Kết quả 1 tới 4 của 4
    Thành viên chính thức HQuangmobile's Avatar
    Nov 2011
    Mặc định xin giúp xem log 72
    JAF version 1.98.62
    Detected PKEY: 0012F584
    Card life counter: 99.99%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101012200
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 03E00016AD5D5A51D60F27C9AA2E9C1F9C570CA5
    HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
    ROM ID: F28A211FCEA7B19D
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
    Loader version: 01.15.00 -> Revision: 0000
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 00020001 <=> SPANSION -> Type not in database
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-180\RM180_50819401.C0
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-180\RM180_50819401.V01
    Languages in ppm: English,French,German,Italian,Spanish,Portuguese
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35629501192127_CRT_backup _2123186.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\356295011921273_CRT_backu p_2123186.pm
    Done!
    Backup LCK OK!
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Operation took 0 minutes 3 seconds...
    Sending CNF Data...
    APE blocks present in flash file but no APE mcu detected in phone. Aborting!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Done!
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Saved to C:\Program Files\ODEON\JAF\ProgData\35629501192127_CRT_backup _2134186.rpl
    Backup CRT OK!
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\356295011921273_CRT_backu p_2134186.pm
    Done!
    Backup LCK OK!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Operation took 0 minutes 4 seconds...
    Sending CNF Data...
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Done!
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05wk07v48.2
    04-10-07
    RM-180
    (c) Nokia.
    HW version: 5002
    PCI version:
    RFIC version: 150a160f
    DSP version: rolf_espresso_05wk07v29p1
    Retu version: 32
    Tahvo version: 53
    Production serial number: CJI647022
    Product code: 0531541
    Module code:
    Basic production code: 0530940
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356295011921273
    IMEI spare to net: 3A 65 92 05 11 29 21 07
    IMEI SV to net: 33 65 92 05 11 29 21 07 F9
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Done!
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\356295011921273_CRT_backu p_2313186.pm
    Done!
    Backup LCK OK!
    Reading simlock data...
    LOCK STATUS:
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Phone is not locked!
    Phone Type:
    Phone Type:
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Saved to C:\Program Files\ODEON\JAF\ProgData\35629501192127_CRT_backup _2315186.rpl
    Backup CRT OK!
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\356295011921273_CRT_backu p_2315186.pm
    Done!
    Backup LCK OK!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CNF Data...
    chú ý sử dụng tiếng Việt có dấu và đặt tiêu đề rõ ràng
    đã edit tiêu đề
    Nov 2011
    ko co ai jup e voi ak ? vietkey cua e bi hong~ roi cac a thong cho e nhe
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    log báo thiếu áp APE ..nếu máy lên trắng treo thì câu áp rồi flash lại
    Nov 2011
    e cau cac kieu roi ma ko duoc ? ae nao co cach khac thi jup e voi
