Kết quả 1 tới 4 của 4
    Thành viên mới toan-mobile's Avatar
    Apr 2008
    Mặc định 6303 rm-443 mat song
    mình vừa thay cặp mà không có sóng, flash lại by mx-box nhưng not okMXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C0814731
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 000039EC
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.73
    Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
    Processing MCU file: rm443__09.10.mcusw
    [BB5,BB5 ALGORITHM] size: 24.61 MB
    Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C05EF61
    CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 1BA0010EBEA68D56BF81FB8A97B6C0CA0DA322EB
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x68680 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x76C80 bytes
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 34B3B657
    Verifying communication to device OK.
    Erase size: 28.25 MB
    CMT FLASH,NOR area [00000000-0001FFFF] erased in 0.657 s
    CMT FLASH,NOR area [00040000-0005FFFF] erased in 0.578 s
    CMT FLASH,NOR area [00060000-0007FFFF] erased in 0.703 s
    CMT FLASH,NOR area [00080000-0015FFFF] erased in 4.235 s
    CMT FLASH,NOR area [00160000-0023FFFF] erased in 4.703 s
    CMT FLASH,NOR area [01740000-0191FFFF] erased in 9.422 s
    CMT FLASH,NOR area [00240000-0173FFFF] erased in 1 min 44.422 s
    CMT FLASH,NOR area [022E0000-0261FFFF] erased in 16.312 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: E8E6E2AB [RAP Certificate 140 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT ISA+DYNSW block sent
    Programming completed in 2 min 28.437 s
    Processing PPM file: rm443__09.10.ppm_v
    [BB5,BB5 ALGORITHM] size: 7.22 MB
    Erase size: 9.75 MB
    CMT FLASH,NOR area [01920000-022DFFFF] erased in 48.688 s
    Programming completed in 46.562 s
    Processing CNT file: rm443__09.10.image_v_steel
    [BB5,BB5 ALGORITHM] page size: 128 K size: 16.02 MB
    Erase size: 25.62 MB
    CMT FLASH,NOR area [02620000-029BFFFF] erased in 24.094 s
    CMT FLASH,NOR area [029C0000-03FBFFFF] erased in 2 min 10.469 s
    Programming completed in 1 min 37.719 s
    Total time for flashing process(boot+erase+write) was 12 min 17.578 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...
    Waiting for device boot up ...
    Device connected: nmwcdc\Nokia 6303 classic USB Phonet, PORT_ID: 35B607CD
    Phone type: RM-443 (Nokia 6303 classic)
    SW version: V 09.10 25-08-09 RM-443 (c) Nokia
    Imei plain: 35150504398412-2
    Product code: 0584688
    Battery voltage: 3698 mV, current: 191 mA
    Language Pack:
    - not available.
    SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
    warning: avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 351505043984122
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Market items is empty, please select the correct products path !
    ae xem và hỗ tợ với thanks.
    Apr 2008
    sao ko ai giúp hết vậy?
    Moderator THIÊN UY™'s Avatar
    Bình Dương
    Apr 2008
    Trích Được post bởi THIÊN UY_GSM Xem bài viết
    hinh gì vậy bro?
  1. iphone 3g restone song mât song
    By hiep dien thoai in forum iPHONE 3G
    Bài viết cuối: 03-04-2013, 22:47
  2. 1209 tu nhien mat song mo nguon len lai co song
    By sonkhung in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 13-07-2011, 07:55
  3. Trả lời: 11
    Bài viết cuối: 10-06-2011, 22:55
  4. Trả lời: 4
    Bài viết cuối: 24-04-2010, 14:36
  5. 1110i mo nguon co song roi lai mac song
    By vansuqt in forum DCT4 - WD2
    Bài viết cuối: 21-01-2009, 14:34
