Kết quả 1 tới 4 của 4
    Thành viên tích cực ATmobile_qn's Avatar
    Aug 2011
    Mặc định 2690 flash không đồng bộ được
    đây là log flash bằng usb , chạy bằng cáp đa năng vẫn vậy
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C0855BC7
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 000162C3
    Connection status: EHCI:HUB:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012)
    Processing MCU file: rm635__09.90.mcusw
    [BB5,BB5 ALGORITHM] size: 17.92 MB
    Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
    CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 12B00008CD1F005655E771B487C3CD1C0BE9AF5C
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x49480 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x57AC0 bytes
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 384D271
    Verifying communication to device OK.
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.781 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.796 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.891 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.640 s
    CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 43.187 s
    CMT FLASH,NOR area [01380000-0151FFFF] erased in 9.157 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: C6B9354E [RAP Certificate v1 246] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 1 min 18.172 s
    Processing PPM file: rm635__09.90.ppm_t
    [BB5,BB5 ALGORITHM] size: 3.86 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF] erased in 46.000 s
    Programming completed in 16.594 s
    Processing CNT file: rm635__09.90_001.image_t_globe_ph_1K5B9
    [BB5,BB5 ALGORITHM] page size: 128 K size: 6.88 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 25.000 s
    CMT FLASH,NOR area [02160000-03FBFFFF] erased in 4 min 16.141 s
    Programming completed in 1 min 28.890 s
    Total time for flashing process(boot+erase+write) was 11 min 6.250 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...
    Waiting for device boot up ...
    Phone not found, retrying ...
    Warning: Phone did not reboot to normal mode.
    Market items is empty, please select the correct products path !
    Yahoo:thanhtruyenmobile ĐT: 0989 413 413
    Thành viên danh dự KHA_MOBILE67's Avatar
    Apr 2010
    ẤP TÂN MỸ 2-PHƯỜNG TÂN LỘC-QUẬN THỐT NỐT-THÀNH PHỐ CẦN THƠ
    anh mang qua phoenix và hợp khác flash thử xem coi xem sau anh...mà máy ban đầu bị như thế nào anh nói rõ nhé anh...rồi tính tiếp nha
    Sữa chữa điện thoại di động..Chạy phần mềm..Nạp tiếng việt..Unlock máy nước ngoài...tại ấp tân mỹ 2...quận thốt nốt...thành phố cần thơ
  3. ( KHA_MOBILE67 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ATmobile_qn (14-04-2012)
    May 2010
    ĐIỆN BIÊN
    load cái ver đụng nóc về chơi đi anh.10.65
    TRUNG HIẾU MOBILE
  5. ( QUANGTRUNG_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Aug 2011
    ok rồi. cảm ơn Quangtrung nha. Tại kô biết có ver cao vậy
  1. Cần xin file flash của 2690
    By newrecyclebin in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 01-11-2013, 08:10
  2. Trả lời: 36
    Bài viết cuối: 22-12-2012, 20:58
  3. file flash 2690 ver 10.10
    By QUANGTRUNG_GSM in forum BB5
    Bài viết cuối: 26-08-2012, 10:35
  4. Trả lời: 15
    Bài viết cuối: 28-05-2012, 07:32
  5. 2690 chập flash và công suất cần giúp
    By manhhung202000 in forum BB5
    Bài viết cuối: 22-09-2011, 09:47
