Kết quả 1 tới 8 của 8
    Thành viên chính thức phuvd's Avatar
    Oct 2011
    Mặc định Cứu giúp em con nokia 500
    Trước đó em đã chạy được vài con rồi, nhưng không hiểu sao hôm nay đen quá(ăn thịt cầy thì phải), em dùng phoenix quất như bình thường, không ngờ em nó ngủ luôn(máy mới, em chạy tiếng việt). Em không backup RPL
    Đây là em nó
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 15168 bytes
    Secondary boot loaded
    BB Asic Index is: 00
    Asic ID is: 000000030000022600010007400C192103032108
    EM Asic ID is: 00001040
    EM Asic ID is: 00001060
    Public ID is: 0C240000FFFB3C40A855A0DDC714610F45E8B524
    Asic Mode ID: 00
    Hash: 3AB5DB70B45D23F1ADEEBB5734160706
    ROM ID: 2CAC45E23BC33C8B
    Device type is: 05
    Device Index is: 00
    Manufacturer code: 0000
    Device ID: 0000
    Extended device ID: 0000
    Revision ID: 0000
    Device type is: 04
    Device Index is: 00
    Manufacturer code: FFFF
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 00
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 01
    Device ID: 0001
    Revision ID: 0000
    Device type is: 03
    Device Index is: 00
    Manufacturer code: 00EC
    Device ID: 0050
    Revision ID: 0232
    Loading update server code: 868640 bytes
    Update server loaded
    Asic CMT: Start programming 267759 KB...
    Asic CMT: Programming data sent: 0%
    Asic CMT: Programming data sent: 10%
    Asic CMT: Programming data sent: 20%
    Asic CMT: Programming data sent: 30%
    Asic CMT: Programming data sent: 40%
    Asic CMT: Programming data sent: 50%
    Asic CMT: Programming data sent: 60%
    Asic CMT: Programming data sent: 70%
    Asic CMT: Programming data sent: 80%
    Asic CMT: Programming data sent: 90%
    Asic CMT: Programming data sent: 100%
    Programming complete
    Asic CMT: Verifying communication to device...
    Waiting for communication response: 25
    Waiting for communication response: 24
    Waiting for communication response: 23
    Waiting for communication response: 22
    Waiting for communication response: 21
    Waiting for communication response: 20
    Waiting for communication response: 19
    Waiting for communication response: 18
    Waiting for communication response: 17
    Waiting for communication response: 16
    Waiting for communication response: 15
    Waiting for communication response: 14
    Waiting for communication response: 13
    Waiting for communication response: 12
    Waiting for communication response: 11
    Waiting for communication response: 10
    Waiting for communication response: 9
    Waiting for communication response: 8
    Waiting for communication response: 7
    Waiting for communication response: 6
    Waiting for communication response: 5
    Waiting for communication response: 4
    Waiting for communication response: 3
    Xong thì nó nhảy lên cái bảng thông báo như hình dưới, em đã rút cáp ra và cắm lại nhiều lần rồi vẫn thông báo như thế, mong anh em giúp đỡ.
    Thành viên tích cực anh tú_gsm's Avatar
    Jan 2011
    hạ hòa - phú thọ
    cho vào box khác plash lại coi được không quăng cái log lên ae chiêm ngưỡng nhé
    ĐIỆN THOẠI DI ĐỘNG ANH TÚ - KHU 17 - ĐẠI PHẠM - HẠ HÒA - PHÚ THỌ. ĐT: 0985 69 0949
  3. ( anh tú_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    phuvd (19-03-2012)
    Oct 2011
    Dòng Symbian này chạy Mx key không được, HWK cũng bó tay, mà em chỉ có box Jaf, HWK và Mx Key thôi, cứu em
    Thành viên chính thức thanhtan1987's Avatar
    Jan 2010
    kiếm file khác chạy lai coi sao nghe bạn
    không được đưa vô box chạy lại luôn
  6. ( thanhtan1987 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    phuvd (19-03-2012)
  7. #5
    Thành viên tích cực thuy1986's Avatar
    cho lên file 111 đi bạn ? đụng nóc đi chứ để làm gì nữa ?
  8. ( thuy1986 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    phuvd (19-03-2012)
  9. #6
    Oct 2011
    Ok. em sẽ nâng, lát nữa em xem tình hình rồi sẽ báo lại anh em
  10. #7
    Thành viên chính thức tamquyen's Avatar
    Dec 2010
    không backup quá mạo hiểm
  11. #8
    Oct 2011
    Đã tiêm cho em nó liều 111.20.59 và đã OK, cảm ơn tất cả các anh em đã chia sẽ !
    Chủ thread đã làm ok.Xin Phép Close topic
  1. Trả lời: 5
  2. Trả lời: 5
    Bài viết cuối: 09-01-2013, 15:47
  3. Trả lời: 5
  4. Trả lời: 10
  5. Trả lời: 25
