DISCONNECT THE PHONE!!! JUST WAIT...
    Estimated time to Finish Erasing: 19:51:20 (24-h Time Format)
    Battery Voltage Test: PASSED
     Ready to Flash Images to Device...
    Processing Image: cert-sw
    Processing Image: cmt-2nd
    Processing Image: cmt-algo
    Processing Image: cmt-mcusw
    Processing Image: xloader
    Processing Image: secondary
    Processing Image: kernel
    Processing Image: rootfs
    Processing Image: mmc
     All Images were Succssfully Uploaded!
     Software Update Done
    []: Found 1 active devices.
    [Nokia N900 USB Phonet]: Opening Connection
    [Nokia N900 USB Phonet]: Port opened OK!
    Rebooting Phone...
    Total Flashing Time (Erase + Flashing) : 00:19:38
    (Booting time is NOT Included)
    Phone is not Connected OR it is not in the
    Required Mode...
     Reboot the Phone and Enable "PC Suite" Mode
    Life timer data is not yet used...
    Life timer: ----:--
    Service Repair Unlock Phone - 0932688118 ( HCM )
    Thành viên chính thức phung77's Avatar
    Oct 2009
    585 TRẦN HƯNG ĐẠO-PHAN THIẾT
    asha 205 flash ok
    rm862__03.19.mcusw
    rm862__03.19.ppm_v
    rm862__03.19.image_v_059Q094
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    Infineon USB Boot: F00A1FB300020303010100FF
    Sending PBL...
    PBL Successfully Sent...
    Sending SBL...
    SBL Successfully Sent...
    Setting Transmission Speed Done...
    Flash Chip Manufacturer: Intel Electronics Corp.
    Flash Boot Successful...
    Unique Data: 1220040294082820
    Original Product Code: 059Q0Q2
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : NPC... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\355488051515706\3554880515157 06_93854.rpl
    Certificate Block Saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\355488051515706\3554880515157 06_CERTIFICATE_4A0EC2B1.bin
    PM Block Saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\355488051515706\3554880515157 06_PMM_PROT_10A8A3FB.bin
    Security Code: 12345
    Data Sections : 04
    Current File : rm862__03.19.mcusw
    Compile Name: rm862__03.19.mcusw_ebl_psi.fls
    Image Type : Main Firmware
    Data Size : 26217864 Bytes
    Sending Certificate Block
    FIRMWARE Certificate Block Sent Successfully...
    Processing Section 01
    FIRMWARE Erase Block: 0x40000000~0x4001FFFE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Preparing Data Blocks...
    Data Size: 131072 bytes
    Data Checksum: B10A
    Uploading Data Blocks to phone...
    Block Write Successful...
    FIRMWARE Data Blocks uploaded to phone...
    Processing Section 02
    FIRMWARE Erase Block: 0x40040000~0x4005FFFE
    Start Erasing...
    Block Erase Done...
    Data Checksum: 7A56
    Processing Section 03
    FIRMWARE Erase Block: 0x40060000~0x4015FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 1048576 bytes
    Data Checksum: DD7C
    Processing Section 04
    FIRMWARE Erase Block: 0x40280000~0x41A3FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 24903680 bytes
    Data Checksum: C132
    Processing Section 05
    FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
    Start Erasing...
    Block Erase Done...
    Data Verification Successful...
    Data Sections : 01
    Current File : rm862__03.19.ppm_v
    Compile Name: package_v.ppm_ebl_psi.fls
    Image Type : PPM Image
    Data Size : 5609328 Bytes
    PPM Certificate Block Sent Successfully...
    PPM Erase Block: 0x41A40000~0x4207FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 5605984 bytes
    Data Checksum: 6D3E
    PPM Data Blocks uploaded to phone...
    Data Sections : 01
    Current File : rm862__03.19.image_v_059Q094
    Compile Name: package_v_059Q094.image.fls
    Image Type : CONTENT Package
    Data Size : 15994128 Bytes
    CONTENT Certificate Block Sent Successfully...
    CONTENT Erase Block: 0x42080000~0x43E1FFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 15990784 bytes
    Data Checksum: C78C
    CONTENT Data Blocks uploaded to phone...
    CONTENT Erase Block: 0x43E60000~0x43F3FFFE
    Start Erasing...
    Block Erase Done...
    Total Flashing Time (Erase + Flashing) : 00:07:27
    Waiting for Phone to Start-Up..(Max 150 seconds)
    Scanning USB Ports...
    Basic Phone Information
    MCU Version: V 03.19 25-12-12 RM-862 (c) Nokia
    IMEI Plain : 355488051515706
    IMEI Spare : A355488051515700
    IMEI SV : 33554880515157006F
    IMEI (2nd) : 355488051515714
    IMEI Spare : A355488051515710
    IMEI SV : 33554880515157106F
    Phone Model: J 205
    Category : Phone
    Phone Type : RM-862
    Extended Phone Information
    Product Serial Number: DFC97EEAH
    Product Code : 059Q0Q2
    Module Code : 0205222
    Basic Production Code: 059N267
    Long Production SN : 0
    PPM SW Version : V 03.19 25-12-12 RM-862 (c) Nokia V
    BT MCM Version : 19b5-22012
    MCU SW Version : V 03.19 25-12-12 RM-862 (c) Nokia
    HW Version : 1000
    RFIC Version : 68
    LCD Version : TPO
    Content Pack Version : Content: v_059Q094 V 03.19 25-12-12 RM-862 (c) Nokia
    Bluetooth ID : 54:79:75:06:38:81
    CS Type : GSM900, GSM1800
    ********** SIMLOCK INFO **********
    CONFIG_DATA : 0010100000000000
    PROFILE_BITS : 800000000004000B
    ASIC : 11
    PROVIDER : Default Test Operator
    LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK)
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SECURITY_CODE : 12345
    PHONE_MODE : TEST
    Dynamic Camera Configuration
    DCC ID : NI00CS00000401022F03
    DCC Ver: 010009
    Status : OK
    Make sure you have installed the
    COMPLETE Flash Package for this Phone...
    Goto "Settings" --> "Nokia Settings" and verify that
    the Folder where you installed your Flash Files are
    in the "PRODUCT PATH TO SCAN" List...
    FACTORY SET TO : Full Factory Set
    OK
    FACTORY SET TO : User Data
    OK
    FACTORY SET TO : Leave Factory
    OK
    FACTORY SET TO : Service Center
    OK
    FACTORY SET TO : Software Upgrade
    OK
    FACTORY SET TO : Production Tune
    OK
    RESET LIFE TIMER TO : 0000:00
    OK
    pinout câu theo hình http://dc391.4shared.com/img/F--2fBX...PHONE_BACK.jpg
    chuyên:UNLOCK-REPAIR BOOT-NẠP TIẾNG VIỆT ALL PHONE
    Oct 2009
    E71 RM-357 flash TV OK
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 400C1921
    ID DWORD 4 : 01031103
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 0F300017
    ID DWORD 1 : 96E48A52
    ID DWORD 2 : CA67ABDF
    ID DWORD 3 : C18EBFF3
    ID DWORD 4 : BB0745B0
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 4B9B7510
    CRC 1 : 3E691FF8
    Checksum A6
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
    Boot File - Version 012.08.00
    Boot File - Revision 0x0002 (2)
    eBB5ProtocolType == New
    PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
    PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
    Secondary Loader Sent...
    TransmissionTypeRequest_DCT5_NewProtocol
    TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
    FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
    Transmission Type Request Sent...
    ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
    MessageID : 06
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> not detected
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Device ID : 0000 -> BAD FLASH TYPE
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0400 -> Flash
    Device ID : 0000 -> Type not in database
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> not used
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0040 -> KAT00F00RA
    Revision ID : 0121
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.5
    Checksum : 25
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    Size : 10000000 (256 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g
    Algorithm File - Version 012.08.00
    Algorithm File - Revision 0x0002 (2)
    Algo Loader Sent...
    SendCodeStart_NewProtocol :
    SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
    SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok...
    VPP Enabled by Software
    Using Internal VPP
    FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
    PAPUB_KEYS_HASH_REQ_BB5
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    52570A2086C79E6965175815B5388535CDD5C6F7
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0xB1 (177)
    ERASE Blocks : 0x04 (4)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x1B (27)
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    0 : 00040000-007FFFFF
    1 : 00A00000-0759FFFF
    2 : 0F1C0000-0F8BFFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x00000000
    Format Info : 000000000000000B0000000000000002000000640000000300 000001000000010000000000000000
    2 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 00000000000000090000000000000001000000640000000400 000001000000010000000000000000
    3 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000
    Erase_SendEraseBlock_BB5_NAND
    Task in Progress... Please Wait...
    Erase_SendFormatPartition_BB5_NAND
    Successfully erased..
    Time Taken to Erase : 00:00:01
    Flashing Speed: 5.00 Mhz (AUTO)
    Processing : rm346_500.21.009_prd.c00
    Total blocks to write : 588
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS [52570A2086C79E6965175815B5388535CDD5C6F7]
    >> CMT Rootkey Hash CERT : SOS*UPDAPP
    >> CMT Rootkey Hash CERT : SOS*DSP0
    >> CMT Rootkey Hash CERT : SOS*ISASW
    >> CMT Rootkey Hash CERT : SOS*CORE
    >> CMT Rootkey Hash CERT : SOS+ROFS
    ContinueFlash_DCT5 Complete
    Continue Flash Complete : : No Error - 0 (0x00)
    Time Taken to Flash : 00:00:39
    C:\Program Files\Nokia\Phoenix\Products\RM-346\rm346_500.21.009_prd.v29
    CMT Type : BB5
    CMT Algorithm : XSR 1.5
    Secondary Sending Speed : 650000 Hz
    Algorithm Sending Speed : 6500000 Hz
    Program Sending Speed : 6500000 Hz
    Message Reading Speed : 98000 Hz
    Number of Blocks : 186
    Entry Point : 0x0169
    Page Format : 128K
    Maximum Page Size : 0x00020000
    StartErase_DCT5...
    BlockLength : 0x3F (63)
    ERASE Blocks : 0x02 (2)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 05420000-0759FFFF
    Device Index : 0x00
    Time Taken to Erase : 00:00:00
    Processing : rm346_500.21.009_prd.v29
    Total blocks to write : 186
    >> CMT Rootkey Hash CERT : SOS+ROFX
    Time Taken to Flash : 00:00:13
    C:\Program Files\Nokia\Phoenix\Products\RM-346\rm346_500.21.009.07U
    CMT Type : BB5
    Number of Blocks : 169
    Entry Point : 0x0122
    Page Format : 128K
    StartErase_DCT5...
    BlockLength : 0x32 (50)
    ERASE Blocks : 0x01 (1)
    0 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 00000000000000080000000000000001000000640000000A00 000001000000010000000000000000
    Processing : rm346_500.21.009.07U
    Total blocks to write : 169
    C:\Program Files\Nokia\Phoenix\Products\RM-346\RM346_ENO_0741.10_08wk42.a36.fpsx
    CMT Type : BB5
    Entry Point : 0x0143
    Page Format : 128K
    StartErase_DCT5...
    BlockLength : 0x10 (16)
    0 ERASE_AREA_BB5 0x13
    Block Length : 0x0D (13)
    Processing : RM346_ENO_0741.10_08wk42.a36.fpsx
    >> CMT Rootkey Hash CERT : SOS*ENO
    Time Taken to Flash : 00:00:01
    C:\Program Files\Nokia\Phoenix\Products\RM-346\leevi_erase_y_drive.fpsx
    CMT Type : BB5
    Number of Blocks : 0
    Entry Point : 0x0000
    Page Format : 128K
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    Device Index : 0x00
    0 : 0F020000-0F1BFFFF
    Processing : leevi_erase_y_drive.fpsx
    No FLASHDATA TO WRITE
    STATUS_REQUEST_BB5...
    1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 00
    Device Type : 03
    Device Type : 00
    Num Bad Blocks : 00000001
    Additional Bad : 00000001
    Correctable ECC : 00000000
    Time Taken to Flash : 00:00:00
    Total Flash Write Time (Flashing Only) : 00:01:08
    Total Flashing Time (Booting + Erase + Flashing) : 00:01:11
    Waiting for Phone to Go Online...
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    MCU Version: V ICPR71_09w47.5 24-05-10 RM-357 (c) Nokia
    IMEI Plain : 352925025840473
    IMEI Spare : A352925025840470
    IMEI SV : 33529250258404759F
    Phone Model: Nokia E71
    Category : Smartphone
    Phone Type : RM-357
    Product Serial Number: SCP475575
    Product Code : 0591122
    Basic Production Code: 0567615
    MCU SW Version : V ICPR71_09w47.5 24-05-10 RM-357 (c) Nokia
    HW Version : 0941
    RFIC Version : 17141715
    DSP Version : ICPR71_09w40
    AHNE Version : 11
    APE SW Core Version : 500.21.009
    Variant Version : 500.21.009500.21.009_v29
    APE Test Version : RM346ENO74110842.a36
    RETU Version : 16
    TAHVO Version : 22
    APE HW Version : 256
    APE ADSP SW Version : 256
    Wireless LAN ID : 00:21:FE:3E:39D
    Bluetooth ID : 00:21:FE:4D:7C:1C
    CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA II, WCDMA V
    Simlock Information
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    SIMLOCK STATE : Not Locked
    SIMLOCK_TYPE : PA_SL2
    PHONE_MODE : TEST
    Primary Dynamic Camera Configuration
    DCC ID : 86L10300010406260004
    DCC Ver: 001009
    Status : OK
    Secondary Dynamic Camera Configuration
    DCC ID : 8600030001040C208A03
    DCC Ver: 001004
    Status : OK
    Super Moderator TuệNguyễn's Avatar
    TP Hồ Chí Minh
    Nokia 107 mã bảo vệ ok!
    START INFINEON BUS CHECK
    Sending PBL 37888 bytes...
    Sending SBL 65024 bytes...
    Flash Chip Manufacturer: STMicroelectronics
    Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
    Extended Information: Multiple Bank / Burst / 1.8v
    INFINEON BUS CHECK DONE
    MCU: V 02.70 08-08-13 RM-961 (c) Nokia
    IMEI: 359210058723604
    Product Serial Number: 031A750AU
    Product Code : 059T238
    Module Code : 0205709
    Basic Production Code: 059S7H5
    PPM SW Version : V 02.70 08-08-13 RM-961 (c) Nokia MR
    ADSP Version : p V 02.70\n08-08-13\nRM-961\n(c) NMP\nmr
    MCU SW Version : V 02.70 08-08-13 RM-961 (c) Nokia
    HW Version : 3001
    UEM Version : 1328
    UPP Version : 8850
    LCD Version : TPO:BARACOAv92 HX5081
    PROFILE_BITS : 0000000000040002
    ASIC : 11
    ST_LCD_TEST : PASSED
    Selected VPL File:
    RM961_059T238_02.70_001.vpl
    Variant Details : NDT SEAP STROKE VN [ATF v10.50]
    Software Version : 02.70
    Product Type : RM-961
    Variant Version : 001
    OK
    OK
    OK
    OK
    OK
    OK
    Unlock-repair boot-repair imei-repair emmc-nạp Tiếng Việt all smart phone
    ĐC: 159/7/2 Đường TTH07 Phường Tân Thới Hiệp Q12 TPHCM
    ĐT: 0903135569 - Skype: tuenguyen.79
    Thành viên chính thức thanhminhsv1's Avatar
    Jan 2011
    Đồng Nai
    thớt này có cổ phần trong cong ty sản xuất ATF thì phải, hình như là cổ đông lớn đáy,
    Oct 2009
    lumia 925 treo logo flash done by atf
    Public ID : 0EA30D674AB9991BD3F04A7CFB3791954A4D902D
    Wireless Lan 0 ID: DC:3E:F8:E4:94:E8
    Wireless Lan 1 ID: DC:3E:F8:E4:94:E9
    Wireless Lan 2 ID: DC:3E:F8:E4:94:EA
    Wireless Lan 3 ID: DC:3E:F8:E4:94:EB
    Bluetooth ID : DC:3E:F8:E4:6A:93
    Simlock Information
    Boot Flash Mode Successful...
    Phone Info Query Start...
    Blocks Returned: 0x07 Blocks
    Block ID 0x01 : 00241000
    Block ID 0x02 : 00240000
    Block ID 0x03 : 01D5A000
    Block ID 0x05 : Nokia.MSM8260A.P6023.4.1
    Block ID 0x0D : 0001
    Block ID 0x0F : 0301010100000101FF
    Block ID 0x10 : 0100030000
    Checking SD Card Size...
    Card Size: 0x00000000
    Checking Platform Security Status...
    Platform Secure Boot Status: Active
    Secure FFU EFUSE Status: Active
    Debug Status: Active
    RDC Status: Not Active
    Authentication Status: Not Active
    UEFI Secure Boot Status: Active
    Checking Secure FFU Mode...
    Secure FFU Mode : SYNC + ASYNC
    Query Flash App Information...
    Flash App Information: 02010E011900
    UEFI App: FLASH APP
    Flash App Protocol Version: 1.14
    Flash App Implementation Version: 1.25
    Query ROOT KEY HASH...
    ROOT_KEY_HASH: CD84376222AAF204C85119532BF34EA55C8844E4CEA35F3E50 8D25AA34D96637
    Sending Image Signatures...
    Image Signatures Accepted!
    Erasing Data Partition...
    Data Partition Erased Successfully
    Preparing Buffers for DATA LOOP...
    Allocating System RAM OK!
    Start Sending DATA BLOCKS...
    Finished Sending all DATA BLOCKS!
    Exiting FLASH Mode via REBOOT...
    Exit FLASH Mode Successful!
    Flashing Done!
    Total Flashing Time : 00:02:45
    Oct 2009
    lumia 610 flash tiếng việt ok by atf
    CSD : D00E00320F5903FFFFFFFFE79640001F
    eMMC Boot Information
    Revision 1.5 (for MMC v4.41)
    BOOT PARTITION : USER AREA
    PARTITION ACCESS : R/W USER PARTITION
    PERM_BOOT_CFG_PROT : DISABLED
    PWR_BOOT_CFG_PROT : DISABLED
    eMMC FirmW UPDATE : DISABLED
    EMMC CACHE SIZE : 0 KB
    SUPER PAGE SIZE : 3584 KB
    HC ERASE GROUP SIZE: 4096 KB
    USER AREA SIZE : 7952400384 BYTES
    BOOT PARTITION SIZE: 2048 KB
    RPMB PARTITION SIZE: 256 KB
    Lumia 610/610C Detected
    eMMC Device Information
    Manufacturer ID: TOSHIBA
    Device Type : Embedded BGA
    Application ID : 00
    Product Name : 008G4B
    Product Rev : 0.0
    Product SN : 0E15840C
    Manufactured : January 2011
    Card Specific Data
    CSD_STRUCTURE : Extended
    SPEC_VERS : Version 4.1/4.2/4.3
    TAAC : 3 ns
    TRANS_SPEED : 4000000 KHz
    READ_BL_LEN : 512 Bytes
    C_SIZE : HIGH CAPACITY
    WP_GRP_ENABLE : YES
    WRITE_BL_LEN : 512 Bytes
    CONTENT_PROT_APP : NO
    PERM_WRITE_PROTECT: NO
    TMP_WRITE_PROTECT : NO
    Extended CSD Saved:
    110100303038473442000E15840C_AD71136C.ext_csd
    Backup Directory:
    C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
    Writing MBR...
    Write Success!
    Writing DBL...
    Write Success!
    Writing OSBL...
    Write Success!
    BOOT Images Written Successfully!
    Total Elapsed Time 00:01:18
    Loading Partition File: C:\Users\Renall\Downloads\os-new\os-new.nb
    Writing Partition 0x48
    Partition 0x48 Write OK
    Total Elapsed Time 00:00:47
    Moderator THIÊN UY™'s Avatar
    Bình Dương
    Lumia 520 lỗi không phát được nhạc.
    Code:
    If the Phone is DEAD
      1. Connect Phone to the USB Port
      2. Press and Hold the VOLUME DOWN and POWER Buttons
      3. Wait until the Phone Vibrates Shortly...
      4. Stop Pressing the Buttons...
    Thành viên tích cực haikute1989th's Avatar
    Jan 2011
    thanh hóa
    NOKIA ASHA 503 BỊ MÃ BAO VỆ
    Number of Image Files: 3
    rm922_12.1.6.mcusw.fls
    rm922_12.1.6_059S8Q0_s2.rofs.fls
    rm922_12.1.6_059S8Q0_s2.image.fls
    Then Perform Steps 1, 2, and 3...
    1. Remove USB Cable and Battery...
    2. Connect USB Cable.
    3. Connect Battery.
    ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT *****
    ******* REMOVE BATTERY AND PUT IT BACK AGAIN. *******
    Infineon Boot: F01650A9070100030101E03008121018F3D459CA2DB6FFFF
    CPU Type: Intel XG618
    <<<< Connect Battery Now >>>>
    Sending PBL...
    Sending SBL...
    Unique Data: E03008121018F3D4
    Original Product Code: 059S8Q0
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\358979057458674\3589790574586 74_92304.rpl
    Current File : rm922_12.1.6.mcusw.fls
    Number of Images: 7
    psi_flash_unsigned.fls
    slb_signed.fls
    main_toc_signed.fls
    rm922_12.1.6.mcusw.fls_signed_mcusw.fls
    swap_signed.fls s
    aeneas_signed.fls s
    fota_signed.fls s
    Processing Data Block 0x00
    Erase Block: 0x00090000~0x000A0FAE
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Data Block Write Done...
    Processing Data Block 0x01
    Erase Block: 0x60000000~0x6003FFFE
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Processing Data Block 0x02
    Erase Block: 0x60040000~0x600403FE
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Processing Data Block 0x03
    Erase Block: 0x64800000~0x66AFB5A2
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Erase Block: 0xFFF00000~0xFFF7FFFE
    Start Erasing...
    Block Erase Done...
    Processing Data Block 0x04
    Erase Block: 0x80000000~0x800053DE
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Processing Data Block 0x05
    Erase Block: 0x67F79C00~0x67FC046E
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Processing Data Block 0x06
    Erase Block: 0x61F00004~0x6206392E
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Current File : rm922_12.1.6_059S8Q0_s2.rofs.fls
    Number of Images: 1
    rofs_ebl_psi.fls
    Erase Block: 0x66E00000~0x679DFCE2
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Current File : rm922_12.1.6_059S8Q0_s2.image.fls
    Number of Images: 1
    rm922_12.1.6_059S8Q0_s2.image.fls.image.fls
    Erase Block: 0xA1000000~0xA3BC53FE
    Start Erasing...
    Block Erase Done...
    Start Writing...
    Finalizing...
    Erase Block: 0xAE000000~0xAE2FFFFE
    Start Erasing...
    Block Erase Done...
    Total Flashing Time (Erase + Flashing) : 00:00:20
    MCU Version: V 12.1.6 21-11-13 RM-922 (c) Nokia
    IMEI Plain : 358979057458674
    IMEI Spare : A358979057458670
    IMEI SV : 33589790574586719F
    IMEI (2nd) : 358979057458682
    IMEI Spare : A358979057458680
    IMEI SV : 33589790574586819F
    Phone Model: 6 503
    Category : Classic Phone
    Phone Type : RM-922
    Product Serial Number: 4BD1F6DBH
    Product Code : 059S8Q0
    Module Code : 0205633
    Basic Production Code: 059S1T0
    PPM SW Version : 23ff7421e556145db74074fd9427cb0e5b4c8dfb
    BT MCM Version : 19e2-4702H10
    AEM Version : 43362a2-5.96.11.0
    MCU SW Version : V 12.1.6 21-11-13 RM-922 (c) Nokia
    HW Version : 1000
    RFIC Version : Integrated to main ASIC
    LCD Version : TPO
    AHNE Version : 8
    Variant Version : 0000000000000000000000000000000000000000
    TAHVO Version : RM-922-12.1.6-059S8Q0-12.1.6-12.1.6
    Wireless LAN ID : CC:89:FD:ED:48D
    Bluetooth ID : CC:89:FD:E7:2E:5D
    CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
    ASIC : 11
    SECURITY_CODE : P
    PHONE_MODE : TEST
    DCC ID : 0103B904
    DCC Ver: 005005
    Status : OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    link file em nó luôn :Free Download Firmwares Nokia Asha 503 RM-922 Product Code 059S8Q0 MrCrab.Net
    Oct 2009
    lumia 720 treo logo flash done
    Basic Tranceiver Code: 059R0L8
    Block ID 0x03 : 00E90000
    Block ID 0x05 : Nokia.MSM8227.P6012.1.2
    Flash App Information: 02010C011700
    UEFI App: FLASH APP
    Flash App Protocol Version: 1.12
    Flash App Implementation Version: 1.23
    ROOT_KEY_HASH: 26323C81CFBFD503F6C530F0EA1C2E7A34039581A56274F9FC C73E1B9E272887
    Flashing Done!
    Total Flashing Time : 00:03:36
  1. Trả lời: 43
    Bài viết cuối: 07-08-2014, 09:15
  2. Trả lời: 91
    Bài viết cuối: 13-08-2013, 17:42
  3. Trả lời: 2
    Bài viết cuối: 27-09-2012, 17:43
  4. Trả lời: 31
    Bài viết cuối: 02-11-2011, 15:23
  5. Trả lời: 7
    Bài viết cuối: 29-01-2011, 20:26
