Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 21
    Thành viên chính thức qazxcdew's Avatar
    Mar 2012
    Exclamation nokia E63 lỗi phần mềm
    máy mở nguồn lên báo=> phone start-up failed..Contact the retailer
    em buscheck được thế này thôi....
    các anh xem giùm em với
    MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C08727CF
    Using device: HTI, FW ver: 00.50, SN: 01006314
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006
    400C192101031103 [RAPIDO3G ver: 1.13]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 059001099C928D52A479AC85174CCF07C7D228CE
    ASIC MODE ID: 00
    ROOT KEY HASH:
    9A28E119033B91D14D22838C86D0D53C
    ROM ID: 4B9B75103E691FF8
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.2.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
    Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.2.0 revision: 2.0 size: 0x8B45D
    FUR: Adding Asic CMT as client OK
    CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6
    Selected firmware certificate matched.
    Original Imei: 35150204654340
    Original Product code: 0590148
    Bluetooth ID: 5C57C8245DE0
    SIMLOCK PA identifier:
    [0] PA_SL2
    [1] PA_SL3
    Phone type: RM-437 (Nokia E63)
    SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia
    ApeCoreSw:
    510.21.010
    Imei plain: 35150204654340-1
    Battery voltage: 4526 mV, current: 7 mA
    Language Pack:
    - not available.
    SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
    warning: avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Phone version(510.21.010) outdated, latest version on server is: 42.0.004
    Imei net: 351502046543401
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    V.I.P DAKLAK-GSM's Avatar
    Aug 2010
    SECURITY_TEST failed! hên xui, thử bằng mxbox , write 1 va 309 , (sl3}
    Thành viên mới Phú SàiGòn-GSM's Avatar
    Dec 2011
    Vấn đề nằm ở đây.Repair SD + Write pm + Super SD lại ok
    Thành viên kỳ cựu KUNEK_GSM™'s Avatar
    Jun 2011
    THIẾU LÂM TỰ
    phu saigon chuẩn khỏi chỉnh làm theo đi bạn
    NGỌC NĂNG SERVICE LÂM HÀ-LÂM ĐỒNG
    CHUYÊN : unlock repair update Firmware tiếng việt ALL MOBILE
    Y/H nangngocdao09@yahoo.com
    SDT:0977+1+7+1+0+3+7
    TK AGRIBANK 5404205189059
    Mar 2012
    dạ vâng... cảm ơn các anh
    hơi khó hiểu 1 chút...
    Write pm,,, có phải là nạp lại pm mới không
    repair SD + Super SD là gì ạ.......
    chỉ em kĩ kĩ với..... xl em không được đi học sửa Dt....nên hơi khó hiểu 1 chút ... mong các anh dậy bả thêm
    Mar 2012
    và em cần dùng box nào ạ.......
    hiện em có 2 hộp..... MX box với Hwk
    Dec 2011
    Mở Mx-box lên,info cho nó thấy máy.Rồi bấm qua bản Service ---> PM bạn sẻ thấy mục Repair SD
    Repair SD => SUPER SD Auth => pm full => lượm lúa
    Mar 2012
    không được anh ak
    yahoo của em .... mr.manh71@yahoo.com
    Mar 2012
    Pm full là nạp pm mới ak
    Mar 2012
    em làm giống như các bước như anh Phú Sài Gòn mà không được.... hay là em làm sai bước nào...
  1. Trả lời: 18
    Bài viết cuối: 24-09-2013, 21:36
  2. cần ae giúp chạy phần mềm n8
    By mobingoc in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-04-2013, 14:06
  3. n72 chạy phần mềm báo lỗi
    By hoanglong33a in forum BB5
    Bài viết cuối: 29-09-2010, 09:48
  4. Xin phần mềm chuyển .avi cho smartmovie
    By nguyen_hiep778 in forum BB5
    Bài viết cuối: 25-03-2010, 11:38
