Kết quả 1 tới 3 của 3
vanthanhmobile anh em xem hộ log 5220 01-06-2011, 08:19
Hà Linh Mobile™ Chạy lại đi đã bạn, xem log... 01-06-2011, 09:19
juyaku Lấy File Good mà phang vào đi... 01-06-2011, 09:35
    Thành viên chính thức vanthanhmobile's Avatar
    Mặc định anh em xem hộ log 5220
    tình hình may nghe nhac báo bộ nhơ đầy.không có bộ suu tạp không có nhac chuông
    Detected PKEY: 9000C53C
    Detected version: 01.B4, Driver version: 0, Library version: 0
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Fast phone flashing selected.
    Booting phone...
    FAST PHONE detected!
    CMT Boot Data:
    Asic ID: 000000010000022600010006030C192101033000
    Asic Mode ID: 00
    Asic EM ID: 00000B22
    Asic Public ID: 154000118E9F025483C43B5FBE5C67C42C7F668F
    HASH: 9DDBFCFE6E73CED7D8C6268C8EB8572300000000
    ROM ID: 273F6D55DFAAF68F
    Error finding cmt boot file...
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 07.23
    17-07-09
    RM-411
    (c) Nokia
    HW version: 1000
    PCI version:
    RFIC version:  064c0601
    DSP version:
    ICPR72_09w17
    LCD version: SHARP
    PPM version: V 07.23
    17-07-09
    RM-411
    (c) Nokia
    V
    BT MCM version: 2222-143C
    Retu version: 15
    Tahvo version: 22
    Production serial number: DTB749129
    Product code: 0563660
    Module code: 0203661
    Basic production code: 0554881
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 353662010318400
    IMEI spare to net: 3A 35 66 02 01 13 48 00
    IMEI SV to net: 33 35 66 02 01 13 48 40 F0
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-411.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Done!
    Jan 2009
    Chạy lại đi đã bạn, xem log ko đọc được cái bệnh như bạn nói đâu
    Thành viên kỳ cựu juyaku's Avatar
    Jan 2010
    Quan Họ - Bắc Ninh
    Lấy File Good mà phang vào đi nha.... :rolleyes:
    Mobile: 0972.769.687 -0976.999.093 Đc: KCN Quế Võ Bắc Ninh Email: kimluanmobile@gmail.com
  1. 5220 liệt phím
    By huynhdetuongtan in forum BB5
    Bài viết cuối: 29-06-2012, 07:49
  2. 5220 ko hiển thị màn hình
    By hibimobile in forum BB5
    Bài viết cuối: 24-03-2012, 10:35
  3. 5220 sơ đồ
    By anhphapvt in forum BB5
    Bài viết cuối: 29-12-2010, 18:24
  4. 5220 sạc hoài không đầy pin
    By minhhoang in forum BB5
    Bài viết cuối: 08-03-2010, 16:05
  5. 5220 ko den
    By N-C in forum BB5
    Bài viết cuối: 03-11-2009, 10:04
