Kết quả 11 tới 20 của 26
    Thành viên tích cực tranvantinh's Avatar
    Sep 2007
    em mất mua log không mấy anh
    V.I.P ThanhHai_GSM's Avatar
    Trích Được post bởi tranvantinh Xem bài viết
    không phải mua chỉ cần unlock và SD >sx4 và Pm là done
    qua yahoo tôi làm cho: hai_th4748
    Sep 2007
    sao em repair simlock , nó báo thế nầy hoài vậy mấy anh
    SIMLOCK_DATA corrupted!
    MXKEY Serial: [FT SCR2000 0] - C0807688
    Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0
    Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
    Product: V 07.23 17-07-09 RM-436 (c) Nokia
    Using cached productData[0A30020D97045950D902CFFD3739110DBFB19FDC] ...
    Calculating SIMLOCK using security server ...
    [UnauthorizedFault] Sorry C0807688, your [CR2]BB5 remaining credits is null or empty
    If your credit is less than 100, this service will consume 1 credit.
    Please contact authorized reseller from your country area for MXKEY credits listed here:
    MXKEY CREDITS - Authorized Distributors and Resellers - GSM-Forum
    Reading Simlock info ...
    Sep 2007
    em có , được không anh
    ID 662 030 736
    PASS 6157
    Sep 2007
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
    EM0 ID: 00000295
    EM1 ID: 00000B22
    PUBLIC ID: 0A30020D97045950D902CFFD3739110DBFB19FDC
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
    ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
    TransmissionMode: 16Bit
    Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
    CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
    TransmissionMode: DDR&TX2
    Original Imei: Empty
    Original Product code: Empty
    NPC_DATA invalid !
    Phone Type: RM-436 (Nokia 7210 Supernova)
    SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
    Imei plain: 12345610654321-?
    Product Code: 0566806
    Battery voltage: 4426 mV, current: 74 mA
    Language Pack:
    - not available.
    SIMLOCK invalid!
    SUPERDONGLE_KEY invalid!
    - WD timer enabled, phone will reboot itself after 3 min.
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei plain is invalid !!!
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    writer RPL lại
    ( ko có thì thay cặp )
    ripair SD
    còn
    cho vào mx repair simlook là ok bạn ak
    yahoo: viethuy_mobi
    Thành viên tích cực Phungmobi's Avatar
    Sep 2010
    IMEI : 359310-02-172074-3 ban đầu có imei mà ...có bakup không vậy
    May 2011
    Hà Nội City
    sao imei bây giờ đẹp thế?
    lúc đầu có imei đàng hoàng cơ mà
    có backup không thì lây ra mần
    còn không thì kiếm cho em nó cái cặp để em nó còn đi học. hê hê
    Sep 2010
    bạn kiểm tra lại xem có bakup không....nếu không có chỉ còn cách thay cặp thôi
    Dec 2009
    thế lúc đầu bạn flash bằng box hì . nếu mx và jap thì may ra đó bạn .( ko có dùng SEARCH tìm hết mọi ở máy tính xem nó có ko )
    yahoo: viethuy_mobi
  1. 7210c mất nguồn
    By thichphamobi in forum BB5
    Bài viết cuối: 08-10-2012, 11:54
  2. câu phím nguồn 7210c
    By phamtrung in forum BB5
    Bài viết cuối: 02-09-2012, 11:42
  3. 7210c Mất Nguồn!
    By MrMaru in forum BB5
    Trả lời: 22
    Bài viết cuối: 07-11-2011, 17:59
  4. Trả lời: 8
    Bài viết cuối: 21-09-2011, 14:07
  5. 7210c tự khởi động nguồn
    By MINH&THÙY_mobile in forum BB5
    Bài viết cuối: 25-03-2011, 17:53
