Kết quả 1 tới 8 của 8
    Thành viên chính thức mrtuong1987's Avatar
    Dec 2008
    Mặc định 6300 tự mất nguồn
    Em có cây 6300 dùng tầm 5 - 10p tự mất nguồn. đã chạy lại và thay IC nguồn nhưng vẫn không được. AE xin giúp
    JAF version 1.98.66 beta5
    Detected PKEY: 9002D656
    Detected JAF INTERFACE version: 01.B4, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.1.39.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 07.21
    05-11-08
    RM-217
    (c) Nokia.
    HW version: 0614
    PCI version:
    RFIC version:  17211721
    DSP version:
    ICPR61_08w10
    PPM version: V 07.21
    05-11-08
    RM-217
    (c) Nokia.
    V
    BT MCM version: 06cc-P9.1
    Retu version: 32
    Tahvo version: 53
    Content Pack version: Content: v
    V 07.21
    05-11-08
    RM-217
    (c) Nokia.
    Production serial number: CMH526694
    Product code: 0563812
    Module code: 0203166
    Basic production code: 0563174
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356901034453117
    IMEI spare to net: 3A 65 09 01 43 54 13 01
    IMEI SV to net: 33 65 09 01 43 54 13 21 F5
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-217.ini
    Setting local mode...
    Reading product code...
    Product Code: 0563812
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.ppm_r
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.image_ctv_cn
    Languages in ppm: English,Chinese Trad ,Chinese Simpl (China)
    Done!
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    bạ dùng MX key bus check cai log lên xem thế nào. mình nghĩ con này chưa đc sx4 thành công.
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    có mxkey sửa lỗi đoạn này đi bạn,nghe nhạc 5>10p là tắt nguồn
    Dec 2008
    nhà lại không có MXkey chi lại. Để mình mang qua chỗ khác xem có được không
    Như Xuân_Thanh Hóa
    Trích Được post bởi tlpmobile_tk Xem bài viết
    config key vẫn đẹp mà. nhưng cái này chưa sx4 thành công nên chỉ dùng đc 3 phút là tắt.
    V.I.P ThanhHai_GSM's Avatar
    log jaf không nói được điều gì có mxkey scan sẽ rõ
    kể cả mxkey có báo CONFIG KEY: 0000000000000000 cũng ảnh hưởng tới bệnh 5>10 phút mất nguồn mà báo hạn chế điện thoại
    con máy này 100% lỗi SECURITY_TEST
    bạn có mxkey cho vào reipair SD > sx4 và pm 1 &309 => done
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    con này e nghĩ chỉ cần repair SD là ok rùi
    yahoo: viethuy_mobi
    Thành viên chính thức MANHTHAI's Avatar
    Jun 2011
    E cung ngi vay
  1. Trả lời: 5
    Bài viết cuối: 30-01-2013, 14:51
  2. Trả lời: 13
  3. Trả lời: 21
  4. Trả lời: 8
    Bài viết cuối: 14-10-2010, 11:53
  5. Trả lời: 10
    Bài viết cuối: 28-11-2009, 17:09
