tình hình em mới nhận con N81 của khách đã qua thợ khác làm mở nguồn hiện nokia rồi treo em cho vào mx check thì log như sau
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08569CD
Using device: HTI, FW ver: 00.24, SN: 0001306F
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 10B000125A860058B5062B37614E933C37A3AA4B
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: E70C21157D5AB5AF61AAD376910751FB06D6E9FD
Original Imei: Empty
Original Product code: Empty
NPC_DATA invalid !
SIMLOCK PA identifier:
[0] PA_SL2
Phone type: RM-179 (Nokia N81)
SW version: V 06wk41v62.4 04-12-08 RM-179 (c) Nokia
Imei plain: 12345610654321-?
Product code: 0545902
Battery voltage: 4709 mV, current: 7 mA
ApeCoreSw: 21.0.010
ApeVariant: 21.0.01021.0.010_14.01
ApeTest: rm179_ENO_x_2007wk24v0.070
Language Pack:
- not available.
SLPA ver[2]: PA_SL2 (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei plain is invalid !!!
Imei net: 12345610654321?
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
em nhìn thấy cái imei đẹp quá bây giờ là phải mua rpl rùi nhưng em không biết mua thế nào em có mxkey thui mong các bác giúp đỡ
