reWarning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 16 (98 bytes)
Warning: failed to write 1 - 18 (98 bytes)
Warning: failed to write 1 - 20 (98 bytes)
Warning: failed to write 1 - 22 (16 bytes)
Warning: failed to write 1 - 23 (4 bytes)
Warning: failed to write 1 - 24 (84 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 26 (110 bytes)
Warning: failed to write 1 - 28 (98 bytes)
Warning: failed to write 1 - 29 (10 bytes)
Warning: failed to write 1 - 31 (98 bytes)
Warning: failed to write 1 - 33 (36 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Warning: failed to write 1 - 35 (16 bytes)
Warning: failed to write 1 - 37 (4 bytes)
Warning: failed to write 1 - 39 (36 bytes)
Warning: failed to write 1 - 44 (182 bytes)
Warning: failed to write 1 - 45 (182 bytes)
Warning: failed to write 1 - 46 (64 bytes)
Section: 2Warning: failed to write 11 - 55 (1 bytes)
Warning: failed to write 11 - 56 (1 bytes)
Warning: failed to write 11 - 57 (1 bytes)
Warning: failed to write 11 - 58 (1 bytes)
Warning: failed to write 11 - 59 (1 bytes)
Warning: failed to write 308 - 0 (1 bytes)
Warning: failed to write 308 - 1 (8192 bytes)
Warning: failed to write 308 - 3 (1 bytes)
Warning: failed to write 308 - 4 (1 bytes)
Warning: failed to write 308 - 6 (1 bytes)
Warning: failed to write 308 - 7 (1 bytes)
Warning: failed to write 308 - 9 (40 bytes)
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes
vào sevce PM SUPER SD Auth. rồi write lại 1 lần nũa. unlock = ok
Nếu SUPER SD Auth kg đc thì PMM Auth ok. có gì báo lại nha
