Kết quả 1 tới 10 của 11
    Thành viên chính thức truonghan162's Avatar
    Jun 2011
    Nha Trang
    Mặc định HElp em voi 5130xm
    chạy phần mềm ra log như vầy mà bật nguồn lên nokia xong sụp . em moi vao nghề vọc nên anh em giúp dùm
    JAF version 1.98.65 beta1
    Detected PKEY: 9000AAC9
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 7.1.40.0
    Changing mode...Done!
    Searching for phone...Detected P-KEY: 9000AAC9
    Init usb communication...
    Found
    Error reading full info...
    Found
    Failed! Aborting!
    Failed! Aborting!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-495\
    Checking path: \Products\RM-495\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.image_v_red
    Backing up CRT...
    Failed to backup CRT...
    PRESS POWER ON NOW!
    Searching for phone...Found
    Sending RAW loader...
    Using 06.02.002
    Elf2flash 09.07.000
    CMT RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step3...
    Sending RAW Loader...
    ...................Loader Sent!
    Stage 2 starting.......................................... .....................................Loader Sent!
    Stage 3 starting..................Phone prepared OK!
    Waiting for the phone to boot...
    Status byte: 8000
    Selecting CMT flash...
    Result: 0000
    Phone is in flash mode...
    CMT blocks: 2430, APE blocks: 0
    Erasing cmt...
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.mcusw...
    Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000
    Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000
    Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
    Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
    Erasing cmt zone 00140000 - 0137FFFF ... Erase result: 0000
    Erasing cmt zone 01380000 - 0151FFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.ppm_v...
    Erasing cmt zone 01520000 - 01DBFFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.image_v_red...
    Erasing cmt zone 01DC0000 - 0215FFFF ... Erase result: 0000
    Erasing cmt zone 02160000 - 03FBFFFF ... Erase result: 0000
    Send CMT CFG...
    Writing cmt...
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    cmt->PAPUB keys already sent...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Rebooting...
    Finishing CMT session...
    Restarting CMT...
    Pooling phone...
    MCUSW: V 07.97
    13-09-10
    RM-495
    (c) Nokia
    APESW: (null)
    VariantSW: (null)
    Prodcode: 0575359
    Done!
    Changing mode...
    Done!
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    bạn đưa qua box khác hoặc dùng Phoenix để flash thủe xem như thế nào nhé. nếu flash mãi ko được thì làm lại nhà lầu thôi.
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    chuyển bõ kahcs múc nó đi bạn . có thì mang sang hwk múc nó
    yahoo: viethuy_mobi
    Jun 2011
    Nha Trang
    chạy bằng pheonĩ ra log vầy :
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 14592 bytes
    Secondary boot loaded
    Loading update server code: 308032 bytes
    Update server loaded
    Asic CMT: Verifying communication to device...
    Asic CMT: Start programming 38485 KB...
    Asic CMT: Erasing rm495__07.97.mcusw
    Asic CMT: Erasing area 1...
    Asic CMT: Erasing area 2...
    Asic CMT: Erasing area 3...
    Asic CMT: Erasing area 4...
    Asic CMT: Erasing area 5...
    Asic CMT: Erasing area 6...
    Asic CMT: Erasing rm495__07.97.ppm_v
    Asic CMT: Erasing rm495__07.97.image_v_red
    Asic CMT: Programming rm495__07.97.mcusw
    Asic CMT: Programming 0%
    Asic CMT: Programming 2%
    Asic CMT: Programming 4%
    Asic CMT: Programming 6%
    Asic CMT: Programming 8%
    Asic CMT: Programming 10%
    Asic CMT: Programming 12%
    Asic CMT: Programming 14%
    Asic CMT: Programming 16%
    Asic CMT: Programming 18%
    Asic CMT: Programming 20%
    Asic CMT: Programming 22%
    Asic CMT: Programming 24%
    Asic CMT: Programming 26%
    Asic CMT: Programming 28%
    Asic CMT: Programming 30%
    Asic CMT: Programming 32%
    Asic CMT: Programming 34%
    Asic CMT: Programming 36%
    Asic CMT: Programming 38%
    Asic CMT: Programming 40%
    Asic CMT: Programming 42%
    Asic CMT: Programming 44%
    Asic CMT: Programming 46%
    Asic CMT: Programming 48%
    Asic CMT: Programming rm495__07.97.ppm_v
    Asic CMT: Programming 50%
    Asic CMT: Programming 52%
    Asic CMT: Programming 54%
    Asic CMT: Programming 56%
    Asic CMT: Programming 58%
    Asic CMT: Programming 60%
    Asic CMT: Programming 62%
    Asic CMT: Programming 64%
    Asic CMT: Programming rm495__07.97.image_v_red
    Asic CMT: Programming 66%
    Asic CMT: Programming 68%
    Asic CMT: Programming 70%
    Asic CMT: Programming 72%
    Asic CMT: Programming 74%
    Asic CMT: Programming 76%
    Asic CMT: Programming 78%
    Asic CMT: Programming 80%
    Asic CMT: Programming 82%
    Asic CMT: Programming 84%
    Asic CMT: Programming 86%
    Asic CMT: Programming 88%
    Asic CMT: Programming 90%
    Asic CMT: Programming 92%
    Asic CMT: Programming 94%
    Asic CMT: Programming 96%
    Asic CMT: Programming 98%
    Asic CMT: Programming 100%
    Phone flashing completed. Waiting for phone to boot up
    Bootup successful
    Verifying communication to product (before flash finalizing)
    Communication verified
    Product code changed
    Doing factorysets
    Factorysets complete
    Reading Dynamic Camera Configuration ID 1
    Updating configuration of camera with ID 1
    Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string NIMMIIIIRRFF094B2F01 was found.
    Loading default data to phone
    Getting Data Package
    Reading product state
    Starting backup/restore sub-procedure: data item pre-delay
    data item pre-delay
    data item pre-delay
    Sub-procedure completed: Succeeded., result code: 0
    Starting to backup/restore data item: ProductProfile, version: 1.1
    Data Item backup/restore completed: Succeeded., result code: 0
    Starting backup/restore sub-procedure: data item post-delay
    data item pre-delay
    data item pre-delay
    Starting to backup/restore data item: Certificates, version: 1.0
    data item pre-delay
    data item pre-delay
    Starting to backup/restore data item: ISSVariantActivator, version: 1.0
    Backup/restore result: 0 out of 3 items were not backed up
    Default data loading complete
    Stopping all operations, returning phone to default mode
    All operations completed
    Firmware updating succeeded.
    Mấy anh xem dum em với . phần cứng thi ok tai may đang chay bt ma em nghich dai chay thử
    V.I.P phungtien's Avatar
    Nov 2007
    cà mau
    đem wa jaf chạy lại cái bạn
    SÓNG GIÓ CUỘC ĐỜI NUÔI TA LỚN,BÃO TÁP CUỘC ĐỜI DẠY TA KHÔN
    Jun 2011
    Nha Trang
    em chạy bằng jà báo như ở trên 1. mới chạy lai băng pheonĩ ra như vậy , ko hieu lỗi ở đâu luôn ?
    Thành viên chính thức longcltv's Avatar
    Oct 2009
    ông chạy J.A.F = cable usb à ? ko có cable ốp lưng sao ? info lại quăng log lên đi ! quăng log flash có nói lên điều jì đâu ! nhớ là quăng log info
    dòng này : Error reading full info... tức là ko info đc => máy lúc đầu bị jì rồi hoặc cọng cáp usb có vấn đề
    tức là máy ban đầu bị jì ? rớt nước - rớt đất jì ko ? nói ko rõ quăng log lên cũng ko rõ thế sao mà a/e giúp đc ! Thân !!!
    Jun 2011
    Nha Trang
    HIc máy đang bình thường ko bị gì cả . tý tởn đem ra nghich cha lai flash thử xem thế nào => ra thế .ko có cap áp lưng nếu có lai đơn gian rùi. chi có thể chạy băng jaf usb va phoenix thui . lúc đầu còn ìno dc jo hết info dc . => po tay
    Jun 2011
    Nha Trang
    thanks các bác nhiều em đã làm đc rồi . cảm ơn sự nhiệt tình của các bác:rolleyes:
    Oct 2009
    tân phú-đồng nai
    Trích Được post bởi truonghan162 Xem bài viết
    chia sẻ a/e cách chữa hết pan của bạn để ae tham khảo bạn hiền.!
  1. 5130xm CONTACT SERVICE
    By ngocminhhungyen in forum BB5
    Bài viết cuối: 09-12-2010, 16:46
  2. 5130xm piout
    Bài viết cuối: 09-12-2010, 08:35
