Trang 2 của 4 Đầu tiênĐầu tiên 1 2 3 4 CuốiCuối
Kết quả 11 tới 20 của 32
    Moderator THIÊN UY™'s Avatar
    Bình Dương
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C08145D8
    Using device: HTI, FW ver: 00.24, SN: 00009B74
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 11A0010BD59B015613AACB0C58D94502B6CD0532
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 0089 8980 - 0000 8980 [Intel ] type: FLASH,NOR, asic:CMT
    Storage content: 8900 8089 8900 8089 8900 4DF9 8900 4DF9
    TransmissionMode: 16Bit
    CMT PAPUBKEYS is blank/erased.
    TransmissionMode: DDR&TX2
    Original Imei: 00000000000000
    Original Product code:
    đây là cai log khi buscheck = mxbox nè mấy pác ......
    Bình Dương
    lash = mxbox thi nhu thế này..........
    Processing MCU file: rm635__10.65.mcusw
    [BB5,BB5 ALGORITHM] size: 17.99 MB
    Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-0137FFFF]
    CMT FLASH,NOR area [01380000-0151FFFF]
    erased in 0.031 s
    Prog.status for Asic CMT ...
    NAND: Status reported bad blocks.
    Flash programming ...
    Error chk C7012D0103CD
    RX2 not responding, please check BSI/cable/pinout !
    Error while programming [00] at 0x000402C0, Result: 0000
    Task failed at (0800001C)!!!
    Last RX buffer: C7 01 2D 01 03 CD 00
    Bình Dương
    Đây là cái log của E nó nè mấy AE xem xong cho vài lời ........................thank..................
    1ST BOOT : C0,07 [Rm-635] [2.2.0.0]
    CMT ASICID: 000000010000022600010006030C192101033000
    EM 1 ID : 00000296
    EM 2 ID : 00000B22
    CMT PUBID : 11A0010BD59B015613AACB0C58D94502B6CD0532
    CMT MODE : 00
    CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROMID : 273F6D55DFAAF68F
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
    CMT FLID0 : 00898980-00008980, Int NU48F128
    CMT FLCNT : 000000890080898900808989004DF989004DF9
    CMT MCID0 : FFFF0000-00000000
    CMT 2ND Boot OK
    CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    PASUBTOC not Exists
    Rebooting Mobile
    Moderator TÚ CÒI's Avatar
    Oct 2008
    hà nội
    Log này ko giải quyết gì cả
    Lấy phoenix flat lại xem thế nào
    Bạn lên cho thêm thông tin về tình trạng main
    Chỉ có vài dấu ...... của bạn thì biết giúp sao đấy
    Nov 2010
    đưa hẳn cái log lên luôn đi bạn
    có thế thì chưa nói được gì
    Nov 2010
    thay cáp xem sao bạn
    có mxbox thì đưa cái log buscheck lên xem nào bạn
    Oct 2008
    hà nội
    Coi lại áp cấp cho CPU
    not ok đóng lại cặp
    Thành viên chính thức nanibk's Avatar
    Trích Được post bởi thienuy228 Xem bài viết
    2690 lên nguồn tối màn hình treo máy........cân sự giúp đỡ.........
    vấn đề đặt tiêu đề đã nhắc nhở rất nhiều và nội quy đã quy định vẫn vậy, edit hộ tái phạm 1 lần nữa band
    khi lên nguồn thì máy vẫn sáng màn hình một chút rồi mới tắt hay sao bạn
    Bình Dương
    Trích Được post bởi nanibk Xem bài viết
    kô có đèn mới đau đầu chứ................
    Bình Dương
    bỏ ăn cơm luôn.................
Hiện có 7 người đang xem bài này . Bao gồm : 0 thành viên và 7 khách
  1. Trả lời: 10
    Bài viết cuối: 23-05-2014, 10:33
  2. 2690 hao pin chờ cần giúp
    By thanhtan1987 in forum BB5
    Bài viết cuối: 20-02-2013, 14:24
  3. cần ae giúp cây 2690
    By NGỌC HÒA_GSM in forum BB5
    Trả lời: 24
    Bài viết cuối: 19-11-2012, 10:36
  4. 2690 bệnh lạ cần ae giúp...............
    By huynhphongmobile1 in forum BB5
    Bài viết cuối: 13-10-2012, 20:54
  5. 2690 rớt nước cần giúp
    By thaimobile_81 in forum BB5
    Bài viết cuối: 20-06-2011, 21:05
