mình mới nhận cây 5300 bi treo máy khi mở nguồn,em vệ sinh rồi mà ko hết,bỏ vào box mxkey chạy thì log như sau,mong các pro chỉ dùm em với
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010)
Processing MCU file: rm146__07.20.mcusw
[BB5,BB5 ALGORITHM] size: 14.56 MB
Supported Ids: 0103192101001101, 010C192101001101
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 23700203EA6E6B56073316B53BC021A1DA827F29
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,CMT
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
CMT PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT NOR area [00000000-000006BF] erased in 0.093 s
CMT NOR area [000006C0-0001FFFF] erased in 0.157 s
CMT NOR area [00020000-0007FFFF] erased in 0.187 s
CMT NOR area [00080000-000DFFFF] erased in 0.187 s
CMT NOR area [00100000-001FFFFF] erased in 0.344 s
CMT NOR area [00200000-0031FFFF] erased in 0.344 s
CMT NOR area [00320000-0105FFFF] erased in 3.140 s
CMT NOR area [01060000-01067FFF] erased in 0.141 s
CMT NOR area [01068000-0107FFFF] erased in 0.140 s
Flash programming ...
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00020000, Result: 0010
Flashing terminated with error(s) in 33.546 s
RX Buffer: C7012D0103CD000010000000F172
