Kết quả 21 tới 27 của 27
  1. #21
    Product Manager Hoang Thong Mobile's Avatar
    Dec 2006
    AdvanceBox v2.16
    > USB Communication Supported :
    Read/Write PM, Full/Total Factory Reset, Read/Write Security Code
    Support OLD-BB5 USB Unlocking (First to implement this feature)
    Support Direct Unlock Via TP using this interface. It is more faster than Box RXTX(FBUS)
    Support Backup/Restore 308
    Support FBUS Counter Reset Using this Interface
    Support Send PSW in USB
    > Added E90 Direct Unlock Via TP [First in the world to implement unlocking of this phone VIA TP]
    V 120.41.35.1 15-10-07 RA-6 (c) Nokia, V 1.0641.30 07-06-07 RA-6 (c) Nokia,V 210.41.48.2 10-04-08 RA-6 (c) Nokia
    > Added E90 TESTPOINT Picture (Just press SHOW TP, you can see button E90 CLK/DATA)
    Note: To use USB Interface you must CHECK it in settings and you must PLUG the USB to PC.
    Default Interface is FBUS(rxtx).
    CTY TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    ĐT/FAX : 083.9572152 - 08.38575707 - 0903.303.717
    Skype : saigonmobile
    YM : saigonmobile_vn
    MSN : saigonmobile@hotmail.com
  2. #22
    Dec 2006
    AdvanceBox Updates
    * AdvanceBox v2.17
    - Fixed and improved SP Lock Table Block reading
    - Improved Unlocking
    - Support new Nokia USB Driver
    - Support USB Interface - Counter reset for new phones with pm 120. Just press FBUS Counter Reset. Not implemented yet in FBUS(rxtx) First In The World
    * AdvanceDCT4 v1.2
    - Fixed minor reported bugs
    Note : The new download is a setup installer. Includes TP, DCT4 Partials, Skins and etc.. Setup will automatically create AdvanceBox folder in program files.
  3. #23
    Dec 2006
    June 30,2008
    Learning Mode update :
    6300
    V 06.60 21-05-08 RM-217 (c) Nokia.
    3110c
    V 06.60 21-05-08 RM-237 (c) Nokia.
    3500c
    V 06.60 21-05-08 RM-272 (c) Nokia.
    N75
    V 06wk15v45.1 17-10-07 RM-128 (c) Nokia. ( 20.1.172 )
  4. #24
    Dec 2006
    Mặc định • AdvanceBox v2.18
    • AdvanceBox v2.18
    - Support TELCEL Learning Mode.
    5200b
    V 03.70 22-09-06 RM-181 © Nokia.
    V 03.92 13-10-06 RM-181 © Nokia.
    V 03.93 20-11-06 RM-181 © Nokia.
    V 04.71 28-02-07 RM-181 © Nokia.
    V 04.72 26-03-07 RM-181 © Nokia.
    V 05.00 27-04-07 RM-181 © Nokia.
    V 05.51 05-09-07 RM-181 © Nokia.
    V 05.53 03-03-08 RM-181 © Nokia.
    5300b
    V 03.50 14-09-06 RM-147 © Nokia.
    V 03.51 20-09-06 RM-147 © Nokia.
    V 03.92 13-10-06 RM-147 © Nokia.
    V 03.93 20-11-06 RM-147 © Nokia.
    V 04.49 03-01-07 RM-147 © Nokia.
    V 04.51 11-01-07 RM-147 © Nokia.
    V 04.70 24-01-07 RM-147 © Nokia.
    V 04.71 28-02-07 RM-147 © Nokia.
    V 04.72 26-03-07 RM-147 © Nokia.
    V 05.00 27-04-07 RM-147 © Nokia.
    V 05.02 05-06-07 RM-147 © Nokia.
    V 05.50 14-08-07 RM-147 © Nokia.
    V 05.51 05-09-07 RM-147 © Nokia.
    6131
    V 03.50 31-03-06 RM-115 © Nokia.
    V 03.70 12-05-06 RM-115 © Nokia.
    V 05.50 20-09-06 RM-115 © Nokia.
    V 06.10 16-02-07 RM-115 © Nokia.
    V 06.60 30-07-07 RM-115 © Nokia.
    6300b
    V 04.20 05-12-06 RM-222 © Nokia.
    V 04.70 24-01-07 RM-222 © Nokia.
    V 04.71 28-02-07 RM-222 © Nokia.
    V 05.00 27-04-07 RM-222 © Nokia.
    V 05.50 14-08-07 RM-222 © Nokia.
    V 05.52 09-11-07 RM-222 © Nokia.
    V 06.01 16-01-08 RM-222 © Nokia.
    6085
    V 03.70 03-11-06 RM-198 © Nokia.
    V 03.71 30-11-06 RM-198 © Nokia.
    V 04.11 11-01-07 RM-198 © Nokia.
    V 04.22 01-03-07 RM-198 © Nokia.
    V 04.26 16-03-07 RM-198 © Nokia.
    V 05.02 08-05-07 RM-198 © Nokia.
    V 05.03 09-08-07 RM-198 © Nokia.
    - Fixed minor bugs.
  5. #25
    Dec 2006
    Mặc định AdvanceBox v2.21 - Official Release
    AdvanceBox Updates
    •AdvanceBox v2.21
    Support Counter Reset using AD0 – ALL BB5 ‘NOR’ PHONE
    Support Learning Mode for Counter Reset using AD0 and AD8 - ALL BB5 ‘NOR’ PHONE
    Improved Unlocking
    >> ALWAYS UPDATE TRIGGERS
  6. #26
    Dec 2006
    Mặc định AdvanceBox v2.22 - Software Updates
    > Add Option for unlock after successfull counter reset
    > Improved USB Direct TP Unlocked
    > Update TELCEL Unlocking (Filter correct profile bit)
    > Add tab for Telcel Unlocking
    > Add setting option to bypass readlock
    > Enable direct link for software download
    > ALWAYS PRESS UPDATE TRIGGER <
    Best regards,
    Advance Team
  7. #27
    Dec 2006
    Mặc định *** Better 3109c / 3109cb Unlocking Support For All Versions ***
    All versions now supported in Direct Unlock TP !!!
    (No more Learning Mode Required)
    Firmware 05.30 - EASY - AD0 - FBUS ONLY (DO NOT USE USB CONNECTION)
    Firmware 05.50 - HARD - AD0 - FBUS & USB Connection Capable
    Firmware 06.01 - EASY - AD0 - FBUS ONLY (DO NOT USE USB CONNECTION)
    Firmware 06.20 - EASY - AD0 - FBUS & USB Connection Capable
    The EASIEST VERSION TO UNLOCK IS 06.20
    Download Flash Files here:
    Firmware 05.30 --> http://www.advance-box.com/3kids/bb5...__sw-05.30.exe
    Firmware 05.50 -->http://www.advance-box.com/3kids/bb5...__sw-05.50.exe
    Firmware 06.01 -->http://www.advance-box.com/3kids/bb5...__sw-06.01.exe
    Firmware 06.20 -->http://www.advance-box.com/3kids/bb5...__sw-06.20.exe
    Here are some Proofs that our Direct Unlock Triggers are working 100%
    All 3109c / 3109cb should have the same flash chip "ST M39L0R807" and so all
    3109c / 3109cb will use the same trigger for unlocking a specific firmware version.
    Version 05.30 via FBUS Connection ONLY
    MCU Sw : V 05.30 16-05-07 RM-274 (c) Nokia.
    IMEI : put_imei_here
    SP Version: SIMLOCK SERVER VERSION 63
    SP_F : 0000000000000000
    SP_P : 5150200000000000
    Provider : Globe Telecom;Philippines
    Counters : 0/3 , 0/10
    Lock info :
    SP Lock Status : Locked
    Auto PM-308 Backup.......
    Backup Already Created......
    Lock info :
    Preparing To Unlock Phone
    No. of Unlock Trigger >>>> : 1
    Unlock Trigger set to : 1
    Unlock Try No. : 1
    Buffer size changed to 04 bytes ....
    Sending Unlock Trigger 1/4
    Sending Unlock Trigger 2/4
    Sending Unlock Trigger 3/4
    Sending Unlock Trigger 4/4
    Initializing TP...
    TP CONNECTED
    Unlocking
    Sending PSW......
    #PW+0123345678901234+7#
    Lock info :
    SP Lock Status : Not Locked
    Unlocking successfull.......
    Process Done! ....
    Version 05.50 via FBUS Connection
    MCU Sw : V 05.50 14-08-07 RM-274 (c) Nokia.
    Lock info :
    Lock info :
    No. of Unlock Trigger >>>> : 4
    Unlock Try No. : 1
    Initializing TP...
    TP CONNECTED
    Unlocking
    Sending PSW......
    Lock info :
    Process Done! ....
    Version 06.01 via FBUS Connection ONLY
    MCU Sw : V 06.01 16-01-08 RM-274 (c) Nokia.
    Lock info :
    Lock info :
    Unlock Try No. : 1
    Initializing TP...
    TP CONNECTED
    Unlocking
    Sending PSW......
    Lock info :
    Process Done! ....
    Version 06.20 via FBUS Connection
    MCU Sw : V 06.20 18-03-08 RM-274 (c) Nokia.
    Lock info :
    Lock info :
    Unlock Try No. : 1
    Initializing TP...
    TP CONNECTED
    Unlocking
    Sending PSW......
    Lock info :
    Process Done! ....
  1. SPT Box Update Check Here !!!
    By Hoang Thong Mobile in forum SPT BOX
    Trả lời: 91
    Bài viết cuối: 09-06-2015, 14:01
  2. Fire-Dongle New Update, Update and Repair All Reader, iPhone Check Imei v1.4 Released
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 21-01-2013, 17:13
  3. JAF update! Check it here!
    By taihv™ in forum J.A.F
    Trả lời: 125
    Bài viết cuối: 29-07-2011, 11:45
  4. UST Pro II update, check here!
    By taihv™ in forum UST Pro II
    Trả lời: 17
    Bài viết cuối: 31-10-2010, 09:57
  5. MT Box new and update check here
    By BlachThon in forum MT-Box
    Bài viết cuối: 29-05-2008, 11:41
