nhờ anh em xem log này bị lổi ở đâu. đã chạy lại pm, lúc đầu máy bị rớt nước dã qua thợ khác làm rồi. đem đến tình trạng máy hay bị khởi dộng lại
MXKEY Serial: [FT SCR2000 0] - C08402E3
Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011)
CMT Data :
SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1]
EM0 ID: 00001040
EM1 ID: 00001030
PUBLIC ID: 1AC00113627F034485906751E5EEF8435B3B3E65
ASIC MODE ID: 00
ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
ROM ID: 3E273BF637BE26FA
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104
No RAP Flash Chip Detected
TransmissionMode: 16Bit
Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60
CMT PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E
TransmissionMode: DDR&TX2
Original Imei: 35272404205132
Original Product code: 0587055
Bluetooth ID: 80501BB7F1B6
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Phone Type: RM-530 (Nokia E72-1)
SW Version: V ICPR82_10w22.10.1 01-02-11 RM-530 (c) Nokia
Imei plain: 35272404205132-5
Product Code: 0587055
Battery voltage: 4577 mV, current: 0 mA
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 352724042051325
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
xin chỉ dùm. thank
