bị rớt nước chạy ct vẫn len chớp mấy cái rồi tắt luôn có khi vào dc ngay tháng.sau khi kiểm tra lại vì thấy ic phím hư nên che dậy kỹ thay thế (vì ko xem sỏ dồ cứ nghỉ ic mh ) khò thay xong tự nhiên vào tất ca dc các ct nhưng vẫn bị liệt phím thế là lai thay con ic phím khác thay xong lai bị bệnh ban dâu chớp tắt nho anh em xem dùm
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085C6B5
Using device: USB ROM and HTI, FW ver: 00.24, SN: 0001608A
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.70
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
Processing MCU file: rm640__06.05.mcusw
[BB5,XSR 1.6] size: 30.60 MB
Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 26C75DEE
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: 24700210ABA60344C8CB12E0F958F841A670686D
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35830603031465_CE RT.rpl"
CMT PAPUBKEYS HASH: 5AA09885C97BF3B0F6783A6337506F9394F346EF
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 45.06 MB
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-0009FFFF]
CMT FLASH,MuxOneNAND area [000A0000-0041FFFF]
CMT FLASH,MuxOneNAND area [00420000-0069FFFF]
CMT FLASH,MuxOneNAND area [006A0000-006DFFFF]
CMT FLASH,MuxOneNAND area [006E0000-0123FFFF]
CMT FLASH,MuxOneNAND area [02060000-020BFFFF]
CMT FLASH,MuxOneNAND area [02CC0000-0333FFFF]
CMT FLASH,MuxOneNAND area [07540000-07B3FFFF]
CMT FLASH,MuxOneNAND area [01240000-0205FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 5AA09885 [RAP Certificate v1 261] sent
CMT RAP3NAND block sent
CMT UPDAPP block sent
CMT LDSP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 5.734 s
Processing PPM file: rm640__06.05.ppm_v
[BB5,XSR 1.6] size: 8.75 MB
Erase size: 12 MB
CMT FLASH,MuxOneNAND area [020C0000-02CBFFFF]
Programming completed in 1.578 s
Processing CNT file: rm640__06.05.image_v_0599706_006
[BB5,XSR 1.6] size: 38.46 MB
Erase size: 66.06 MB
CMT FLASH,MuxOneNAND area [03340000-0753FFFF]
Programming completed in 7.625 s
Total time for flashing process(boot+erase+write) was 41.390 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C3-01 USB Phonet, PORT_ID: 30C7696
Verifying communication to device OK.
Phone type: RM-640 (Nokia C3-01)
SW version: V 06.05 30-05-11 RM-640 (c) Nokia
Imei plain: 35830603031465-1
Product code: 0599709
Battery voltage: 3958 mV, current: 148 mA
Language Pack:
- not available.
SLPA ver[5]: PA_SIMLOC30 (20 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 0A4E2007008005, ver:
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358306030314651
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
Market items is empty, please select the correct products path !
