Kết quả 11 tới 15 của 15
    Thành viên danh dự minhung334's Avatar
    Jul 2008
    TpHCM
    chắc bị pm rồi, log có vấn đề, log đây:
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0853831
    Using device: USB Phonet and HTI, FW ver: 00.50, SN: 00003D39
    Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
    Driver: nmwcdc, ver: 7.1.32.70
    Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
    Reading Important data ...
    NPC_DATA is empty.
    SIMLOCK_DATA saved OK
    SIMLOCK_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    LOCK120_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35341704294962_PM .rpl"
    Processing MCU file: rm561__09.97.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
    NOR page size in the phone is 128 K.
    Battery voltage: 3823 mV
    Phone type: RM-561 (Nokia 2700 Classic)
    Product code: 0581057
    SW version: V 09.95 - 02-04-10 - RM-561 - (c) Nokia
    LanguagePkg version: 5 - 02-04-10 - RM-561 - (c) Nokia - V
    Version from phone: 09.95
    Version from file: 09.97
    CMT BOOT ID: 0803000302010000
    CMT PUBLIC ID: 0F7000149FE000569C7C8E301B340629AAA1D7DD
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
    Storage0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR, asic:CMT
    Storage0: 0000 0000 - 0000 0000 [unused/removed] type: NAND, asic:APE
    Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
    Update Server code succesfully sent to phone.
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 9DE3704
    Verifying communication to device OK.
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.000 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.000 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 0.016 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 0.016 s
    CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 17.219 s
    CMT FLASH,NOR area [01380000-0151FFFF] erased in 6.812 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 1 min 42.609 s
    Processing PPM file: rm561__09.97.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF] erased in 37.469 s
    Programming completed in 32.546 s
    Processing CNT file: rm561__09.97.image_v_blac
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 15.985 s
    CMT FLASH,NOR area [02160000-03FBFFFF] erased in 2 min 13.672 s
    Converting UCP blocks to 128 K.
    Programming completed in 1 min 15.500 s
    Total time for flashing process(boot+erase+write) was 8 min 19.359 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Waiting for device boot up ...
    Device connected: nmwcdc\Nokia 2700 classic USB Phonet, PORT_ID: 31A7DFE1
    Phone type: RM-561 (Nokia 2700 classic)
    SW version: V 09.97 18-06-10 RM-561 (c) Nokia
    Imei plain: 35341704294962-7
    Battery voltage: 3834 mV, current: 93 mA
    Language Pack:
    - not available.
    SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
    warning: avoid SW Downgrade & manual erase to this phone !
    Camera config: NIMMIIIIRRFF0A021001, ver: 002.007
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 353417042949627
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    FULL FACTORY... OK
    Completed in 1.750 s
    AE xem thử
    V.I.P hoanglanhpromobile's Avatar
    Jul 2008
    korea
    log bình thường có lỗi gì đâu bạn .
    hãy nhấn nút THANKS khi bài viết hữu ích cho bạn . thank all
  3. ( hoanglanhpromobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    minhung334 (26-03-2012)
    Jul 2008
    TpHCM
    chắc nhầm rồi, đưa log vào giao diên Win xem cho dễ thấy xuất hiện 2 dòng tô màu tưởng bị lỗi, ai dè.....
    thank A
    Thành viên chính thức minhhaiangiang's Avatar
    Oct 2009
    Số 9 Trưng Nữ Vương, F1, TP Vĩnh Long
    Thay con R2072 thử đi bạn.
    Oct 2009
    Gở bỏ thử và sau đó là thay con điện trở R2072 xem sao bạn (xử lý vấn đề pin đầy mở nguồn không lên không nói vấn đề chạm).
  1. xin giúp 2700c
    By manhdung81mobile in forum BB5
    Bài viết cuối: 24-06-2012, 10:56
  2. 2700c cần anh em giúp
    By thanhphuek in forum BB5
    Bài viết cuối: 04-09-2011, 00:25
  3. 2700c xin giúp
    By hanayuky18 in forum BB5
    Bài viết cuối: 03-09-2011, 15:40
  4. Trả lời: 15
    Bài viết cuối: 01-06-2011, 12:30
  5. 2700c cần giúp
    By anhquoc in forum BB5
    Bài viết cuối: 24-08-2010, 08:34
