Kết quả 11 tới 13 của 13
    Thành viên tích cực sang_apple's Avatar
    Feb 2012
    F,3 Q4 ,Hồ Chí Minh
    Mặc định 5310 cần ae giúp
    mình nhận cây 5310 khởi động len nokia rồi tắt treo 1.8 , mình đã nạp pm rồi vẫn ko hết , dưới đây là log của e nó , ae xem giúp mình với.......
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C084160D
    Using device: HTI, FW ver: 00.50, SN: 00010AAF
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006
    010C192101013000
    EM0 ID: 00000295
    EM1 ID: 00000B22
    PUBLIC ID: 1C00010681135950E05FB134EC830BBE64B3C80E
    ASIC MODE ID: 00
    ROOT KEY HASH:
    BAF3A9C3DBFA8454937DB77F2B8852B1
    ROM ID: 273F6D55DFAAF68F
    SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    eBB5ProtocolType: OLD
    Storage0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
    CMT PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D
    TransmissionMode: DDR&TX2
    Processing MCU file: rm303__09.42.mcusw
    [BB5,BB5 ALGORITHM] size: 17.07 MB
    Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
    Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
    Erase size: 18 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-010DFFFF]
    CMT FLASH,NOR area [010E0000-0121FFFF]
    erased in 1 min 6.656 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3E96DE42 [RAP Certificate 90 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: OK
    Programming completed in 1 min 15.922 s
    Processing PPM file: rm303__09.42.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.24 MB
    Erase size: 6.50 MB
    CMT FLASH,NOR area [01220000-0189FFFF]
    erased in 24.125 s
    NOR: OK
    NOR: OK
    Programming completed in 29.047 s
    Processing CNT file: rm303__09.42.image_v_red
    [BB5,BB5 ALGORITHM] page size: 128 K size: 10.01 MB
    Erase size: 39.12 MB
    CMT FLASH,NOR area [018A0000-01B1FFFF]
    CMT FLASH,NOR area [01B20000-03FBFFFF]
    erased in 2 min 54.406 s
    NOR: OK
    NOR: OK
    Programming completed in 46.578 s
    Total time for flashing process(boot+erase+write) was 7 min 4.157 s
    Phone type: RM-303 (Nokia 5310 XpressMusic)
    SW version: V 09.42 07-11-08 RM-303 (c) Nokia
    Imei plain: 35687002839009-0
    Product code: 0565758
    Battery voltage: 4525 mV, current: 15 mA
    Language Pack:
    - not available.
    SLPA ver[2]: PA_SL2 (15 digit NCK)
    Camera config: XXXXXX, ver:
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 356870028390090
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Luôn lắng nghe và học hỏi....
  1. giúp em với e51 và 5310 đen màn
    By kotexsytin in forum BB5
    Bài viết cuối: 08-05-2010, 18:21
  2. Giúp em với .......5310
    By Mr.ch1p in forum BB5
    Bài viết cuối: 25-02-2010, 18:43
  3. xem giúp mình cái LOG 5310
    By ngocminh_dtdd in forum BB5
    Trả lời: 13
    Bài viết cuối: 08-01-2010, 15:04
  4. Trả lời: 4
    Bài viết cuối: 05-01-2010, 09:19
  5. Máy 5310 MP4 ko sạc được cần giúp đỡ
    By viethieuk150 in forum Sửa chữa phần cứng
    Bài viết cuối: 19-10-2009, 21:15
