chạy bằng fbus thì báo lỗi thế này
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0859FA3
Using device: HTI, FW ver: 00.17, SN: 0000C258
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012)
Processing MCU file: rm233__10.00.mcusw
[BB5,BB5 ALGORITHM] size: 18.95 MB
Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1B80020F8B9F7C56DD026A8D9324AF98D81157D1
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Erase size: 21.12 MB
CMT FLASH,NOR area [00000000-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [013C0000-0153FFFF]
CMT FLASH,NOR area [00140000-013BFFFF]
erased in 55.482 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 35533D51 [RAP Certificate 70 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 57.802 s
Processing PPM file: rm233__10.00.ppm_v
[BB5,BB5 ALGORITHM] size: 5.99 MB
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
CMT PAPUBKEYS HASH: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A
Erase size: 6.50 MB
CMT FLASH,NOR area [01540000-01BBFFFF]
erased in 17.117 s
NOR: OK
NOR: OK
Programming completed in 38.105 s
Processing CNT file: rm233__10.00_ISM_002.image_v_vn_gold
[BB5,XSR 1.5] page size: 128 K size: 41.13 MB
NOR page size in the phone is 128 K.
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Algorithm: RAP3Gv3_algo_xsr15.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x26CB8
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Erase size: 35.87 MB
CMT FLASH,NOR area [01EC0000-03F9FFFF]
CMT FLASH,NOR area [01BC0000-01EBFFFF]
erased in 16.031 s
NOR: OK
Converting UCP blocks to 128 K.
Error chk C7012D0103CD
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00044000, Result: 0000
Task failed at (0800001C)!!!
Last RX buffer: C7 01 2D 01 03 CD 00
bật nguồn không thấy lên nữa
