Kết quả 1 tới 7 của 7
    Thành viên chính thức nguyenlaluong's Avatar
    Mặc định C6-00 mất nguồn xin giúp thank.
    em nhận được một con c6-00 bi rơi đất em kẹp dòng rung một cái treo dòng 1.8v khoảng 8==>16 s rồi rút về không em chạy phần mềm nhưng vẫn bị như thế xin pro giúp em cai thank day la logg cua nó :CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
    CMT ROM ID: 4B9B75103E691FF8
    Loading CMT secondary boot code
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Loading CMT update server data
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
    Update server code loaded.
    FUR: Adding Asic CMT as client OK.
    CMT PAPUBKEYS HASH: 505A5C85580A6322C103BFE4E67B73EF478E791C
    Original Imei: 00000000000000
    Original Product code:
    SIMLOCK PA identifier:
    [0] PA_SIM
    Reading CMT NPC (0xFF bytes).
    Reading CMT VARIANT (0x0 bytes).
    Reading CMT CCC (0xFF bytes).
    Reading CMT HWC (0xFF bytes).
    Reading CMT R&D (0xFF bytes).
    Reading CMT PARTNERC (0x0 bytes).
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Waiting for device boot up ...
    Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: 46F464C
    Verifying communication to device OK.
    Phone type: RM-612 (Nokia C6-00)
    SW version: V ICPR72_11w04.2 09-08-11 RM-612 (c) Nokia
    Imei plain: 35150304437218-1
    Product code: 0597944
    Battery voltage: 3709 mV, current: 276 mA
    ApeCoreSw: v 41.0.010
    Language Pack:
    - not available.
    SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
    warning: avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Phone version(v 41.0.010) outdated, selected version is: 40.0.021
    Imei net: 351503044372181
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Thành viên tích cực SỸ HẢI_mobile's Avatar
    thử bỏ cục pin xạc đầy vào coi sao
    sỹ Hải_mobile
    em thay cả cục khác cũng không được nó chỉ rung một cái , mấy huynh gặp bệnh này rồi xin chỉ em cái thank.
    ko được thì chạy lại ver đụng nóc luôn xem sao
    sỹ Hải_mobile
    Moderator Dong_Mobile's Avatar
    Nov 2010
    Log vậy là OK rồi.xem lại dây nguồn và giao động thử xem
    em tháo máy ra rồi máy này tho khác đã lam đến phần cứng rồi , bay giờ không biết phải làm từ đâu xin giúp thank.
    V.I.P Thanh_6868's Avatar
    Oct 2008
    Bỏ pin vào rồi cắm sạc xem nếu ko sạc đựoc thì làm đường BSI
    ThanhlongmobileServieCenter
    Số 2 An kim Hải-Lê Chân-Hải Phòng:ĐT: 0942006868, yahoo: Thanhkienan@yahoo.com
