cho sim vào contet sẻvit roi tắt may. nếu ko cho sim vào máy hỏi khởi dộng ko cần thẻ sim thì hiện lên chữ contes sevit rồi tắt luôn
dây nhờ ae xem dùm
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085C6B5
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.67
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
Processing MCU file: rm561__09.98.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 25408D92
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 28300117AA4D7F560A86D27200B16D0399B7D3E9
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 3B791826
Verifying communication to device OK.
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF] erased in 0.765 s
CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.735 s
CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.797 s
CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.516 s
CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 40.922 s
CMT FLASH,NOR area [01380000-0151FFFF] erased in 8.828 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 1 min 9.937 s
Processing PPM file: rm561__09.98.ppm_x
[BB5,BB5 ALGORITHM] size: 6.91 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF] erased in 46.453 s
Programming completed in 25.203 s
Processing CNT file: rm561__09.98_009.image_x_ctv_id_v3_96897
[BB5,BB5 ALGORITHM] page size: 128 K size: 15.64 MB
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 22.922 s
CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 22.140 s
Programming completed in 56.703 s
Total time for flashing process(boot+erase+write) was 9 min 15.406 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 2700 classic USB Phonet, PORT_ID: 18B2E338
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35419203121587-1
Battery voltage: 3784 mV, current: 76 mA
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Market items is empty, please select the correct products path !
