ASANSAM Box (All-in-One v1.0.5)Released just look it that and nothing else
ASANSAM Box Version 2.4.8
BIG Update of 2014
First in The World Update
HOT Update
Amazing Update
BR
ASANSAM TEAM
BIG Update of 2014
HOT Update
Amazing Update
BR
ASANSAM TEAM
ASANSAM Box (Nokia Android Tool rev1.0.0) Released
Nokia Android Tool rev1.0.0 Released
Add Nokia_X Family A110 (RM-980,RM-981)
- Write Flash
Flash Factory Flash Files on All Blocks Boot,Recovery,System,Userdata,Persist , ...
Quote:
11:32:39 PM : Searching For Phone ...OK
11:32:39 PM : Device Found!
11:32:39 PM : Reading Information ...
11:32:39 PM : Protocol Version : 0.5
11:32:39 PM : Serial No. : YYYYYYYY
11:32:39 PM : Platform Type : MSM7627A
11:33:00 PM : Uploading [QCSBL_CONFIG] As Partition [sbl1] ...DONE!
11:33:20 PM : Uploading [QCSBL] As Partition [sbl3] ...DONE!
11:33:43 PM : Uploading [MODEM] As Partition [modem] ...DONE!
11:34:03 PM : Uploading [OEMSBL_HEADER] As Partition [tz] ...DONE!
11:34:24 PM : Uploading [OEMSBL] As Partition [tz] ...DONE!
11:34:44 PM : Uploading [APPSBOOT_HEADER] As Partition [rpm] ...DONE!
11:35:05 PM : Uploading [APPSBOOT] As Partition [rpm] ...DONE!
11:35:25 PM : Uploading [BOOT] As Partition [boot] ...DONE!
11:35:36 PM : Uploading [RECOVERY] As Partition [recovery] ...DONE!
11:35:57 PM : Uploading [PERSIST] As Partition [persist] ...DONE!
11:37:41 PM : Uploading [SYSTEM] As Partition [system] ...DONE!
11:38:02 PM : Uploading [VARIANT] As Partition [variant] ...DONE!
11:38:23 PM : Uploading [CACHE] As Partition [cache] ...DONE!
11:38:46 PM : Uploading [USERDATA] As Partition [userdata] ...DONE!
11:39:20 PM : Uploading [UDISK] As Partition [mdm] ...DONE!
11:40:45 PM : Uploading [PRELOAD] As Partition [preload] ...DONE!
11:40:45 PM : Rebooting to Normal Mode ...OK
11:40:45 PM : Operation Completed
11:40:45 PM : Operation Time: 00:08:06
Download Nokia X Flash Video Here
- Read/Write Security
Read Security Block Include SIMLOCK Data/Imeis
Quote:
11:46:13 PM : -----------------------------------------------------------------------------------------------
11:46:13 PM : Turn-on the Phone Goto 'Settings > Developers options Turn-on Developer options
11:46:13 PM : And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver.
11:46:13 PM :
11:46:13 PM : NOTE: if Your Phone Still Not Detected Dial this Sequence => *#*#2273#*#*
11:46:13 PM : and check WinusbEnable/Disable
11:46:18 PM : Prepairing ...OK
11:46:18 PM : Device Found!
11:46:18 PM : Model : Nokia_X
11:46:18 PM : Serial No. : YYYYYYYY
11:46:18 PM : IMEI 1 : 3XXXXXXXXXXXXXX
11:46:18 PM : IMEI 2 : 3XXXXXXXXXXXXXX
11:46:22 PM : Root Status : Rooted
11:46:23 PM : Backup 'NVM' ...OK OK OK
11:46:26 PM : Backup 'MODEM_FSG' ...OK OK OK
11:46:28 PM : Backup 'MODEM_ST1' ...OK OK OK
11:46:29 PM : Backup 'MODEM_ST2' ...OK OK OK
11:46:29 PM : SECURITY Backed Up and Saved in : C:\ANAT2\BACKUP\SECURITY\2014\April\26\23-46-22\Nokia_X\3XXXXXXXXXXXXXX
- Read Phone Info
Read Usefull information About Your Device Version,SN,IMEI,....
Quote:
11:43:28 PM : -----------------------------------------------------------------------------------------------
11:43:28 PM : Turn-on the Phone Goto 'Settings > Developers options Turn-on Developer options
11:43:28 PM : And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver.
11:43:28 PM :
11:43:28 PM : NOTE: if Your Phone Still Not Detected Dial this Sequence => *#*#2273#*#*
11:43:28 PM : and check WinusbEnable/Disable
11:43:33 PM : Prepairing ...OK
11:43:33 PM : Device Found!
11:43:34 PM : Model : Nokia_X
11:43:34 PM : Product Type : RM-980
11:43:34 PM : Software Version : 11.1.1
11:43:34 PM : Product Code : 059T9F2
11:43:34 PM : Serial No. : YYYYYYYY
11:43:34 PM : IMEI 1 : 3XXXXXXXXXXXXX
11:43:34 PM : IMEI 2 : 3XXXXXXXXXXXXX
11:43:34 PM : Android Version : 4.1.2
11:43:34 PM : Baseband Version : 8X25-SSRSKOLYM-3070
11:43:34 PM : Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140307.164931 test-keys
11:43:34 PM : Product Platform : Nokia X software platform 1.1
11:43:34 PM : Build Date : Fri Mar 7 16:50:13 CST 2014
11:43:34 PM : Root Status : Not Rooted!
11:43:34 PM : -----------------------------------------------------------------------------------------------
- Root
Working on All Exist Variant versions
Quote:
11:43:59 PM : -----------------------------------------------------------------------------------------------
11:43:59 PM : Turn-on the Phone Goto 'Settings > Developers options Turn-on Developer options
11:43:59 PM : And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver.
11:43:59 PM :
11:43:59 PM : NOTE: if Your Phone Still Not Detected Dial this Sequence => *#*#2273#*#*
11:43:59 PM : and check WinusbEnable/Disable
11:44:04 PM : Prepairing ...OK
11:44:04 PM : Device Found!
11:44:04 PM : Uploading ROOTFILE 1 ...OK
11:44:04 PM : Setting Permission ...OK
11:44:04 PM : Uploading ROOTFILE 2 ...OK
11:44:05 PM : Uploading ROOTFILE 3 ...OK
11:44:05 PM : Uploading ROOTFILE 4 ...OK
11:44:08 PM : Installing SU ...OK
11:44:47 PM : Running Exploit ...OK
11:44:47 PM : Cleaning ...OK
11:44:51 PM : Rebooting ...OK
11:44:51 PM : -----------------------------------------------------------------------------------------------
11:44:51 PM : Operation Completed
11:44:51 PM : Operation Time: 00:00:52
- Install/Uninstall Google Play Service
Each Android Device Without Google Play Mean Nothing
So With This Future You Can Add Multiple Google Apps on Phone
Quote:
08:44:38 PM : -----------------------------------------------------------------------------------------------
08:44:38 PM : Turn-on the Phone Goto 'Settings > Developers options Turn-on Developer options
08:44:38 PM : And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver.
08:44:38 PM :
08:44:38 PM : NOTE: if Your Phone Still Not Detected Dial this Sequence => *#*#2273#*#*
08:44:38 PM : and check WinusbEnable/Disable
08:44:43 PM : Prepairing ...OK
08:44:43 PM : Device Found!
08:44:43 PM : Installing Google Service...
08:44:53 PM : Uploading Resource File ...OK
08:44:57 PM : Rebooting to Recovery Mode ...OK
08:44:57 PM : Now in Recovery Menu Navigate to 'apply update from internal storage' then select 'Install.zip'
08:44:57 PM : After Finishing Installation Navigate to 'reboot system now'
08:44:57 PM :
08:44:57 PM : Waiting for Device ...
08:45:10 PM : Device Found
08:45:12 PM : Cleaning ...OK
08:45:13 PM : Operation Completed
08:45:13 PM : Operation Time: 00:00:50
08:45:13 PM : -----------------------------------------------------------------------------------------------
- Install Custom Recovery
- one-Click Install CWM recovery
Quote:
08:51:55 PM : Searching For Phone ...OK
08:51:55 PM : Device Found!
08:51:55 PM : Reading Information ...
08:51:55 PM : Protocol Version : 0.5
08:51:55 PM : Serial No. : YYYYYYYY
08:51:56 PM : Platform Type : MSM7627A
08:55:00 PM : Searching For Phone ...OK
08:55:00 PM : Device Found!
08:55:00 PM : Reading Information ...
08:55:00 PM : Protocol Version : 0.5
08:55:00 PM : Serial No. : YYYYYYYY
08:55:00 PM : Platform Type : MSM7627A
08:55:11 PM : Uploading [RECOVERY] As Partition [recovery] ...DONE!
08:55:12 PM : Rebooting to Normal Mode ...OK
08:55:12 PM : Operation Completed
08:55:12 PM : Operation Time: 00:00:12
- Install Kitkat launcher
Quote:
09:00:13 PM : -----------------------------------------------------------------------------------------------
09:00:13 PM : Turn-on the Phone Goto 'Settings > Developers options Turn-on Developer options
09:00:13 PM : And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver.
09:00:13 PM :
09:00:13 PM : NOTE: if Your Phone Still Not Detected Dial this Sequence => *#*#2273#*#*
09:00:13 PM : and check WinusbEnable/Disable
09:00:18 PM : Prepairing ...OK
09:02:16 PM : Device Found!
09:02:30 PM : Installing 'Velvet' ...OK
09:02:35 PM : Installing 'PrebuiltGmsCore' ...OK
09:02:41 PM : Installing 'GoogleHome' ...OK
09:02:45 PM : Rebooting ...OK
09:02:45 PM :
09:02:45 PM : After Phone Start up Completely Doing this:
09:02:45 PM : Hold '<' button for 2 seconds you should see 'Complete action using'
09:02:45 PM : at this point, select 'Google Search Launcher'
09:02:45 PM : -----------------------------------------------------------------------------------------------
Download
4shared
ASB Box BY ASANSAM Team Samsung/Sony/Blackberry/Nokia Supported
BR
ASANGSM TEAM
ASANSAM BOX(ASF rev 1.1.6) Released (Add Suppprt For MSM8210,MSM8928 CPU Based Phone)
ASANSAM All-in-One v1.0.6
ASF Rev 1.1.6 Released
Add
Xperia T2 Ultra Flash/Service
Xperia E1 , E1 Dual Flash/Service/ROOT
Xperia Z2 Flash/Service/ROOT
Xperia Z1 Compact Flash/Service/ROOT
Xperia Z1s Flash/Service/ROOT
IMPORTANT NOTE
From This All-in-One Version (v1.0.6) ANAT (ASANSAM NOKIA ANDROID TOOL) Added in All-in-One Setup For Ease of Installation
DOWNLOAD
4Shared
How to Install
Uninstall Previous Version then Download This New All-in-One Setup and install it
BR
ASANSAM TEAM
ASANSAM Box Version 2.5.0 Released add 200 new special imei in database list
ASANSAM Box Ver 2.5.0 Released
Add 200 New special Imei For Some Country(contact to 100.1587178 if your country have imei policy)
GT-I9300 4.3
GT-N7100 4.3
GT-I9500
SM-N900
SM-N900W8
SM-N900T
SM-N9008
SM-N9006
SM-N9005
SM-N9008V
Add
SGH-I777 one click imei repair
GT-S6818 one click imei repair
GT-S6818L one click imei repair
GT-S6810 one click imei repair
GT-S6810B one click imei repair
GT-S6810M one click imei repair
GT-S6810E one click imei repair
GT-S6810L one click imei repair
GT-S6810P one click imei repair
GT-S6812C one click imei repair
GT-S6812I one click imei repair
About Imei repair
Not supported all stock or custom firmware
Special tanx to Alnajat and danisss users
Download
4shared[/B]
Download and copy to c:/asansam2(need all in one 1.0.5)
Just For Warm UP
BR
ASANSAM TEAM
Click image for larger version Name: 05-31-2014 05-39-41 ب.png Views: 0 Size: 8.3 KB ID: 326653
Asansam Box Version 2.5.1 Released Add Galaxy S5 imei repair
FIFA WORLD CUP 2014 UPDATE
Add
Galaxy S5 SM-G900H
One Click Imei Repair
One Click SN Repair
--Need root and Usb Debugging and some firmwares supported
Quote:
Prepairing ...OK
Device Found!
Reading Phone Informations ...
Model : SM-G900H
Android Version : 4.4.2
PDA Version : G900HXXU1ANE2
CS Version : G900HUUB1ANE2
Phone Version : G900HXXU1ANE2
IMEI : NULL
Checking Root ...OK
Phone Root OK. Continue..
Disabling Security ...Done!
Rebooting... OK!
Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue
Delay 60 Seconds...
Searching for phone on COM9 ... Phone Found
Reading Data from phone...
Model : SM-G900H
S/W Version : G900HXXU1ANE2
Unique ID : CV300A3754A8A21
Memory ID : -
IMEI : none
Verifying MSL ... OK
Bypassing MSL ... OK
Writing IMEI ... OK
Reset Done!
Operation Completed
Operation Time: 00:02:06
Quote:
Prepairing ...OK
Device Found!
Model : SM-G900H
IMEI : NULL
S/N : RF1F40TGZEM
Checking Root ...OK
Repairing S/N ...OK..OK..OK
Rebooting... OK!
Operation Completed
Operation Time: 00:00:56
Download
4SHARED
Just For Warm UP
BR
ASANSAM TEAM
AsansamBox(Hua Tools version 1.0.0)-3th July 2014
HUA Tools Version 1.0.0 Released
More info and discussion HERE
BR
ASANSAM TEAM
AsansamBox(All in one 1.0.7)Released Tab3 and Amazing ROOT(FIRST IN THE WORLD)
FIFA WORLD CUP 2014
One click Direct Unlock(Beta)
One click Imei repair
Write Flash and Full service
SM-T211 GALAXY TAB 3
One click Unknown baseband Repair
Most Android Phones(2013 and 2014)Supported
Read here before use amazing root button?
Goto menu/open super su/press continue/press normal after root For install su
N7100
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
I9300
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
I9500
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
HUAWEI P6
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
HUAWEI G525
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
HUAWEI Y300
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
HUAWEI Y201
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
HUAWEI G520
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
I8262
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
NOKIA X
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
NOKIA XL
Quote:
Prepairing ...OK
Device Found!
Installing SU ...OK
Cleaning ...OK
Rebooting ...OK
Operation Completed
--And Froot Bug Fix
DÔWNLOAD 4SHARED
Just For Warm UP
BR
ASANSAM TEAM
ASANSAM Box(Nokia Android Tool rev1.0.1) Released
Nokia X+
Write Flash
Read and Write Security/IMEI
One click R Root
Read Phone Info
Install and Uninstall Google Play
Nokia XL
Write Flash
One click R Root
Read Phone Info
DOWNLOAD
ASANSAM Box(All in one 1.0.8)Released add 40 New Phones and Unlock and Imei Repair
ASANSAM Box Version 2.5.5 Released
Add Unlock/Imei Repair(Beta Test)
T235Y Add Direct unlock/One click imei repair
T2105 Add Direct unlock/One click imei repair
G3818 Add Direct unlock/One click imei repair
G3812 Add Direct unlock/One click imei repair
S6108 Add Direct unlock/One click imei repair
S6358 Add Direct unlock/One click imei repair
I8200 Add Direct unlock/One click imei repair
I8200N Add Direct unlock/One click imei repair
I8200L Add Direct unlock/One click imei repair
I8250 Add Direct unlock/One click imei repair
Add New Phone Models
G800F Add Write Flash/Read PIT/Full Service
G800H Add Write Flash/Read PIT/Full Service
G800H/DS Add Write Flash/Read PIT/Full Service
G800A Add Write Flash/Read PIT/Full Service
G800Y Add Write Flash/Read PIT/Full Service
G800M Add Write Flash/Read PIT/Full Service
G800R4 Add Write Flash/Read PIT/Full Service
G386F Add Write Flash/Read PIT/Full Service
G7105 Add Write Flash/Read PIT/Full Service
G7105L Add Write Flash/Read PIT/Full Service
T335 Add Write Flash/Read PIT/Full Service
T237P Add Write Flash/Read PIT/Full Service
T537V Add Write Flash/Read PIT/Full Service
T335F3 Add Write Flash/Read PIT/Full Service
T537A Add Write Flash/Read PIT/Full Service
T537R4 Add Write Flash/Read PIT/Full Service
T535 Add Write Flash/Read PIT/Full Service
T530 Add Write Flash/Read PIT/Full Service
T531 Add Write Flash/Read PIT/Full Service
T331 Add Write Flash/Read PIT/Full Service
T365 Add Write Flash/Read PIT/Full Service
T360 Add Write Flash/Read PIT/Full Service
T327A Add Write Flash/Read PIT/Full Service
T337A Add Write Flash/Read PIT/Full Service
G3589W Add Write Flash/Read PIT/Full Service
G3589V Add Write Flash/Read PIT/Full Service
G3568V Add Write Flash/Read PIT/Full Service
G3586V Add Write Flash/Read PIT/Full Service
G3588V Add Write Flash/Read PIT/Full Service
G3586H Add Write Flash/Read PIT/Full Service
G3558 Add Write Flash/Read PIT/Full Service
G3559 Add Write Flash/Read PIT/Full Service
G3556D Add Write Flash/Read PIT/Full Service
G355H Add Write Flash/Read PIT/Full Service
G3518 Add Write Flash/Read PIT/Full Service
M380K Add Write Flash/Read PIT/Full Service
M570K Add Write Flash/Read PIT/Full Service
M570S Add Write Flash/Read PIT/Full Service
i8580 Add Write Flash/Read PIT/Full Service
Add Read and Write NVM For All New Phone models
Add Clear Log Button
Add What's news Button
Download
Asansam Box Powered With Asansam Team
Please
Wait
For
Hot
and
Amazing
Updates
BR
ASANSAM TEAM
ASANSAM rev 2.5.6 Released
Add S7262 Flash/Read PIT/Full Service(Except ROOT)/Repair IMEI/Repair Network (*)
Add S7270 Flash/Read PIT/Full Service(Except ROOT)/Repair IMEI/Direct Unlock(BETA)
Add S7272 Flash/Read PIT/Full Service(Except ROOT)/Repair IMEI/Direct Unlock(BETA)
Add S7580 Flash/Read PIT/Full Service(Except ROOT)/Repair IMEI/Direct Unlock(BETA)
Add S7582 Flash/Read PIT/Full Service(Except ROOT)/Repair IMEI/Direct Unlock(BETA)
(*) For Repair IMEI Select S7262 Model then Going to Setting TAB and Check 'Repair Network (Some New Android Models)'
Then Return to General Service TAB and enter Your Selected IMEIs then Click Repair IMEI
DOWNLOAD
Wait for Amazing Updates..
BR
ASANSAM TEAM
