ae coi dùm cái log lúc nhận lên bình thường chỉ hao nguồn sau và mất sóng dò mạng không được làm hết hao nguồn đem flash cái báo vậy là sao ae coi dùm thanks all
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 1] - C0859FE9
Using device: HTI BOX, FW ver: 00.17
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Processing MCU file: rm578__10.45.mcusw
[BB5,BB5 ALGORITHM] size: 21.65 MB
Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101023000
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 23A00103A4CA8C563397E7B2CEADC0768E8D13DD
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
CMT PAPUBKEYS HASH: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 23.25 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0155FFFF]
CMT FLASH,NOR area [01560000-0175FFFF]
erased in 2 min 1.062 s
Prog.status for Asic CMT ...
NOR: Success
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 8669C775 [RAP Certificate 215 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: Success
Programming completed in 1 min 40.313 s
Processing PPM file: rm578__10.45.ppm_v
[BB5,BB5 ALGORITHM] size: 6.78 MB
Bootstrap failed!
