máy mới đầu thỉnh thoảng đang dùng khởi động lại
log chạy bằng mxkey:
Version from phone: 05wk07v48.1
Version from file: 50737301.C0
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35291302170520_BA CK.rpl).
Processing MCU file: RM84_50737301.C0
[BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.41 MB
Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200
Supported Ids: 17100701, 17100702
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 16300019E6726B51B57F1F981F13A6922D0A244F
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
TransmissionMode: DDR&TX2
Partitioning ...OK
Erase size: 68.92 MB
CMT NOR area [00000000-0052B515] erased in 32.687 s
CMT NOR area [006A0000-006BFFFF] erased in 0.157 s
CMT NOR area [006DF000-006EFFFF] erased in 1.047 s
CMT NOR area [00700000-007EFFFF] erased in 6.781 s
APE NAND area [00000000-0000FFFF] erased in 0.140 s
warning : erase sector address out of chip bound.
APE NAND area [00010000-0001FFFF] erased in 0.141 s
APE NAND area [00020000-000203FF] erased in 0.140 s
APE NAND area [00050000-03ECFFFF] erased in 0.156 s
Flash programming ...
CMT PAPUBKEYS: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D (Rap certificate3) written.
Error chk C7012D0100D0000010000000F1
Error while programming [01] at 0x00000000, Result: 0010
Flashing terminated with error(s) in 1 min 23.281 s
RX Buffer: C7012D0100D0000010000000F172
đây là log jaf crack:
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
USB Cable Driver version: 7.1.36.0
Changing mode...Done!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101002200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 16300019E6726B51B57F1F981F13A6922D0A244F
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv2_2nd.fg
Loader version: 01.10.02 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg
Loader version: 01.0C.05 -> Revision: 0000
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_51003301.C0
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_51003301.V29
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\35291302170520_CRT_backup _8295.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Setting local mode...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\352913021705205_CRT_backu p_8295.pm
Done!
Backup LCK OK!
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!
e đã câu ape theo hình này:
và hình này:
đã thay các cáp khác vẫn chạy máy khác bình thường
