Kết quả 11 tới 15 của 15
  1. #11
    Thành viên danh dự minhung334's Avatar
    Jul 2008
    TpHCM
    còn đây log JAF:
    JAF version 1.98.66 beta5
    Detected PKEY: 90019A02
    Detected JAF INTERFACE version: 01.B4, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.1.34.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Booting phone...
    FAST PHONE detected!
    CMT Boot Data:
    Asic ID: 000000010000022600010006400C192101031103
    Asic Mode ID: 00
    Asic EM ID: 00000B22
    Asic Public ID: 11F00008097200529FB1D2B87DFAAD1F6776E8D5
    HASH: 9A28E119033B91D14D22838C86D0D53C00000000
    ROM ID: 4B9B75103E691FF8
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg
    Loader version: 01.23.00 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V ICPR71_09w04.2
    19-02-09
    RM-437
    (c) Nokia
    HW version: 0801
    PCI version:
    RFIC version:
    DSP version:
    Retu version: 16
    Tahvo version: 22
    Production serial number: M7I049124
    Product code: 0575098
    Module code:
    Basic production code: 0561985
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 359319021159497
    IMEI spare to net: 3A 95 13 09 12 51 49 09
    IMEI SV to net: 33 95 13 09 12 51 49 09 F4
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-437.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Done!
    Setting test mode...
    Setting FULL FACTORY...
    Operation took 0 minutes 10 seconds...
    Done!
    Resetting USER DATA...
    Operation took 0 minutes 0 seconds...
    Done!
    Done!
    k lẻ phải nạp FW sao mấy A?
  2. #12
    Thành viên chính thức 0976094394's Avatar
    Apr 2011
    Tam Dảo-vinh phuc
    thời gian đâu mà đẻ hum sau khách ló không chờ đươc đâu phang cho em nó cái
  3. #13
    Thành viên kỳ cựu juyaku's Avatar
    Jan 2010
    Quan Họ - Bắc Ninh
    Trích Được post bởi ThanhHai_GSM Xem bài viết
    cái này do nhập sai quá 5 lần
    nếu khác không hối gỡ pin ra để sau 20 > 30 phút nhập lại ok
    Để cho máy giải lao như trên... nhé
    Mobile: 0972.769.687 -0976.999.093 Đc: KCN Quế Võ Bắc Ninh Email: kimluanmobile@gmail.com
  4. #14
    Thành viên chính thức my2kforever's Avatar
    Sep 2007
    Có những con flash cũng ko hết luôn. Cứ để vậy cắm sạc đầy pin nhập lại 12345 là ok.
  5. #15
    V.I.P Lão_Đại's Avatar
    hải phòng
    Thêm thông tin ( Nhấc pin ra quán làm 5 vại beer , khoảng 2h sau bàn phím nhớ để về chế độ số nhé đã test OK )
  1. 7610 thật khó hiểu
    By trathanhtung in forum DCT4 - WD2
    Bài viết cuối: 13-05-2010, 11:37
  2. Vẫn V3i tq thật khó sửa
    By hoanghoatham in forum MOTOROLA
    Bài viết cuối: 09-11-2007, 19:16
  3. 3380 thật khó hiểu ????
    By vuongnet_gsm in forum Phần mềm và các mã lệnh
    Bài viết cuối: 24-10-2007, 14:54
