Kết quả 1 tới 10 của 14
    Thành viên mới maiquynh's Avatar
    Apr 2009
    Mặc định 5610 tự khởi động lại nguồn
    em có máy 5610 cứ dùng một lúc là tự khởi động lại nguồn,em đã chạy v9.40 cho nó rồi.nhưng vẫn chưa được.xin giúp đỡ.
    Powering the phone... Reading... MCU SW version: V 09.40 07-11-08 RM-242 (c) Nokia HW version: 1201 PCI version: RFIC version: 17141715 DSP version: ICPR71_08w30 LCD version: SHARP PPM version: V 09.40 07-11-08 RM-242 (c) Nokia v BT MCM version: 2222-143 Retu version: 15 Tahvo version: 22 Content Pack version: Content: white_v_no_yahoo V 09.40 07-11-08 RM-242 (c) Nokia Production serial number: CXA669208 Product code: 0552249 Module code: 0203378 Basic production code: 0515121 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 358652017243995 IMEI spare to net: 3A 85 56 02 71 42 93 09 IMEI SV to net: 33 85 56 02 71 42 93 59 F8 LOCK STATUS: CONFIG KEY: 800000
    2:56 AM 18/8 CONFIG KEY: 8000000000000006 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-242.ini Saved INI not found, loading INI list
    2:56 AM 18/8 WARNING! Update your Pkey to increase life counter! Setting local mode... Reading product code... Product Code: 0552249 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-242\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-242\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-242\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done!
    Thành viên tích cực giakhang84's Avatar
    Dec 2007
    Cho nó cái pm gôd coi có khả thi hok anh
    Sửa chửa & dao tạo học viên sửa DTDD
    tân hiệp - kiên giang phone: 0909646664
    Thành viên chính thức nhatphuongmobiles's Avatar
    Thay dây nguôn thử coi bạn
    Thành viên tích cực tronghienmobile's Avatar
    Apr 2009
    bạn bỏ thẻ nhờ ra xem còn bị ko.nếu hết thì pomat thẻ.neu ko hết.bạn xoá full rui chạy lại thư xem.mjnh cung gặp trương hợp này nhiu rùi thương chạy lại rùi pomat the là ok.đời máy 5610 là chùa hay bị bênh khởi đông lại nguồn
    Thành viên mới tlgsmex's Avatar
    Sài gòn
    Trước tiên update cái pkey của bạn ..........
    check coi ape có đủ áp không nếu nếu không thì câu cấp áp cho nó .....
    V.I.P NAMMC's Avatar
    Aug 2007
    ..::Ngoc Linh Mobile::..
    Nhìn cái Log mà hoa mắt . Xoá Full nạp lại là OK
    Thành viên chính thức ngocdatn's Avatar
    Thái Bình quê em
    em cung co con 5610 khoi dong nguon len nokia roi rot nguon ai co cach nao xin giup
    V.I.P thinhtam's Avatar
    Nov 2008
    Trích Được post bởi ngocdatn Xem bài viết
    thế thì chạy cho nó thử xem BB5 này hay bị thế này lắm.................5610d RM-242_9.40.rar
    Thành viên chính thức trantrongdiep's Avatar
    Usa
    May ong chang biet gi toan co noi doc
    Nov 2008
    Trích Được post bởi trantrongdiep Xem bài viết
    cai vụ này mới ah các bác...
  1. 5610 hao nguồn chờ
    By manhdung81mobile in forum BB5
    Bài viết cuối: 15-10-2012, 20:04
  2. 5610 gọi mất nguồn
    By kimjunsao86 in forum BB5
    Bài viết cuối: 31-07-2011, 06:23
  3. 5610 mât nguôn
    By phanquocquan in forum DCT3-DCTL
    Bài viết cuối: 19-07-2010, 15:00
  4. 5610 mất nguồn
    By minhhoang in forum BB5
    Bài viết cuối: 02-12-2009, 08:40
  5. 5610 rớt h2o hao nguôn
    By vantuan_huemobile in forum BB5
    Bài viết cuối: 23-12-2008, 20:12
