Bung yahoo đi mình chạy die usb phoenix cho ok
thaibinh_mobile (05-12-2011)
ae nào plash c3 00 qua cap đa năng rùi cho mình xin với ạ
Chạy die usb toàn lỗi ạ
[BB5,XSR 1.6] size: 8.91 MB
Supported Ids: 2200050920030000, 22000509200C0000
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1165B401
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 900944050509B7A4F101AC70C91415AED92B7168
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: FFFF FFFF - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x0 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x0 bytes).
Reading CMT HWC (0x0 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Invalid Certificate Data, backup will not be created.
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 33.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT ADA block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 697F7477 [RAP Certificate v1 232] sent
CMT UPDAPP block sent
CMT MCUSW block sent
Programming completed in 3.469 s
Processing PPM file: rm614__07.20.ppm_v
[BB5,XSR 1.6] size: 6.79 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
Programming completed in 2.594 s
Processing CNT file: rm614__07.20.image_v_0594046
[BB5,XSR 1.6] size: 12.44 MB
Erase size: 75.31 MB
CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
Converting UCP blocks to 128 K.
Error converting UCP!
Task failed at (08000009)!!!
Last RX buffer: 82 10 6D 00
cái này C3 00 đã hỗ trợ plash bằng cáp f bush đâu mà đòi pin out
chạy die usb đi
buồn vơi các ngài wa,.có nhìn thấy cai gì đâu.???????????????????????????????????????????? ?????????![]()
up.... em đang cần pin out con C3 này ... anh em giúp với
con này chỉ chạy được cáp u sb thôi pinout không làm gì được đâu mà tìm
https://t.me/pump_upp
