load file ver đụng lóc nhà về rồi đạp cho nó 1 cái.not ok cho 200 đ log ae xem nào
HÃY HẾT LÒNG VÌ KHÁCH HÀNG
em xin lôi... các anh.......... em vừa bán hàng song...... em chạy cho nó ver....
Ver......Rm_675_013.016_79.92_prd_core_fpsx....... .....
mong các anh coi giùm em với.............
em chạy bằng Mx-key nhe..........................
MXKEY [FT SCR2000 0], SN: C0801C94
Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.72
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
Processing MCU file: RM-675_013.016_79.92_prd.core.fpsx
[BB5,XSR 1.6] size: 128.82 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: BF541CF
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 11D00113B9D80344EE7A4D5FF21CDF33D70F1ACA
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0068 - 0000 0131 [Samsung LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x0 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x0 bytes).
Reading CMT HWC (0x0 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Invalid Certificate Data, backup will not be created.
Error saving backup !
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 489.06 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF]
CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 95A68E9F [RAP Certificate v1 263] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 20.169 s
Processing PPM file: RM-675_013.016_20.01_Thai_79.92_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 24.45 MB
Erase size: 59.25 MB
CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 3.873 s
Processing PPM file: RM-675_013.016_C02.01_SEAP_79.92_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 11.30 KB
Erase size: 15 MB
CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 0.156 s
Total time for flashing process(boot+erase+write) was 35.499 s
Waiting for device boot up ...
Warning: Phone did not reboot to normal mode.
em But check dược thế này thôi......................
Connection status: EHCI:HUB:HUB:USB 2.00 (High-speed)
Original Imei: 00000000000000
Original Product code:
vào navi lấy file cao nhất về chạy nhé.không dc thì mang qua box khác chạy.song đưa log lên nhé
Tam Điệp Ninh Bình
Chạy ver cao hơn cho nó đi
chạy xong lên ngay
vay hả....... cảm ơn anh nhiều nha......... nhưng em chay ver cao hon có bị banh IME ko vây anh............
không banh đâu bạn chạy ver cao nhất đùng code sẽ tỉnh ngay có ATF không cho nó flash ngọt hơn
có anh nào co' file cao nhất ko....... gủi cho em xin với........em tìm ỏ trên NAVIFIRM ma' ko thấy có file nào cao hơn........
