				con máy này có bị rơi đát ko . a xem main có bị cong ko . khi bật nguồn lấy tay ấn cặp 2 tầng . xem sao
yahoo: viethuy_mobi
tran_ba (27-05-2011)
				MXKEY Serial: [FT SCR2000 0] - C0845DFF
Driver: UFS2XX, ver: 2.0.0.0, NTMP ver: 2.0.0.1
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
Processing MCU file: rm561__09.98.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1A00010C34B14950202A6E7E4FC8D26CB84F3FBA
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21 MB
CMT NOR area [00000000-000006BF] erased in 0.593 s
CMT NOR area [000006C0-0001FFFF] erased in 0.157 s
CMT NOR area [00040000-000BFFFF] erased in 2.218 s
CMT NOR area [000C0000-0013FFFF] erased in 0.219 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 10.062 s
CMT NOR area [01380000-0151FFFF] erased in 6.875 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100303130 (RAP Certificate 202 v.1) sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 13 min 7.860 s
Processing PPM file: rm561__09.98.ppm_t
[BB5,BB5 ALGORITHM] size: 6.62 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 28.000 s
Programming completed in 4 min 47.703 s
Processing CNT file: rm561__09.98.image_t_ph_gray
[BB5,BB5 ALGORITHM] page size: 128 K size: 10.89 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 34 MB
CMT NOR area [01DC0000-0215FFFF] erased in 0.922 s
CMT NOR area [02160000-03FBFFFF] erased in 49.781 s
Programming completed in 7 min 25.375 s
Total time for flashing process(boot+erase+write) was 28 min 52.968 s
Phone not responding !
DIA_NGUC_MA
0984745666
				cũng đã chạy thử dea usb rồi ae ơi, chua quá. lôi đâu ra cặp thay vao bây giờ ae? ae nào có để lại cho em một cặp đi
DIA_NGUC_MA
0984745666
				mình cũng đang gặp một em như thế .thấy anh em bảo thay cặp .không biết pro trong đây có cách xử lý tốt hơn không
Thanh Tùng MobileĐịa chỉ : Chợ gạo - Thành Lợi - Vụ Bản - Nam Định
Phone : 0905022590
				em cũng đang kiếm cặp thay vào mà chưa biết kiếm đâu ra. co cặp 2730 mà không biết có chạy được không. chưa test thử
DIA_NGUC_MA
0984745666
				thanks all . máy đã trả mất rồi,
DIA_NGUC_MA
0984745666
